Question about Honda Garden
I'm not getting any pressure from my husky 3000psi pressure washer. Why?
4 Suggested Answers
  • 553 Answers
SOURCE: Owner's manual for Husky #HU80432 pressure washer
If you can't find it under Tech Support, Manuals & Guides on this site you could go to: http://huskypowerwasher.com/manuals_specs.php
You can also call Husky at: 1-888-550-1606 from 8:00 AM to 4:30 PM Central time.
I hope this helps.
Posted on Mar 28, 2010
Testimonial: "thanks for the info. the # that I was referred to for manuals is - 866-340-3912."
  • 5 Answers
SOURCE: John Deere 3000psi pressure washer stalling
Mine is having the same issue...I googled and found this with no answers. I'll update if I can find a cure on my own...
Have you checked your oil level?? Small engines have a cut-off switch if your oil is low...mine is topped off so this is not the solution for me..but it could possibly for you.
Posted on Sep 26, 2010
  • 35 Answers
SOURCE: what kind of oil does a husky 3000psi pressure washer use?
I don't believe that Husky (Home Depot) makes any 3000psi pressure washer that operates with a 2 Cycle motor. So.... gas only in the gas tank. Husky pumps can be from several differant manufacturers... some use no oil, some are sealed and don't recommend any attempt at oil changes, and some use Non-detergent 30w oil and some use 20-50 Full Synthetic oil. You can look up your specific model specifcations with a google search for Husky pressure washer.
Posted on Oct 21, 2012
How can i adjust the pressure
Cannot. Ensure u have a 3000psi wand.
Jan 15, 2016 | Northstar Pressure Washer 3000 PSI
Will not pump above 3000psi?
probably has a relief valve in the pump head that prevents over pressure from damaging the pump
3000 psi is extreme for a pressure washer and will remove paint from a vehicle , blow out gaskets on engines , remove cement surface , peel timber surfaces
Sep 08, 2015 | Comet TW 5050 S - Pressure Washer...
Husky power washer won't stay on after I start it
low oil pressure switch faulty or oil level low, disconnect pressure switch then try.
May 14, 2014 | Homelite For Husky - Pressure Washer Pump...
What kind of oil does a husky 3000psi pressure washer use?
Oct 21, 2012 | Garden
No pressure forgot to winterize
These aren't bad pumps but they do wear, and they cannot take idling without moving water. If you don't have a temp sensor add one to provide some flow if you idle too long. You can find parts at www.pressure-washer-parts.com
Jul 06, 2010 | Annovi Reverberi 3000psi 35gpm Pressure...
I hope this helps.
Mar 28, 2010 | Garden
Washer not working properly
the unloader is bad if not replaced it will damage the packings in the head of the pump go to the car wash an ask them were they buy there rebuild kits and parts they will now
Mar 15, 2010 | Garden
Husky 1650 PSI power washer hose got brittle and broke.
If the $$ that you Husky Dealer is asking is to tall, try a garage that make brake hoses. Take the hose with you and many times they can remove your nozzle and install it on a new piece of hose. MAKE SURE that they understand that this hose is for a pressure washer...DO NOT use just any hose...it MUST be a high pressure rated hose.
Oct 07, 2009 | Garden
What type of oil is best for the 3000psi Honda power washer?
a 30 weight nondetergent oil is recommended, available at any auto parts store.
Aug 05, 2009 | Honda Pressure Washer PSI 3000
Garden Logo
219 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
