Question about Logitech Cordless Mouse
The mouse is not as responsive as it used be. i have to move the mouse further to travel a certain distance. I changed the batteries. Does it need to be cleaned?
4 Suggested Answers
SOURCE: Mouse not working
I opened the mouse and took the batteries out and double checked their placement and even though they were in correctly the first time, the mouse started working the second time.
Thanks for your response.
Posted on Nov 12, 2008
emissionwiz
  • 75822 Answers
SOURCE: The mouse is on again/off again in response to my
the mouse itself is defeective, replace it.
Posted on Sep 28, 2009
jakirk
  • 103 Answers
SOURCE: Logitech wireless M310 Cursor is slow to respond.
try cleaning the lens over the laser
Posted on Jan 20, 2011
When i move my mouse it brings up thaings without hitting the mouse button
The most common reason for this activity is low batteries, too big a distance, or bad channel.
Try changing channels first using the button on the receiver and on the bottom of the mouse.
If that doesn't work, change the batteries in the mouse.
If that still doesn't work, try moving the mouse closer to the receiver.
One of those should FixYa.
Feb 27, 2011 | Logitech Wireless Access Duo Optical...
Bad tensioner when i am put my belt on should i trun the tensioner all the way around or is it no good im not sure if i have to wined it up or not it is way to lose it on a 94 saturn
There is a stop at both ends of the tensioners travel. It should only travel a certain distance, usually about a 1/4 turn or less. If it will spin around in a circle then your tensioner is damaged and should be replaced. You only need to move it far enough to get the belt off of the engine. Normally it will not travel much further than is needed to remove the belt.
Good luck.
Oct 16, 2009 | 1998 Saturn SL
Sensing distance problem
See if anything (piece of paper, dirt, a bread crumb, what have you) is stuck in the Sensor Hole, underside of mouse.
Clean the 4 plastic pads, Change the mouse pad.
Try reconfiguring the sensitivity of the mouse (Contro Panel, Mouse Icon)
Hope it helps
Sep 04, 2009 | Microsoft Wireless Laser Mouse 5000
Mouse pointer frozen
I would try re-syncing the mouse. If it doesn't work right away, try a reboot and then syncing the mouse. There is a little button on the bottom of the mouse that will allow you to do this.
If you need me to go further in depth i certainly will - just let me know but I would say that it's probably your problem.
Let me know if this works or not so i can try to find the correct solution if this doesn't to it for you. I'm here to help!!
Aug 15, 2009 | Interlink Mouse
Microsoft Intellimouse Explorer 2.0 Battery Problem
You say that this has been happening with a wired mouse as well?
In that case, you probably have a kind of virus/malware. Try this first:
http://housecall65.trendmicro.com/
Do a full system scan. You may have to temporarily disable/uninstall your current anti-virus if you have one already..
If not, try a system restore.
Jun 09, 2008 | Microsoft Wireless IntelliMouse Explorer
Mouse problem
You mouse may need to have the batteries changed. Try changing that batteries, if this does not work, post again and I will help you further. Have a good day!
Oct 15, 2007 | Dell Wireless Keyboard Optical Mouse w0147
Logitech MX 5000
By default this comes with rechargeable batteries but just to make sure it isn't a battery/charger problem try using new alkaline batteries. If it works then you may have a problem with the charger. If the problem definitely isn't batteries then the next candidate is transmission of the signal between the cradle and the mouse. Move the base or the mouse to within a few inches of each other. Make sure the mouse is working then start moving the mouse/cradle to its original position or further away till the problem reappears. Chances are you'll find an obstruction or a distance issue. Ordinarily these should transmit at least 3 to 5 feet away, sometimes even further. Over time I have seen a degradation of the range to the point where they have to be fairly close together to work reliably. If its still within the warranty I?d call Logitech for a repair/replacement. Let us know if you have any other questions otherwise thanks in advance for rating this post.
Apr 02, 2007 | Logitech Cordless Desktop MX 5000 Laser
Logitech Cordless Mouse Logo
18 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
