Question about Komodo Computers & Internet
Everything has a yellow tint to it. if its supposed to be blue it looks green. I have tried changing the settings several times. on rare occassions it will go back to normal but goes back to green when I restart the monitor. Is there a way to reset everything the way it is suppossed to be?
    Genius:
  • 1,288 Answers
I doubt that the monitor is on its way out, the yellow cast is indicative that either the vdu cable is damaged, or more likely, the inner circuits are failing, you may need to replace the monitor
Posted on Jan 03, 2011
Contrast really dark but seems to improve after the tv has been on several hours
Hi:
You may have a problem with the inverters in the unit, they are responsible for lighting up the back panel. Check or have checked the power supply voltage to the inverters, should be around 18-24 volts DC. Also leaky capacitors on the power supply will cause this issue as well as leaky or puffy capacitors on the inverter.
Sep 08, 2011 | LG 32LG30 32 in. LCD HDTV
Green tint
what cable are uusing coumpount vga 15 pin to coumpunt or u try new cables
Jan 24, 2008 | Dell 3200MP Multimedia Projector
Green hue/tint
Need to do the alignment feature where it refocuses the light beams. Convergance. Look through the set up. Different magnetism and shaking of the set has thrown it off most likely. Auto focus maybe what its called.
Apr 15, 2010 | Sony KDS-R50XBR1 50" HDTV
Blues' appear more green
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 05, 2010 | Philips Televison & Video
My projection tv lost its blue tint
Hi
Thanks for using FixYa. Usually this happens when the Light Engine has gone bad, and I should say this is a common issue with Projection TVs. There are three tubes/mini LCDs inside your TV- green/yellow, blue and red. When the set heats up over time of usage the screens tend to break resulting in leaking color everywhere. The cost to get this fixed by a professional should be around $300 depending on the parts that needs to be replaced. Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Feb 23, 2010 | Zenith E44W46LCD 44" Rear Projection...
My sony lcd tv looks like it is missing a color, everything is green and blue what could the problem be?
What do you mean green and blue? Are you missing red? Are you hooked up through component cables? Check the component cables.
Dec 02, 2009 | Televison & Video
Dell 2400 MP DPL Projector projects a yellow tinted image.
Clean any external dust filters or air openings in the unit.If you don't want to remove the filters, you can simply use a vacuum cleaner hose to suction away the dust from the filter element--same effect anyway. The unit probably does indeed need a thorough cleaning.
The yellow effect is most probably a burned BLUE polarizer filter located behind the blue LCD panel. (Color key--Purple onscreen=green lcd, baby blue onscreen=red lcd, and yellow onscreen=blue lcd). That's how you can tell which lcd has dust on it! Usually, the green lcd has the most free area around it and collects the most visible dust. (large purple specs) The polarizer filters can get burned due to excessive heat (not keeping proper ventilation). Of course, it might be the blue LCD panel which is failing prematurely due to heat build-up over time. The polarizer filter isn't that expensive if it can be replaced, however, the actual lcd panel IS.---Rick
Sep 07, 2009 | Dell 2300MP Multimedia Projector
Picture calibration settings for 42lg70
Picture Menu
Picture Mode: Expert1
*Backlight: 16
*Contrast: 83
*Brightness: 53
Sharpness: 50
*Color: 55
*Tint: 0
Expert Control
  • Fresh Contrast: Off
  • Noise Reduction: Medium
  • Gamma: Medium
  • Black Level: Low
  • Real Cinema: On
  • TruMotion: Low
  • Color Standard: HD (N/A w/HDMI)
  • White Balance: Warm
  • **Method: 10-Point IRE
    • 10 IRE
      • **Red: 1
      • **Green: 2
      • **Blue: -16
    • 20 IRE
      • **Red: -6
      • **Green: 0
      • **Blue: -7
    • 30 IRE
      • **Red: -5
      • **Green: 0
      • **Blue: -4
    • 40 IRE
      • **Red: -8
      • **Green: 0
      • **Blue: -4
    • 50 IRE
      • **Red: -4
      • **Green: 4
      • **Blue: -4
    • 60 IRE
      • **Red: -6
      • **Green: 6
      • **Blue: -5
    • 70 IRE
      • **Red: -8
      • **Green: 3
      • **Blue: -10
    • 80 IRE
      • **Red: -8
      • **Green: 7
      • **Blue: -16
    • 90 IRE
      • **Red: -9
      • **Green: 5
      • **Blue: -18
    • 100 IRE
      • **Red: -10
      • **Green: 4
      • **Blue: -9
Color Management System
  • Red Color: 0
  • Red Tint: 0
  • Green Color: 0
  • Green Tint: -15
  • Blue Color: 0
  • Blue Tint: 11
  • Yellow Color: 15
  • Yellow Tint: 2
  • Cyan Color: -15
  • Cyan Tint: 0
  • Magenta Color: 0
  • Magenta Tint: -1
lg70 nice tv excellent processor just to bad there is no intensity control on color management oh well still better than what the three s are pushing block out the hype lg will be number 1 in a few years haters are starting to come around and well leds coming,
p.s. i dont work for lg just tired of losers bashing stuff because they dont own it.
