Question about Pioneer CDJ-100 Turntable
Hi there, I have got a CDJ 100s. Some days ago as I turned it on, I got an error message E-9103. I inserted the disk and then got E-7201. I read some posts from fixya and tried most of the solutions such as open the cdj to check if there was something unplugged or disconnected or even stucked and also cleaned up the cds. After all those actions, I open the CDJ again and checked everything once more. I found nothing. Now it is an awkward situation: there is no more error messages, the CD keeps spinning but it seems not to be reading its TOC or something. I insert a 10 tracks CD and I can go forward from #1 to #10 then it comes to #1, so I suppose it reads the tracks number but nothing else. It doesn't load any tracks length and after 10 seconds (sort of) it goes to track #0, CD keeps spinning inside the CDJ and no music at all. Is there any problem with its optical lens or so? Thanks in advance. Cheers. Jorge
    Problem Solver:
  • 44 Answers
Have you got an manual for it if so look up the error message and see what it says E-9103 and E-7201 it will tell you what to do
Posted on Jan 03, 2011
CDJ-1000 CD Player: SIR I HAVE 100S POINEER WHN I RUN CD I FACE ERROR ...
hi there,
you need to clean compartment of your cdj. Pls make sure if you can do it yourself then do it yourself or take it to an expert.
djajay
May 05, 2010 | Pioneer CDJ-1000 CD Player
CDJ 100s present error code 8503 any ideias? Error is not listed anywhere!
I Believe Ive came across this error before and i believe it means that the cd player is completely ruined you should try Getting a new one its very old!!!!
Feb 02, 2010 | Pioneer CDJ-100S CD Player
CDJ 100 s PROBLEM E-9103 and E-7201
E-9103 is MECHANICAL TIME OUT,
Solution : some object in compartment slot, remove it, or clean player compartment
E-7201 is disc cant be read in 20 seconds,
Solution : Disc has scratch, Replace disc
Disc is dirty, Clean disc
Dj ajay
djajay@inbox.com
Feb 03, 2009 | Pioneer CDJ-100S CD Player
Error message E-7201 for CDJ-1000mk3
sounds like a cd slot or laser pick-up fault, if you havent had it repaired you can send it to us.
Regards.
http://www.audiovisualservices.info/
Nov 12, 2008 | Pioneer CDJ-1000 CD Player
Pioneer CDJ-500S error 9103.
9103 error is a traverse assembly issue. Unfortunately, there is no easy fix for this. You will have to take it to a service center for repair. They will in turn replace the Traverse assembly, or find out why it's giving this error. If the traverse assembly is replaced, they will also have to calibrate the unit according to Pioneer specs.
- Davis
Digital Analog Therapy
www.repairnyc.com
Jul 15, 2008 | Pioneer Audio Players & Recorders
Cdj-700s
Hi Je remy
I have a 700s too, it´s showing problems similar to yours. Mine is even worst, it almost doesn´t play no more (shows "NO DISC"). Sometimes, when i turn it off and on, or open the cover, it reads... When pause is pressed, it holds the music for some seconds, then it "slides" thru the music... Sometimes it display an error message (something like E-8something).
I think all these errors are caused by a worn optic reader, but i´m not sure. I´ve already opened my unit and cleaned the lens, but no bail.
Here in Brazil a new optic reader can be found for R$150 (around U$90). I´ve just found out the same unit in UK for 150 pounds, so i´m suspicius that those units sold here aren´t really new... I´m planning to replace mine, but first i must be sure that the problem is really caused by the reader.
I don´t know if u have already opened yours, but it´s pretty simple to replace the unit, just some screws to loose (12, if i´m not mistaken - 4 ouside, 4 holding the lens protective cover, and 4 holding two inox sticks where the reader slides over). 700s´ units are Part No DWY1067, and you probably won´t find those anymore. You´ll only find the DWY1069, originally found in CDJ-100s (technically almost same, but probably some newer technology), but they´re totally interchangeable.
Hope could be of some use.
If u want, can contact me at nandoseiji@hotmail.com
This is the unit seller here in Brazil:
http://www.quebarato.com.br/classificados/unidade-otica-optica-leitor-para-do-cdj100-cdj-100-cdj-100s-cdj100s-cdj-500s-cdj-700s-dwy-1069-dwy1069__181502.html
http://www.eletronicamaster.com.br/produtos.asp?produto=3991
Mar 28, 2008 | Pioneer CDJ-700S Turntable
CD keep ejecting when inserted
99% laser module is faulty.
if u try to push your cd and it returning it or your cd stuck inside and it stating no disk, find a new laser and replace it.
regards
Mar 18, 2008 | Pioneer CDJ-100S CD Player
Pioneer CDJ-100 Turntable Logo
350 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
