Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
I have a RCA HDTV D52W20B...and the unit started going off..power light flashes three times and stays off...sometimes it will come on for alittle while then goes back off. I have been reading some of the links about replacing the bad caps...but are they located on the power supply or the other main board ?? does anyone have any pics showing the correct board ?? I can replace them but just need to be pointed in the right direction. Thanks for any help !! Ken kwstovall@sbcglobal.net
  • 13 more comments
  • Ken Stovall Jan 04, 2011
    John...I have included a pic...need to make sure im looking at the right board...There is another board that I see a split cap on as well...right below the power supply if im looking at the right board ?? I have more pics if needed.
    My wife works for Mouser Electronics so I has access to most of all parts I need.
    Thank you,
    Ken Stovall
    817-689-8760
    Thanks Eagle for your reply...I have included two pics...one of the power supply and the other of the High Voltage Board I think ??
    To me the power supply caps all look fine but the high voltage board if thats it...does have a cap near the back that is lifted alittle on top.....was not sure how to unply the red wire going to the one component ??
    Let me know if you need more pics.
    Thanks !!
    Ken
    Eagle....if you need the orginal pics...I can send them to an ftp server or another email address that will accept larger files....the site here as you know is limitied on upload size.
    Ken
    kstovall@stovallcorp.net
    Cool....so I can remove that wire then I can take out the board and replace the bad cap....what is the proper name of this board ?? and do you think I still have a problem with my power supply ??
    ok sounds like a plan...again what is the name of the board that im working on at the bottom left side ??
    oh ok Thanks...I will pull it tonight and check all caps to see how manys bad....have you seen this board in the past to be a trouble maker ??
  • Ken Stovall Jan 05, 2011
    The Red
    There is a red wire on top of the transformer ?? and a black wire right beside it....I think I sent a pic yesterday.
    Here is the pic of the HV Board...if you can send me your email I can send the full size pic.
    Ken
    Here is the link:http://img834.imageshack.us/i/rcahighvol...
    You did...but the wire does not seem to want to come out...I pulled the black cap up first and then tried pulling the red wire out but it does not come....again was wonderding if there is some type of latch or catch before I pull to hard and screw it up ??
    ok Thanks....I will try it at lunch when I go home...does the black wire pull out the same ??
    I removed the board and now going to pickup the 220uf / 35Volt Cap that is bad....never was able to remove the red wire...just flipped the board to remove the cap.
    http://img842.imageshack.us/img842/7112/...
  • Ken Stovall Jan 06, 2011
    Well that fixed the problem bad CP114 Cap on the HV Board....Everything is working great !! Here are a couple of pics of the Bad Boy !!
    Thanks for all your help Buddy !!
    Ken
  • 4,889 Answers
Its definitely the power board or the deflection board(high voltage circuit). We should start by looking on the power supply board. It is the one into which the power cord plugs. Look for faulty electrolytic caps(cylindrical objects with X mark at the top) which are bulged, cracked or have holes in them near the X mark. If you can get me an image of the board, I can mark the faulty caps for you.
Posted on Jan 04, 2011
  • 9 more comments
  • eagle338
    eagle338 Jan 04, 2011
    The black colored rubber cover of the wire should first be pulled up the wire(it slides on the wire) and the wire should just be pulled from the transformer. This pic should summarize the situation
    http://www.agoraquest.com/images/upimage...
  • eagle338
    Yes you can just pull out the wires. It shouldn't be too hard but make sure that you slide the boot up the wire first. As for the power supply, I wouldn't come to any conclusions so soon, but we should first replace the parts that look faulty and then see if it works. So lets start with the capacitor.
    Sai.
  • eagle338
    Its the deflection board AKA HV board.
  • eagle338
    Yes. In cases like this its either the HV board or the power supply. And be careful with the flyback. Let me know how ti goes.
    Sai.
  • eagle338
    eagle338 Jan 05, 2011
    Sorry I did not understand what you meant by "the red"
  • eagle338
    Please upload the image to imageshack.us and get me the direct link. In the image you sent me, I can hardly see it!
  • eagle338
    Seen the image. I thought I already told you how to remove the red one?
  • eagle338
    You need to keep twisting it from side to side as you pull. Ofcourse you have to pull it hard.
  • eagle338
    The black wire has to be dealt with on the board end. It does not pull out
    http://www.manufacturer.com/cimages/prod...
  • eagle338
    Actually none of the caps look bad to me, unless you have already removed it. If thats the case then solder a replacement and see if does the trick.
