Question about NEC PlasmaSync 42VP4D 42 in. HD-Ready Television
Antenn input ? - NEC PlasmaSync 42VP4D 42 in. HD-Ready Television
Any computer geeks out there that can help me please?! I've been using my HDTV as a second screen from my laptop via a HDMI cord. The other day I had to change the resolution on my laptop. Now, I can't seem to get a picture on my TV screen! I have sound, but nothing else...I've googled, read forums...any suggestions?
Posted on Aug 23, 2012
  • 11,361 Answers
It does not have built-in Tuner, it is HD ready monitor which means it is ready for the HD signal sources. You need the tuner or cable box with HD Video output to feed this monitor.
http://www.hdtvsolutions.com/NEC-PlasmaSync_42VP4D.htm
Posted on Jan 03, 2011
Where is the antenne hookup
How to Hook Up a TV Antenna: 7 Steps (with Pictures)
www.wikihow.com > ... > TV and Home Audio > Television
wikiHowHow to Hook Up a TV Antenna. Two Parts:Picking an AntennaConnecting the AntennaQuestions and Answers. Want to ditch your cable, but still like to watch the ...
How to Connect an Over the Air TV Antenna to a Flat Screen ...
? 6:37
https://www.youtube.com/watch?v=9Pq8e57O4zk
Sep 19, 2012 - Uploaded by All About Home Electronics.com
How to watch digital channels without cable TV or satellite for FREE? ... How To BUILD The BEST HDTV ...
How to Connect an Antenna or Cable to Your HDTV - Video ...
www.dummies.com/.../how-to-connect-an-antenna-or-cable-to-your-hdt...
The first step to connect an antenna, is to find the input port on your HDTV. Look for the VHF/UHF input. It's usually on the side or in the back of your HDTV.
Jan 24, 2016 | Televison & Video
Lc45gd4u plug in blue light on steady no picture or. Sound I see the same question on earlier post any one have a answer
is an external input hooked to it ,antenns dvd player etc . the iput has to be set to what you want to receive
Feb 23, 2015 | Sharp Aquos LC-45GD4U 45 in. LCD HDTV
Comment mettre ma tv sur antenne je n'ai pas le cable?
Branche une antenne dans la prise du cable ! si tu as un t?l?viseur ATSC/QAM tu va pouvoir probablement avoir des chaines en HD
Mar 14, 2011 | Televison & Video
Geachte heer/mevrouw, Het geluid (met name zware bassen) vervormt bij de linker boxen. Kan dit liggen aan de verbinding (antenne) of aan mijn versterker?
Hallo, met behulp van een vertaler. Zet uw luidsprekers links en rechts en kijk of het probleem is met de spreker. Het is niet een probleem met uw antenne. Nadat u luidsprekers als het geluid is nog steeds vervormd op de linker luidspreker vak dan je versterker aan vervanging toe. Hoop dat dit helpt.
Jeff
Black Forest Colorado
Feb 26, 2011 | Denon AVR-3300 Receiver
Mijn nuvi 660 vind geen satelieten meer,is daar een oplossing voor desnoods met een externe antenne.
Ik heb net het zelfde probleem, volgens de verdeler weggooien en nieuw toestel kopen.
Externe antenne aangesloten en ontvangst beter dan ooit.
Nov 11, 2010 | Garmin Nuvi 660 GPS Receiver
Cadillac antenne 1976
its has a hole through the fender for the mast to come through and a brace at the motor housing to attach to the inner fender support. a threaded antenna bezel is needed to mount the mast to the fender
May 25, 2009 | 1976 Cadillac Deville
I HAVE A JVC KD-G321 CAR RADIO/CD PLAYER
I had the same problem, the cd refused and radio plays good, with JVC KD G321. I have disconnected the switches behind the radio and also disconnected the antenne (do not forget the antenne) and it played the cd again.
Jan (my english is not so good, i hope my solution is better.
Jun 11, 2008 | JVC KD-G320 CD Player
Cb radio
Hi, A couple of switches and knobs you can check (if present in your rig): 1. auto noise/noise blanker switch - try off position; 2. dynamic squelch control - lower down setting; 3. RF gain - should be at max (clockwise); and 4. Delta Tune - normally should be centered. Hope this works out for you and give you an idea where to start. Good luck and pls post again how things turn up. Kind regards.
Aug 07, 2007 | Uniden Bearcat Pro PC78XL 40-Channels Base...
NEC PlasmaSync 42VP4D 42 in. HD-Ready Television Logo
66 people viewed this question
Top NEC Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a NEC Televison and Video Expert? Answer questions, earn points and help others
