Question about Mitsubishi WD-52327 52" Rear Projection HDTV-Ready Television
Bulb went out for the 2nd time in less than a year on Mitsubishi WD52327. Also making a loud grinding noise. What is my problem?
  • 441 Answers
The grinding noise is from the cooling fan that cools the bulb. It needs to cleaned or replaced. You will need to take the back cover off the set to get at it. If the cooling fan is not doing its job that would cause the short bulb life and the noise
Posted on Jan 03, 2011
2008 Mitsubishi lancer radio from loud squealing noise
What is causing that irritating noise? ' DSMtuners
www.dsmtuners.com > ... > Articles: Miscellaneous
Jun 1, 2009 - 2 posts - ‎1 author Check the ECU power relay in the console, under the radio. ... You hear a loud clicking type noise from under the hood when you try to start the car. .... You hear a squealing, grinding, or rubbing noise in the lower timing belt .... The Mitsubishi Eclipse, Eagle Talon, Plymouth Laser, Mitsubishi Galant VR-4, ... LOUD squeak when turning steering wheel (Video Inside)
Mar 5, 2011
Why does my alternator belt squeal so much on initial ...
May 14, 2010
More results from www.dsmtuners.com
Lancer Troubleshooting [Archive] - evolutionm.net
www.evolutionm.net/forums/mitsubishi-evolution-forums/f-203.html
NEED RADIO HELP! ... Help not start Lancer GT 2012 EngineOverheating STOP SAFELY warning on ... AC ISSUES 2011 Mitsubishi Lancer ES · 2008 Lancer GTS no start please ... 2011 lancer no sound · Driver/Passenger side floor squeaky? ... plastic piece of rear shelf rattles a lot · Very loud noise on Lancer ES 2008 ...
Dec 03, 2015 | 2008 Mitsubishi Lancer GTS CVT Sedan
Did you resolve your dryer / noise?
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
7687t
Apr 14, 2009 | LG DLG5932W Gas Dryer
TV making loud humming noise
Sounds like u need a color wheel
Apr 06, 2009 | Televison & Video
Replaced bulb and now no picture and a loud humming sound
replaced the light engine. yhis set is probably not cost affective to fix.
Apr 03, 2009 | Mitsubishi WD-52327 52" Rear Projection...
Dishwasher making loud noise
Newer washers are designed with a food grinder inside to help grind up large pieces of food. What you are hearing is the grinder doing its job. You do not need to worry about the noise. It should go away after a while as the food particle is ground up.
Jan 10, 2009 | Amana 24 in. ADB2500AW Built-in Dishwasher
Maytag washer cleans poorly & has been making loud sqeeking noise
The drive Belt is loose adjust it's tension or change with new one.
Jan 09, 2018 | Maytag SAV3655A Top Load Washer
Installed new bulb and now there is a loud whirring noise and multi colored flashing on screen
Sounds like the same problem I had, I bought a new bulb as well, installed it and nothing. I googled that same issue and endedup buying a kit herehttp://servicemanuals.vstore.ca/product_info.php/pName/mitsubishi-v26-dlp-power-pwb-repair-kit/cName/repair-kits/osCsid/145ffde26a9336eaf57c21ff6389def7that came with capacitors that had to be replace, the kit comes with aservice manual and a bag with lots of different capacitors to replaceany out on your board, they are really good at troubleshooting and theyoffer help online. If that is whats wrong with you, you will need asoldering tool, I bought my as a kit at radio shack for $20.00 and plusthe $36.00 for the kit, and a lot of patience, my TV is well andrunning now, it was better than the $600.00 estimate I got from a localrepair shop. Good luck!
Sep 06, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52327 52" Rear Projection HDTV-Ready Television Logo
265 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