  • eagle338
    eagle338 Jan 06, 2011
    Oh yeah! I see them. Could not spot them from the top view. Ok replace them and see if it resolves the problem and let me know
    Novelist:
  • 131 Answers
Hello; I am John at J D Electronics in Poland Maine. I have had an RCA model M50WH72S setting dead in my shop for over a year now and is now mine. Your set may be of the same design. If so, The power supply is the likely cause of failure due to bad CHEAP caps. If it is like mine, the Power Supply board is on the left SIDE of the chassis. Any capacitors that have DOMED or SPLIT tops are bad. The set would start intermittently and run for an hour and die. Other times it would not start at all and the LED would flash 5 or 6 times and stop. With NO SUPPORT from Thomson/ RCA, I was on my own. The extended warranty Co said to try the light engine first. I replaced the light engine with no improvement, just the led flashing. I was not going to pay 500 to 700 dollars for other boards to try to fix this piece of JUNK.I have since read several blogs that point to power supply caps as being the problem. I took this piece of junk apart for the last time before I hauled it to the dump. I pulled out the power supply on the left as you face the back of set. I noticed 2 Electrolytic caps had " domed shaped tops ,which is a good sign of failure or overheating. They are 1000 ufd @ 35Volts 105 degree rating. They were both bad along with 2 more on the same board ! They are labeled CP624 and CP647 on the bottom edge of the board inside the "c" shaped heat sink. The other two are above the chopper transformer labeled CP641 @ CP639. replacing these fixed the set. Call DigiKey 800-344-4539 part # 493-1588 are ten for $7.00. Don't spend money on a lamp you don't need. If this looks like yours, you can send it to me to have the 4 caps replaced for $48 to include labor , caps and return 48 state shipping. Call 1st 207 998 5687 John
Posted on Jan 03, 2011
  • John Dube Jan 04, 2011
    Hello; I have no access to RCA service manuals. I did find out that you have a CRT set and not the DLP I was talking about. This is my mistake. The model numbers looked similar. John
RCA model# D52W20B When I turn on the power the green power light will come on for a few seconds, go off, come on and go off again and stay off.What might be causing it to shut down? Thanks for any help. ...
yes u may have a problem with the power supply , bad capacitor on the power supply 2200uf at 25volts , thats the only cap with this value , it's right on the power supply
Dec 08, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Model d52w20b the green light comes on flashes 3 times but the tv wont come on the green power light is supoose to stay on
Replace the CP150, CP120 and CP114 capacitors. You can get the RCA repair Kit by that same name from www.tvrepairworld.com which also has the CD with instructions.
Jan 14, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
My d52w20b rca tv will not turn on and if you hold down the power buton down the led flashes a code 19
All the ITC222 series will blink 19 if they have a no start situation regardless of the problem, Since the set wont power up the Main eprm cant communicate so it blinks 19 which means it cant identify the chassis. When you press the power to turn it on does the power light come on briefly then go out 3 times? Let me know and I will assist you with the problem. Also do you hear any sounds when the power is pressed?
Nov 27, 2009 | RCA D52W19 52" Rear Projection Television
I have a RCA 52 inch HDTV model D52W20B when you press the power button the green power light flash about 3 or 4 times and that's it no sound no video. Everytime it flashes you can hear I guess the power...
On Deflection board CK capacitors cp150 2200uf 16v if it is puffed up on top it is bad their is 2 more caps in same circuit replace them also cp114 cp120 220uf 35v also resolder all pins on FBT flyback Transfomer
Nov 10, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca flashing the menu screen
a professional. Electronics go threw a self diagnostic to check for problems. it sounds like it's found one.
Jun 01, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Check the buttons on the front keyboard panel. Try cleaning them if that's no help replace the panel or the buttons.
May 25, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA Model D52W20B Serial # F074C312B Chasis ITC222 Set does not turn on the power light comes on then flashes and goes off. I need the part number in order to fix the problem
if the light flashes three times then goes out you need flyback 259296 if the light only comes on once then goes out you need the deflecion board. You can get any part you need at the following link and if your not sure leave them a email with the model number and symptom they respond quickly.
http://servicemanuals.vstore.ca/
Sep 25, 2008 | Televison & Video
Won't come on
hy i got a toshiba 42" LCD tv ,when i press the power boton
iget the red light,& it stay that way ontil i pressthe power back off
thanks for any help
Jun 26, 2008 | Toshiba 62HM95 62" HDTV
RCA D52W20 52" TV SHUTS DOWN AFTER A FEW MINUTES
this is the filment circuit having a problem. i think you will find it is a loose connection on a solder joint. Goodluck
Jan 16, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
405 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
