Question about Hotpoint Dryers
Hotpoint gas dryer Mod. NBXR463GBOWW ignition dial on front goes to off position when trying to start. motor will turn when dial is held; but turns off when releasing dial.
Amigaman
  • 248 Answers
SOURCE: Gas dryer is not heating up
Could be a bad set of burner coils. Does the glow come on for a bit then goes out. And after a bit does same?
Probably bad coils. If you were able to change ignitor, you can do the coils. Unplug first! The coils are the 2 black cylinder shaped devices on burner. They are held on with a bracket that has 2 phillips screws. You can probably take them to your parts house and they can ohm them out for you. Make sure to write down their position before removing them.
Posted on Nov 07, 2007
watugot
  • 290 Answers
SOURCE: GE dryer starts but..... stops
What you describe is either a failed evenheat board or a failed motor relay.
Please post the complete model number from the machine and I can help you narrow it down. There should be a wiring diagram inside the console with voltage checks also.
Thanks/Mike
Posted on Nov 25, 2007
SOURCE: Intermitten Heat up
I would like to thank the ones who responded to giving me a 'hand' in repairing my dryer. I did like you said & changed out the coils & now the dryer is working like it should.
Posted on Apr 12, 2008
  • 848 Answers
SOURCE: amana gas dryer
check the thermal fuse ........
Posted on Aug 28, 2008
  • 221 Answers
SOURCE: hotpoint gas dryer will not tumble
Try checking the belt that wrap's around the drum, sound's like it might be broken.
Posted on Apr 06, 2009
Mod 417.94052500 won't heat
Have you tried to watch or listen to see if you hear it ignite and then it goes out or does it not try to ignite at all?
If it doesn't try to ignite at all, replace the igniter with this part.
If it ignites and goes out after a few seconds, replace the flame sensor with this part.
Oct 19, 2012 | Kenmore 77632 Gas Dryer
I have a whirlpool dryer and for some reason it has quit getting hot so it's not drying my clothes. Also my dial wont turn. When I turn the dial to start a load it never moves from the begining...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jun 24, 2011 | Whirlpool Dryers
My Kenmore gas dryer mod 110.77522600 burner light when I first turn it on. After 4 mins. or so, it goes out. It will try to relight several time (igniter glows) but it never does.
This is usually the dryer coils have failed. They tend to fail as they heat up. They are inexpensive and easy to replace. Here is a video on replacing the dryer coils. If you need further help try this link for troubleshooting a gas dryer
Jan 03, 2011 | Kenmore Dryers
Kenmore gas dryer won't turn
It sounds like the belt is stretched or slipping. The belt needs to be replaced. It has been a few years, but dryer cabinets haven't changed that much.First, unplug the dryer from the electical outlet. If the lint filter slides out the top, then remove the two screws that you see in that top door. Pop the two front clips and open the top like a clamshell. You should be able to see where the belt goes around the drum. The front is held on by a couple of bolts at the top of each side. If you remove them the front will swing out, but be careful with the door switch wires. Before removing the old belt, pay attention how it goes around the motor tension pulleys. Slide the old belt off and slide the new one on. Reassemble. I hope this helps
Mar 28, 2010 | Kenmore Dryers
Dryer gas ignites Runs for up to 5 minutes flame goes out
check the igniter to make sure it is glowing white and not orange. if it's orange replace it. you may also need the gas coils replaced.
Oct 16, 2009 | Hotpoint Dryers
Gas dryer mod.# MDG6000BWW, Igniter lights but no flame
Replace the flame sensor on the side of the heat canister. You may also have to replace the gas valve coils.
Aug 27, 2009 | Dryers
Kenmore gas dryer will not start model 110 72972109
check your motor relay under your control panel
Dec 23, 2008 | Kenmore 62802 Electric Dryer
Fridgidaire Gas Dryer - Mod.#FDG 546 RBS 0 Press start button just a humming noise, drum doesn't turn. Tried rotating the drum manually and it turns only with great effort so I don't think is't a belt. 12+...
Your glides are brobably broken and missing. This will make the drum hard to turn and bind the motor. Get the front off the dryer:
7411f19.jpgStart by popping the top with a putty knife.
Get the screws out that hold the front on and take a look:
Dec 16, 2008 | Frigidaire GLGR341AS Gas Dryer
Nov 06, 2007 | Hotpoint NVL333GY Gas Dryer
Dryers Logo
88 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
