Question about General Heating & Cooling
Can a legacy heater #rnc-le30lttf be converted from lp gas to natural gas?
  • 472 Answers
Yes it will require the correct size orfice and spring in the valve something yo should be able to get from the manufacture... fairly easy to do as the orfice just unscrews and you instal the new one... the natural gas orfice will be a little smaller as it is lighter ... the spring in the valve is so that the diaphram opens and closes properly due to the different required pressure... good luck
\pleae vote.
Posted on Jan 03, 2011
Testimonial: "Thank you! We are looking for a heater for our garage in the basement and we were hoping we found one.. it will work!"
I have a dyna glo RMC 40 NGT vent less wall heater that I would like to convert to propane, I need to know which conversion kit to buy, and where. Thank you.
dyna glo natural gas heater Questions & Answers - Fixya
www.fixya.com > Forum > Tags
dyna glo ventless rmc50 ngt can this heater be changed from natural gas to propaneuse, ... Dyna Glo Natural Gas conversion to LP Gas I have a Dyna-Glo natural gas space ... Question about D-E36 Infra-Red Wall Mounted Panel Heater ... dyna glo heater model #RMC-40GT I believe on your particular model , that you ...
Parts for Dyna Glo, Thermoheat and Dyna Glo Pro Heaters
spaceheaterparts.com/category.sc?categoryId=13
Shop Dyna Glo, Thermoheat, Dura Heat, Workhorse LP and oil fired htrs ... Circuit Board 2201181 Dyna Glo & Thermoheat 150k Nat Gas Htr RMC-FA150NGDGD ... This spark plug (ignitor) is used on Dyna Glo and Thermoheat 40K btu LP.
Propane Wall Heaters - Walmart.com
www.walmart.com > ... > Heaters
WalmartDyna-Glo IR18NMDG-1 18,000 BTU Natural Gas - Infrared Vent Free Wall Heater. $170. ... Dyna-Glo 40K Liquid Propane 360-Degree Tank Top Heater. $88.00 ... Dyna-Glo Deluxe RMC-FA125DGD Portable Gas Powered Forced Air Heater.
1352062 Dyna Glo Natural Gas conversion to LP Gas
162.220.53.34/F/.../t1352062-dyna_glo_natural_gas_conversion_lp_gas
Jan 12, 2016 | Heating & Cooling
Can i convert a Rheem ECO 180DVP (LP gas unit) to a natural gas unit ?
Rheem water heaters should not be converted from propane to natural gas. The burners have been optimized for the rated gas and will not work as well after conversion. (Unlike ranges where the gas/air flow ratios can be adjusted when the burner orifices and regulator are swapped, the water heater doesn't have that option.)
I wish I had better news for you. I recommend you get a new water heater for the LNG service; it will be safer and more efficient.
Nov 10, 2014 | Rheem Tankless Hot Water Heater...
Is a 650 delta gas valve for natural gas be used with lp
no.
propane burns much hotter than natural gas, and has higher pressure
gas valve and burner and orifice must be changed to switch between natural gas and propane
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html
Most manufacturers do not support converting gas on heater.
Gene
Sep 13, 2014 | Rheem 40 Gallon FVR NATGAS Low WATER...
Change orfis in water heater
Do NOT do that.
If you put LP gas to NG heater you can cause explosion.
Contact manufacturer and see if they sell conversion kit. Most do not.
Copy following link for general overview and cautions:
http://waterheatertimer.org/pdf/Convert-Natural-Gas-water-heater-to-LP-heater.pdf
Jul 11, 2012 | Water Heaters
Want to convert lp gas to natural gas laarslite llg250
not adviseable years ago they would sell you different orfices and change the gas valve setting but too much liability involved LP runs hotter so they had smaller orfices unsafe
Mar 21, 2012 | Teledyne Laars Laars Lite 2 Pool Heater...
Converting rinnai 516tr from natural gas to lp
Try national energy they sell convestion kits It would need a gas fitter to do the work , you may need to a quote on this , they would be able to tell you if it is worth it ,its hard to tell with out looking at the heater .
Feb 24, 2012 | Rinnai Heating & Cooling
We have a dynna glo zero clearance for Natural Gas
Before you attempt to covert to lp. You need to check the flue. Black smoke is cause by incomplete combustion. So it may be now plug with black soot. Heat-exchanger may be damage Before you invest in a lp kit. Make sure it is worth it. To convert you need the main burner orifices and lp spring for gas value. Once you replace these parts you must adjust gas pressure, nat gas is measured at 3.2 - 3.5wc lp is measured 10.5 - 11.00 wc. In my honest opinion this is to dangerous for customer to attempt. Please a HVAC contractor inspect unit and install lp kit.
Nov 20, 2009 | Dyna-Glo D-E37 Wall Mounted Panel Heater
Convert Laars lite model lg125n to LP gas
i dont have a solution, but i would like to do the exact opposite. I would like to convert a lg125 from lp to natural gas. have you learned anything?
Jun 02, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Switching from natural gas to lp gas
Get in contact with the appliance manfacter, ask them for a conversion kit and if it can be done they will send you out all you need. Obviously there will be a charge.
Jun 02, 2009 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Heating & Cooling Logo
73 people viewed this question
Top General Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
Are you a General Heating and Cooling Expert? Answer questions, earn points and help others
