Question about LG WM3677HW 3.7 cu.ft. Front Load Washer and Dryer
My LG Tromm washer dryer ( WM3677HW or WD-12270RD) is showing an OF (overfill) alert during the dry cycle. The wash tank will properly drain during a rinse/spin cycle. What component needs to be replaced?
  • 2 more comments
  • GORDON'S APPLIANCE SERVICE
    I'm not aware of any "OF" error code for this machine. Are you sure it isnt "OE"?
  • efm_fixya Jan 03, 2011
    The error is FE.
    It works fine except in drying mode, instead of squirting a little water in, it runs the input tap for far longer than it used to. it will drain as normal, but because it's filling for so long, eventually it fills up the tub, at which time it generates an FE.
    i thought it might be that the valve was sticking but i put a multimeter on the inputs, and it is getting voltage for an extended period.
  • efm_fixya Jan 04, 2011
    The water frequency value is working as you describe, showing different values depending on how much water is in the basin. It does indeed read the appropriate value when the tub has lots of water in it and the other when it has been drained.
    The exact thing that is happening is that everything works fine for a wash and spin cycle, but it fails during the dry cycle. it has always run the inlet for a few seconds, then after a bit run the drain for a few second, and repeated this during the drying. What has changed is that now it is running the inlet for more like 20 seconds, and the drain still for 2 seconds. After a while of this, the basin just gets more and more full until water is several inches up on the "window" in the front and it gives the FE.
    I thought maybe the inlet solenoid or valve was stuck, so I put a multimeter on it and it is definitely being told to keep the valve open for that long, it goes high and water starts flowing, and stay high, then as soon as it goes low the valve closes.
    So I'm figuring it's either the controller or a sensor that is giving the controller faulty data causing it to run the inlet for far too long, but looking at the block circuit diagram I can't imagine what it is.
    The drain pump is running normally, it's like there is a lot more water than uual flowing in during drying.
  • 283 Answers
According to the manual "water is overflowing (water level frequency is over 213). If FE is displayed, the drain pump will operate to drain the water automatically". Since there's nothing between the water inlet valves and the PWB I'd suspect that, but not before putting it into Test Mode to rule out other components and especially checking the water level detector switch
The water level detector switch monitors the water level and feeds this information to the MICOM. The sensor reads air pressure in an air chamber on
the tub. The air pressure changes in relation to the depth of the water, moving a diaphragm in the switch. As the water level fluctuates, it raises or lowers the iron center in the coil, which, in turn, changes the electric resonance of the oscillator circuit of which it is a part. As water level decreases, frequency increases. (e.g. A low water level may read 25.5kHz1 while a high water level may read 21.4 kHz. These readings are approximate; washers in the field may vary slightly from these figures.)
To read the frequency while the COMBO is running, press and hold the SPIN SPEED and SOIL LEVEL buttons. The number on the display should be divided
by 10 to obtain the frequency reading in kHz. A display of 254 would indicate a frequency of 25.4 kHz. The MICOM interprets the frequency reading as one of
eight levels, with one being the lowest water level and any level greater than eight indicating an overflow situation.
Posted on Jan 04, 2011
  • 1 more comment
    It sounds like a problem with the condensation water inlet. I'll pass this on to my collegues and see if anyone's heard of this
    I think I'm getting somewhere. "Water inlet valve is energized approx. 80% of the time during the DRY cycle • The Drain Pump is energized every 30 seconds for approx. 2-3 seconds pumping approx. 4 oz. (8 oz. every minute) • Water is used to cool duct and remove lint" You should look at the condensation tube for a buildup of lint which is why it won't drain
    The reason for checking the water frequency was to determine the proper amount of water. This design does use water during the dry process to cool the duct assembly and remove moisture from the air stream. According to the information posted earlier, water running 80% of the time during the dry cycle is normal. If, as I suspect, a buildup of lint prevents this water from draining propelry it will trigger the error you are getting
Some water goes into the machine during the dry cycle. The factory tech told us this is normal???
dear its normal.... all the machine having 02 type of dry sis terms,,,your machine is condensation dry sisterm,,,,
Jan 30, 2014 | LG WM3677HW 3.7 cu.ft. Front Load Washer...
We have a wm3677hw LG washer/dryer combo. it goes into the dry cycle and keeps adding water. what is the problem. we have cleaned all the internal tubes. checked the lower heating element and it is not...
Hello & Welcome to FixYa
If you have already tried cleaning the vent then the problem is with the Thermal fuse. When the thermal fuse goes bad it cannot be reset and replacing it is recommended repair.It is located on the blower wheel housing inside the rear panel to the exhaust duct. Please get back to me if you have any other questions.
Kevin
Jan 16, 2011 | LG WM3677HW 3.7 cu.ft. Front Load Washer...
My lg tromm DLG69885 gas dryer is not heating; otherwise it works fine. Dry light flashes cooling light stays on solid
I am using LG Tromm DLE2514 washer dryer. It 's running but didn't dried the clothes. I clean it's lint but still it's not working. The one thing i notice now is it's drying light is blinking and cooling light is turn on all the time during the cycle. So what's the problem with my dryer?
May 20, 2010 | LG DLG5932W Gas Dryer
LG TROMM WM3431HW(?) soaks clothes in Dry Cycle
LG says to unplug unit. Or remove power by tripping circuit breaker. Wait a minute and plug back in. Good luck.
Mar 25, 2017 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Washer-dryer # wm3677HW will not dry,heats up, run, on and on
You're a moron. This unit washes and dries. That's the whole point of it. Perhaps you should do some research before answering the question. the most likely cause is the water lever sensor.
Aug 09, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
I have the same problem
I had the same problem, I changed the water discharge pump and the drain problem was fixed. I still have the loud sound during the wash cycle but it does not coincide with the drum movement. I think a will pull the wash pump to check for lint buildup. people cleaning the lint trap will avoid alot of unnecessary headaches.
Jun 23, 2009 | LG WM-3677HW Front Load Washer / Dryer
LG Senseclean washer dryer combo won't dry
The problem is likely due to lint build up in the condensing unit. I found a solution here:
http://www.motusconnect.com/blog/2009/1/5/lg-washer-dryer-drama-%E2%80%93-diy-fix
I also had a softball size ball of wet, packed lint in the condensing unit. I found that the unit can be cleaned without tools or dis-assembly by:
  1. draining the water.
  2. laying the washer on it's back.
  3. removing the hose clamp on the rubber bellows that connects the drum to the condensing unit (right hand side of machine).
  4. digging the lint wads out with your fingers and a small screwdriver.
Happy drying!
Jan 15, 2009 | LG WM3677HW 3.7 cu.ft. Front Load Washer...
LG all in one washer dryer fills with water on the drying cycle
the unit is made to bring water in in the drying cycle ,,the water dont touch the clothes..the water is to take the lint away and to cool the drum,,you must remember that you can was 22 pounds but you can only dry 11 pound..so you must dry about half of what you wash..and drying the 11 pounds it will take 3 to 4 hours,,no exhaust...
Sep 21, 2008 | LG WD-3274RHD Front Load Washer / Dryer
LG WM3677HW 3.7 cu.ft. Front Load Washer and Dryer Logo
770 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