im isf certified those settings are right on the money straighter than a ruler
Oct 05, 2008 | Televison & Video
Picture settings
Colorimetre HCFR software
AVC HD 709 calibration disk
Spyder2 colorimeter (I know most prefer the Eye-One meters, but the Spyder2 was available from my job at no cost)
Here are the settings:
PS3 Blu-Ray player
Output Format (HDMI): Y Pb/Cb Pr/Cr (important!!! NOT RGB output)
BD 1080p 24hz Output (HDMI): On (this TV can reproduce video at 48hz for accurate 2:2 pulldown)
Y Pb/Cb Pr/Cr Super White (HDMI): On (not sure if this matters)
42LG50 Settings
Aspect Ratio: Set By Program (Personal Preference)
Picture Mode: Expert 1
Backlight: 50 (Personal Preference)
Contrast: 54
Brightness: 54
Sharpness: 40 (Personal Preference)
Color: 50
Tint: 0
Fresh Contrast: Off
Noise Reduction: Off
Gamma: Medium
Black Level: Low
Real Cinema: On
White Balance: Warm
Method: 10 Point IRE
10 (-3,8,-16)
20 (15,24,-21)
30 (20,36,-22)
40 (3,19,-40)
50 (8,34,-41)
60 (10,50,-20)
70 (-5,50,-8)
80 (-16,50,18
90 (-14,50,30)
100 (-22,38,21)
Red Color: -3
Red Tint: 0
Green Color: 10
Green Tint: 0
Blue Color: 14
Blue Tint: 0
Yellow Color: 0
Yellow Tint: 1
Cyan Color: -11
Cyan Tint: 0
Magenta Color: 0
Magenta Tint: -2
Take time to get used to the settings, you may think the screen looks dull at first. The truth is most people have way too much contrast on their TVs.
These settings will also work for Cable or Dish hookups, in which case you may change the Noise Reduction option to Medium to reduce signal noise.
OR....
2POINT IRE
Backlight: 65
Contrast: 55
Brightness: 45
Sharpness: 50
Color: 45
Tint: 0
Fresh Contrast: Off
Gamma: Medium
Black Level: Low
Real Cinema: On
White Balance: Warm
Method: 2 Point
Red Color: 3
Red Tint: 0
Green Color: 9
Green Tint: 2
Blue Color: -1
Blue Tint: 0
Yellow Color: 6
Yellow Tint: 5
Cyan Color: -1
Cyan Tint: 1
Magenta Color: 2
Magenta Tint: -1
Sep 15, 2008 | LG 42LG50 42 in. LCD HDTV
Occasional discoloring, tv randomly turns from green tint to no tint
Loose connections in CTR board ( picture tube), resolder it.
Aug 05, 2007 | Insignia NS- 27" TV27 TV
Computers & Internet Logo
153 people viewed this question
Top Komodo Computers & Internet Experts
David Payne
David Payne
Are you a Komodo Computer and Internet Expert? Answer questions, earn points and help others
