I have an avol television alt2602m and the light on the front of the tv is the only thing that goes on, it just flashes n flashes n flashes but the screen doesn't go on what's wrong with it?
5 Suggested Answers
  • 556 Answers
SOURCE: Mitsubishi tv model # wd-52527, lamp light flashing,no picture.
I would say so.
Posted on Aug 18, 2009
Randyincv
  • 17 Answers
SOURCE: television when turned on: light goes to green
If the Red Light Blinks twice and goes out, the TV is in Protection Mode. There are 6 voltage outputs to the lamps around the screen. If one of those outputs is missing the TV will sense that there's a problem and refuse to turn on. The predominant failure in this model are the output transformers on the Inverter board. A properly trained technician can measure the windings on each transformer and look for an open circuit, if one is found, replace that Transformer. i was given one of these sets from a friend and I replaced an output transformer ($11 w/shipping) and I now have a fully functional TV/DVD Combo. Also verify that all of the connecting cables internally are properly seated, there have been reports or the ribbon cables from the Power supply board to the main board above it not being fully inserted and it also prevented the TV from turning on. A word of caution. There are VERY High Voltages on the inverter circuit board, only persons with proper training and knowledge should attempt this repair.
Posted on Oct 31, 2009
  • 8457 Answers
SOURCE: tv powers on, then screen goes black, and a red
Power Supply is dead.Replaced the power supply will get ur power back.Tries Shopjimmy.com,Ebay.com to buy a refurbish power supply board.
Posted on Feb 15, 2010
budmrtn
  • 11361 Answers
SOURCE: Sharp LC-32D64U Liqid Crystal Television Power
It can be in safety shutdown mode due the failed DC filter caps, shorted circuits in the backlights inverter boards, main board problem. You need to do some inspection first.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
Posted on Dec 14, 2010
NEED REMOTE FOR AVOL TV
This may or may not work for you. This is a listing on ebay for an Avol t.v. Hope this helps ya. http://www.ebay.com/itm/Original-New-AVOL-TV-Remote-Control-MA303-/251595524200?hash=item3a94430868
Sep 02, 2015 | LG 42LW5700 42 in. 3D LED TV
Where can i purchase a AVOL tv remote (ARC-U1)
http://www.avukltd.uk.com/index.php?osCsid=2158210173a162a6756e86f81fb6fa3b
Nov 25, 2011 | Televison & Video
I have an AVol TV and need the Dish Network remote control codes
Hi, my name is Cheri Torres and I am with DISH Network Customer Service. I tried looking up all of our possible remote codes and I was not able to locate any codes for an AVol TV. Instead of using codes to address your DISH remote to your TV you will need to try a power scan. A power scan will normally find the code that works best for your TV for you. I will list here for you the instructions for performing a power scan. I hope you find this information useful. :)
Instructions for performing a power scan
  1. Turn the Television On.
  2. Press and hold the TV mode button until all mode lights light up red.
  3. Press and release the big red power button once.
  4. Press and release the channel Up Arrow on the remote until the television turns off.
  5. After the television turns off, press and release the pound(#) button once.
  6. Test functionality with the TV.
  7. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Sep 09, 2011 | DISH Network IR Remote Control
Avol tv. What is direct tv remote codes for programing remote to tv
Try using the brand "Hisense"....worked for my Avol.
Sep 02, 2011 | Televison & Video
I have a philips dlp 55pl9773 has one red flashing led on the front when i do a hard reset tv boots up lamps lites led goes from flashing yellow to green for about ten seconds and then back to red flashing...
MY philips tv model number 55PL9773/17 WAS TURNING OFF THE SCREEN AND LEAVING THE AUDIO ON FOR ONE MINUTE. THEN THE YELLOW LIGHT STAYED ON. THEN THE LIGHT TURNED OFF. thEN I TURNED ON WITH THE REMOTE AND THE YELLOW LIGHT TURNED ON AND A FEW SECONDS LATER CHANGED TO THE GREEN LIGHT AND THE TV TURNED ON. AFTER A FEW MINUTES, BETWEEN 10 AND 30 IT DID THE SAME THING. NOW IT IS OFF WITH A BLINKING RED LIGHT PERMANENTLY ON. TO TURN IT OFF I HAVE TO UNPLUG IT FROM THE WALL. I REPLACE THE LAMP A FEW WEEKS AGO AND IT IS FINE.
Dec 01, 2009 | Philips 55PL9773 55" Rear Projection...
My emerson tv standby light is on the power light flashes twice
Mine stayed in stanby mode and all I had to do was to switch the plug to a different outlet. The power strip it was on wasn't providing enough power. It worked fine for a month before I had a problem.
Dec 04, 2008 | Emerson EWL3706 37 in. LCD Television
Need Remote for AVOL t.v
go to www.AVL21c.com this is the company that makes the AVL Brand televisions for AAFES
Aug 17, 2008 | Sony RMT-V202 Remote Control
Avol TV remote
I own an AVOL 19in TV, I just got my comcast cable hooked up; I too was plagued by initially having to use my other remote to turn TV/volume on/off up/down. Being the code is not listed in the Comcast universal remote instructions, in the above answers someone mentioned APEX as a parent company with AVOL; I was able to use a code from the APEX codes listed in the Comcast universal remote instructions to get the controller to work with turning the TV power on/off and volume control. The code that worked for my particular TV was 10765. Try these codes for your TV to see if they work- 10748, 10879, 10767, 10890. Hope this helps.
Mar 17, 2008 | Televison & Video
Televison & Video Logo
101 people viewed this question
Top Televison & Video Experts
Electro Med Services...
