Question about Heritage Pool & Spa
I have a Heritage spa that has a fault code of FLO on the pad and also it is not heating up.. Are these related and what is the fix... Cheers Steve
  • 264 Answers
All spa's have a circulator pump. This pump works in conjunction with your heating element. The pump automatically turns on when the heater does to circulate the newly heated water. If the pump fails, the heater will not kick on as a safety measure so you don't burn out the heating element. It sounds like your circulator pump has failed. On many spas, this may also be related to a pressure switch failure. I hope this helps. It should at least give you a place to start.
Posted on Jan 03, 2011
What does mean FLO message on the digital panel
Hi Simon,
The FLO message is a warning that your water flow is not what it needs to be. This can be harmful to your equipment, without proper water flow the heating element can over heat or your pump can run dry causing damage. Often this is can be caused by dirty filters, so your first check should be to see if your filters are clean. Other possible problems could be water levels. Make sure you have no water blockages especially on the suction end.
Jan 17, 2015 | Pool & Spa
We have a 4 person heritage spa with ozone and we have 3 lights flashing ..what could this be? Cannot find my manual
ozone not flowing could be related check recirculation pump and pressure switch and heating element
Oct 09, 2017 | Heritage Pool & Spa
Fault Low Flo Pressure
check pressure switch and copper tube to it
Nov 04, 2012 | Jandy Air Energy Heat Pump - 100,000 Btus
I have a servicecode , flo, and the temp. Will not reach the seting i have done
FLO code relates to the correct water pressure flowing through the heater tube. This is a safety procedure in adequate water flow could damage your equipment.
As this code can be one of the hardest to diagnose start by checking that all water suction & discharge slice valves are all-the-way open. If they are okay try clean or replace the filter cartridge.
If the cartridge is new or clean try temporarily run the spa with out the filter cartridge, it could possibly be preventing flow.
If the issue persists you can check that the suction fitting covers are free of debris. If the suction fittings are clear of blockages it is likely that pressure switch or flow switch (depending on your spa model) has failed.
These steps will fix a flo code the majority of the time, the pump is another potential cause but least likely.
Feb 20, 2011 | Qca Spas Majestic Series Grand Cayman Hot...
Filled artic spa 36 hours ago. not heating properly. what should I check?
If you don't have any error codes, FLO, FLC, then there is a chance your heater has burnt out. You would need an Ohm meter to measure if you have continuity thru the heater element. You should read 11 to 12 ohms. If you have either FLO or FLC on the display this indicates a problem with the pressure switch. The pressure switch is threaded into the side of the heater, the stainless steel tube attached to the #1 or main pump. Its a round module with two wires attached to it. There is an adjusting post in the center of the module. For an FLO code turn the post half a turn CCW. For an FLC code turn it half a turn CW. If this does not solve the problem replace the pressure switch.
Oct 16, 2010 | Arctic Pool & Spa
The flo, cool, and a temp of 53 but the heat indicator is not on?
Assuming that pump 1 works ok on low speed...
Try removing the filter(s) and see whether or not this clears the fault. If the fault has gone install some new filters.
Apr 15, 2010 | Qca Spas Jewel Series Topaz Plus Hot Tub
Get Flo Message frequently and sometimes FIL2 message.
FLO is related to either a dirty filter or a clogged suction to the pump or possibly a pump related fault. FIL2 is the code displayed when programming the 2nd Filtration Cycle.
Apr 01, 2010 | Qca Spas Dream Series Dream Master Hot Tub...
LF READING ON PANEL
LF means "Low Flow". Remove the filters to see if the code goes away. If not, the pressure switch may be bad.
Feb 09, 2010 | Aqua Flo 1 HP Aqua-Flo Pump: 1.5" in/out,...
Heat not firing, read-out indicates "FLO"
you may have a bad pressure switch.if you are getting flow thru the heater and this code is comeing on there are only two reasons.No flow or bad switch.
Jul 06, 2009 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Pool & Spa Logo
447 people viewed this question
Top Heritage Pool & Spa Experts
john h
Tom Chichester
David Spradling
David Spradling
Are you a Heritage Pool and Spa Expert? Answer questions, earn points and help others
