Question about Kyocera Fs-1300d Printer
FS-1300D 'Attention' light is on, nothing obvious like paper jammed
shawn38
  • 200 Answers
SOURCE: I have a continous red light (paper jam) on a
If you are not seeing any paper there you most likely have a bad paper detect sensor. The paper detect sensor is what looks for the proper timing of the paper moving through the machine and indicates a jam when the paper stops.
Posted on Mar 25, 2011
xptareq2000
  • 1447 Answers
SOURCE: Kyocera FS 1920 paper jam
Please install printer cartridge with drum unite properly.
Posted on Aug 24, 2009
don_farr
  • 1018 Answers
SOURCE: how do i print envelopes on a kyocera ecosys FS-1300d
Just a suggestion but in the application you are using, make sure the "Page Setup" is set to the envelope you need and the source for the envelope is correct.
Also, check the driver settings to make sure they match what the application needs.
Don
Posted on Nov 19, 2009
  • 241 Answers
SOURCE: Kyocera FS - 3900DN creases the paper
If even a very small piece of paper is in the paper path it could cause this issue. You may need to have a technician take the printer apart to see what the cause is. If you can indicate exactly where inside it may be causing the paper to crease it would indicate whether one of the rollers is causing the issue or not, you may have a roller that is needing to be replaced. If you haven't had your printer looked at by a technician in a while it may be time to get a maintenance cleaning done which would resolve your issue and also indicate if there is any major problems going on with your printer.
Posted on May 28, 2010
  • 132 Answers
SOURCE: Kyocera 1300D paper jam
Check for small piece of paper somewhere on paper path
Posted on Nov 17, 2010
My office max shredder OM99729 light says it's on but it does nothing and it has another light that says attention but nothing! ANY ideas?
it means your "Trigger" for a Jammed piece of paper is stopping it from running, sounds like something is Wedging it from turning, unplug and look into it for jammed up paper or a staple.
Jul 19, 2014 | OfficeMax Office Equipment & Supplies
Hi, i have a problem with printer paper jam. A pile of paper is stuck in the printer and i couldn't take it out manually. Please help me. Thank you.
http://www.kyoceramita.com.sg/repository/resources/fs-1100_fs-1300..._og_eng_1.2.pdf
When you go to the above link, download and open the PDF. It is a 112 page document. Go to page 83 and you will see instructions as well as pictures to assist with this. I hope this helps and best of luck.
Sep 21, 2011 | Kyocera Fs-1300d Printer
I have a paper jam i cannot find on a kyrocea fs-1300d any suggestions how to find and correct this problem?
Hi
1. Paper jammed can be found in the paper tray. Just remove all the paper and inspect paper jammed from the feeder roller.
2. Paper jammed can be found in the toner cartridge compartment. Remove the toner cartridge and inspect for paper jammed.
3. Paper jammed can also be found in the rear door of the printer (back door of the print). Check if there is a back door and inspect for a paper jammed into the roller.
4. Paper jammed can be found in the toner cartridge itself. Check for teared paper inside the toner cartridge.
Please let me know if you need more help
Mar 05, 2011 | Kyocera Fs-1300d Printer
I have a continous red light (paper jam) on a kyocera Mita fs 1000+ not obvious paper jam,..... what's wrong?
Dec 24, 2010 | Kyocera Mita FS-1020D Laser Printer
HELLO!!! How do I reset a Kyocera FS-1300d networks card to factory settings. Thank you very much. hector
Your printer comes with a software CD. Run the CD there's an option to reset the printer.
Dec 10, 2010 | Kyocera Fs-1300d Printer
Nov 17, 2010 | Office Equipment & Supplies
How do i print envelopes on a kyocera ecosys FS-1300d
Don
Nov 19, 2009 | Kyocera FS 1030D LASER 22PPM A4 PAR,USB...
Flashing Light
Hopefully just has a jam. Usually people miss them under the process unit (toner) or behind the paper tray. Pull all the way out and look. If you have really looked everywhere you probably have a sensor out of place or dirty.
from manual-- Attention - Flashing  A paper jam has occurred. The cassette is not inserted properly or the paper has run out.
also read page 22-27 in your manual for jam removal
Apr 17, 2008 | Kyocera Mita FS-1030D Laser Printer
The red attention indicator light and the toner indicator light are both flashing together
ON your driver check that the paper size is correct and this most commonly occurs when the incorrect paper size is selected. For example if you are printing to A4 and you have letter size installed in the machine then the system will cause an error or jam when there is nothing there.
Also within word or which ever program you are using on the document goto file and then down to page setup once in there check the paper size make sure it's correct for the paper in your machine also check the paper source. Once you have done this check the paper tray guides are correctly against the paper turn on and try printing and hopefully this will work.
Thanks J
Oct 27, 2006 | Kyocera Mita FS 1000 Plus Laser Printer
Kyocera Fs-1300d  Printer Logo
3,390 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
