Question about Panasonic KV-S7065C Flatbed Scanner
The lamp is dead. I cannot find a replacement for under $1200.00 Can this be true?
    Sergeant:
    Champion:
  • 217 Answers
It's not just the lamp they're selling, it's the whole lamp fitment.
Cheaper to buy new, I guess.
Posted on Jan 03, 2011
I have a Suzuki 2007 xl7 and the information center is not working, could it be the body control module causing this
post 3 and still not one photo or word,as to what information is missing?
and then 3 ,posts
My Cluster DIC is dead. is true name.
driver info center display.
does not working mean DEAD
as this display shows 100s of data.
the operators guide on this,seems endless......
so DEAD is clear.more clear
is it dead,with head lamps on>?
why not check fuses first
then scan it,2nd.
say this
why x,y.z are dead
"speedo, fuel, radio, nav, data, or waring lamps dead or, or or
we cant guess what you can not see!
see?
im reading the book on your are saying
the DIC is dead.?
driver information center=DIC
it clearly states "instrument cluster"
if that is totally dead (vast data there possible)
it can be.
1; fuse blown to it.
2:it;s bad
3: communication to it lost, network issues.
it is a pure,data display
as all such devices need this. to function.
1; power
2:good data.
not scanning it now, is hopeless.
OBD2 scan tool , any. use it ,scan it and win.
does this display glow if head lamps are turned on.?
Feb 20, 2017 | 2007 Suzuki XL-7
Why would my cold temperature light come on during driving on 2003 suziki aerio
what lamp?
what does the operators guide tell you about that lamp?
sure it says get it serviced,but what are the words there.>?
it will say more... im sure.
google shows.
and also informed me that the blue light is that is is under normal operating temp. The red light that can appear next to it that looks like an antifreeze light is an overheating indicator.
so if that is true. im not spending 4 bucks to RTM
but that means the engine is not reaching proper temp.
1: air is near the ECT sensor meaning that you never really burped out all the air in the block, you skipped major steps.
2:missing themostat or again, air below it.
3: thermostat upside down,
4: theremostat not with air bleed hole,.up hill. cause, 1,2, above
5: not RTM , read the FSM. it tells all proper steps.
go out to dead cold car, is the rad full, look in actual rad.
the filler neck, i bet not full. due to skipping steps on burp.
Aug 18, 2014 | 2003 Suzuki Aerio
Change headlight assembly
is the lamp bad or or the whole assembly.
but varies by country.
http://www.scantool.net/software/alldata-diy-1-month-subscription.html
generic? the whole deal.
1: gain access to back and remove screws there. (even under fender)
2: on some cars the front nose of car bezel must be removed
gaining true access to lamp housings, and the screws.
disconnect the socket wire (or replace bulb now)
and then the housing screws. bingo its free.
some cars, the hood opens
and there is a plate that extends L/R across front of car.
remove top plate and bingo , lamps.
Jun 09, 2013 | 2002 Suzuki Esteem
I have some dark shadow on the right side of the TV screen, I think it could be the lamp, is that true?
No,colors misalignment,shodows pictures and 3D pictures are not cause by the projection lamp.It cause by the tv convergence board have 2 STK convergence ICS and some or all it resistors are dead.The shop will cost u $300-350 for the parts and labors.
Jul 07, 2010 | Zenith D52WLCD 52" Rear Projection...
My 62 inch dlp tv came on and was working then with out any noise or notice the picture went to black and a steady red light came on under the word "lamp". We looked at the bulb and it does not look burned...
The tv lamp was replaced when? The tv on about 4 or 5 hours a day right?The lamp was replaced about a year or a year an a half ago?The projection lamp is dead,the life span is over.Must replaced with a new lamp.
Jul 01, 2010 | Mitsubishi WD-62525 62" Rear Projection...
The tv went dark and no audio and the lamp light started flashing red. I have the Sone extented warranty, but they said it was a lamp and not covered
There are no lamp,in LCD tv,only Liquid Crystals amitting lights Display in a form of two pcbs.These LCD crystals are not the prob.The main video backlight board is dead,that why u not getting video.
Oct 18, 2009 | Sony KDF-E55A20 55 in. LCD Television
I have a green dot on my screen of my JVC HD52G887
Hello. If it resembles a tiny bright green dot, this is most probably a dead pixel. In the troubleshooting guide in the user manual, the manufacturer states that some pixel loss is normal--either they will be gone or permanently "on". If the unit is new(i.e. still under some warranty) talk with the supplier about options--they *may* decide to replace it if the dot is in a particularly annoying location. Be aware though, they won't be under obligation to do so. I own a LCD projector with a few visible pixels--as devices such as these(lcd tv's, projectors, plasma, etc.) age, this type of phenomenon is going to occur. Normally--and this certainly isn't always true, there is a tolerance of 3-9 pixels. Check with the supplier and/or manufacturer for individual specs. Especially if the unit is under warranty!--Hope I successfully assisted you.---Rick
Jun 24, 2009 | JVC TS-CL110UAA Projector Lamp
Newlamp went out in 20 days. lamp light blinks. is lamp dead now?
Biggest problem with DLP tv's is they get dirty (the usually have two or more fans...one in the back w/filter and one under the lamp). If air-flow is restricted the life of the lamp is in jeopardy. Verify air flow & clean filter(s). Replace lamp with exact P/N..not those that say they "are equivalent"...they are not. Also, be sure the lamp lens is very clean.
Apr 02, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Help!!
when this happened on our unit (it was still under warranty) replacing the lamp fixed the problem. a new lamp unit seems to run about $250 on the web and is easy to replace from front of unit.
Apr 19, 2008 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic KV-S7065C Flatbed Scanner Logo
121 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
