Question about Frigidaire FAP094P1 Portable Air Conditioner
I am sorry, but I have to ask if there is indeed any water in the tank or are you getting a "tank full" reading when it's completely empty?
Why ismy Essick humidifier registering over 20 on the humidity level. I have changed the filters several times using high end filters?? I also have wet the filters
Sorry to ask, for clarification is this a dehumidifier or a humidifier? Do you want to add water to your air or take water out of your air. A reading of 20 for a humidifier sounds pretty good to me. I didn't know there were filters on a humidifier, I thought most of the time you just filled the tank with distilled water, it got heated and vapor came out. I guess a filter to keep airborne bacteria from floating into the water tank would make some sense, maybe a water filter to pre-filter the water going into your humidifier, but I don't think any filter is your problem. If you are trying to remove water from your air, then a dehumidifier is needed and you just have to empty the tank when it's full.
Feb 19, 2015 | Essick Air Humidifiers
How do you drain holding tanks 1 and 2 on a trail runner 39qbbh
Are you asking because monitor panel says full still? Not uncommon for paper or other debris to hang on probes inside tank and cause panel to read improperly. Close valve, add some water and then pull valve and listen for flow. If that water flows through ok, your likely empty.
Jan 05, 2015 | Heartland 2013 Trail Runner TR 39 QBBH
Water tank says empty but it is full
Do you have a tank heater on the tank? If not, you may want to get one to prevent the tank from freezing and busting. Next, there is a small diode inline and it may have failed which will give a false reading.
Jan 08, 2014 | Forest River 2013 Flagstaff Classic Super...
Car of year 1998, when tank is full or medium from fuel, guage shows empty. When tank is completely empty, the guage shows full. Guage is of digital type with the bars. What can I do ? Any tests I...
Digital gauge also gets its input for fuel level from a float in the tank. Here the culprit can be that float because the error is systematic i.e., full on empty and empty on full/half. If the reading was erratic then it was something to do with IC in the bars display panel.
Aug 15, 2011 | Toyota Yaris Cars & Trucks
Display on Saeco Magic Comfort+ says "Fill Watertank" even when tank is full. Removing and resetting does not help.
Hi
This is usually a magnet in the water tank or sensor inside the machine. First do you have the grey magnet in the water tank? If no magnet in the tank, that is the problem. The magnet floats when the tank is full and sinks when its empty. It sends a flux signal to the sensor inside the machine. If the sensor is bad inside it doesn't pick up the flux field and you get the "water tank empty" display.
May 23, 2011 | Saeco Magic Comfort Plus Espresso Machine
LX-140 SOLEUS A/C DUMPED WATER ALL OVER MY WOODEN FLOOR........THE TANK ALWAYS GETS EMPTIED AND CONVINCED THAT THE WATER IS COMING FROM THE BOTTOM OF THE UNIT, I TURNED IT OVER AND WATER CAME POURING OUT...
I would recommend that you manually fill the tank so you can watch it and see when it is completly full. If tank full sensor does not work then I would replace it. I think it is probably bad as it should not only tell you the tank is full it should also shut it off. Thank you.
Apr 29, 2011 | Soleus KY-34 Portable Air Conditioner
It says to add water and it is full of water
Sorry to read about your problem, I hope this helps you out.
just try and reseat tank plus this
Sorry to read about your issue.
The brewer should be de-scaled at least every 3-6 months. Scale is harmless, but if left unattended, it can hinder optimal brewer performance. De-scaling your brewer regularly helps maintain the heating element, removable water reservoir and other parts of the brewer that come in contact with water. Better water quality and water heating means a better cup of coffee, tea, hot cocoa or iced beverage. We recommend de-scaling your brewer at least every 6 months (every 3 months if your water has a high mineral content). The de-scaling process involves using 48 ounces of undiluted white vinegar.
Take 48 oz of white vinegar. place in tank. pretend you are making coffee (Do No Use K Cup). let the water fill you mug. then empty that mug. Do it again until tank is empty. then let sit for 4 hours.
Then fill with fresh water to the top. let that tank of water run thru. towards the end taste the water.
If you taste vinegar..use more clean water, until the taste is ok.
I tried to help you. Please help me and Vote/Rate this response. Thanks and good luck
Dec 17, 2010 | Keurig B60 Coffee Maker
My gas guage stays on empty and the tank is full
Sounds like your senor in the gas tank it self is bad. Most cars have a float that read out how full the tank is and when it goes out it will stay stuck showing you on the dash that your tank is empty even though it is full.
Nov 03, 2010 | 2000 Buick LeSabre
Frigidaire FAP094P1 Portable Air Conditioner Logo
21 people viewed this question
Top Frigidaire Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
