Question about Gateway FPD1960 19" Flat Panel LCD Monitor
How do you disassemble the monitor? I want to repair it...I have taken all the screws out of the back of the monitor, but I can not figure out how to pop off the back without damaging the monitor. Please help, Thanks!!
  • 11,361 Answers
I use thin flat blade screw driver to crack it open at the bottom edge so any scratch will not show up as bad, not much you can do from not scratching it up due to the way the front and the back are snapped together with plastic fingers. It is worst on the newer one.
Look for bad caps in this model.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Posted on Jan 04, 2011
How do you disassemble the case to repair light?
You remove all the screws and the stand, then use a thin flat blade screw driver to crack open the case starting at the bottom edge of the monitor first and work your way around, it is kind of hard to explain in words, just be real careful on the switch assembly in the front bezel.
You can also look a YOUTUBE on how to disassemble LCD monitors.
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
Please post back what you find.
Sep 07, 2010 | Sceptre X9G-NagaIV 19" LCD Monitor
After couple hours of use the screan will go black and power led will flash. If left unpluged for a while (2-3) hrs and is pluged back in it will work again for a short piored of time. I was guessing that...
Just repaired mine. Had a couple of bad caps on the power board.
For disassembly, on the back the two hinge covers will slide off sideways, exposing 4 screws holding the hinge assembly to the monitor. remove that piece and you can get to all three screws holding the plastic monitor shell together. After those three screws are removed, its just snapped together so use a small screwdriver or blade to pry apart. I started at the button area on the bottom and worked up from there. Good Luck.
May 17, 2010 | Computers & Internet
How to open (remove back) Omnitech Vw19B LCD Monitor
You are right about the problem on the flourescent, but the issue is caused by the mosfet transistors. You need to use a flat screwdriver to pry the back of the display until you get this open. Start from the bottom side because some damage will be left on the plastic.
Apr 15, 2010 | LG Flatron L1951S-SN 19" LCD Flat Panel...
LG1917S-BN Access to power supply - Rear cover removing
You need to use flat thin blade screw driver to crack open the case, starting at the bottom edge of the case first, you may need two screw drivers, when it starting to come apart, leave one screw driver in the partially opening section so it not snap back together while you tackle another section of the case. Most monitors cases these day do not have small slot to show where you should crack open the case at, they just do not want you to fix it.
Feb 23, 2010 | LG L1917S-BN 19" LCD Monitor
Display is blank...power light flashes at around 1 second intervals. display flashes +very faintly+ white as the power light flashes. my guess is power supply fault but... i cant figure out how to remove...
djreynolds, maybe go look for some clues at YOUTUBE and search for videos that are longer than 6 minutes and use search term "LCD monitor disassembly" and "LCD monitor repair" may turn up something!! Also find a very DULL butter knife to prevent visit to emergency entrance of local hospital when "PARTING" the rear plastic cover from the front bezel. Use extreme caution to prevent damage to LCD PANEL. 12fixlouie
Jan 04, 2010 | HP Compaq FP5315 15" LCD Monitor
Samsung 170 MP LCD Monitor Disassembly
The plastic case also has latches along the sides, top and bottom. Take a small flat blade screwdriver and go between the 2 halves of the case. The 2 pieces should open just a bit, now move the screwdrivers along the seam between the 2 halves. about every 2-4 inches there is a clip that needs to be released. You can release it by applying a small amount of pressure by each clip and moving down to the next one while pulling the case apart.
Buddy
Corporate Compuer
over 21 years repairing PCs and printers
Jun 17, 2009 | Samsung SyncMaster 17" TFT LCD Monitor
How to disassemble Mag innovision 19" monitor
Once the 4 screw at the bottom of the screen has been removed the frame surrounding the lcd should slide up and away. The display itself is fastened to the plastic back by 6/8 screws be careful when removing the lcd screen since it is still attached to the electronics in the back by cable connectors!
Feb 27, 2009 | Mag Innovision LT782S 17" Flat Panel LCD...
Acer Monitor, Model No. X223W -- I can't get the arm of the back of the monitor (the thing you stick the base into) in order to mount on a multiple monitor stand (quad)... Spoke with Acer Tech Suppoort and...
i have the same problem with the AL1717. After hours figuring it out, i found the solution.. if you slide off the cover holding the back arm, you will expose the screws holding the arm which you can screw off to take off the back arm....
the cover can easily slide off as it is only 'clicked' into place.... gently put your fingers on the cover apply some pressure to slide it out...
Dec 19, 2008 | Acer AL1717 17" LCD Monitor
Need to know how to Disassemble AL1912 19" LCD Monitor
The ones I take apart have a snap on front bezel.
gently pry at the lcd edge with fingers in center left or right to get it to bow , dont damage the lcd with too much pressure.
it will start to separate ,put a plastic knife or such in the outside crack and work your way around once you have one side the rest will be easier. you have to bow the inside edge out(away from the lcd) because of the plastic clips.
luck.
Apr 17, 2008 | Acer AL1912 19" LCD Monitor
Gateway FPD1960 19" Flat Panel LCD Monitor Logo
69 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
