Question about Ovens
Remove oven door on kitchen aid gas stove for cleaning
  • 552 Answers
Click on the link below to watch a video that explains how to remove the door on most modern ranges.
http://www.appliancerepairlesson.com/2011/01/22/oven-door_diy-oven-repair-help-101/
Posted on Mar 06, 2011
    Problem Solver:
  • 15 Answers
Usually the doors just lift off.
Keep your fingers away from the hinge region as they can release and whack your fingers
Posted on Jan 04, 2011
We a kitchen aid oven the door was accidentally lock. Can you find out how to open it? Whirlpool owns kitchen aid
  • Look for a manual lever to unlock the oven. If there is one, it will probably swing back and forth horizontally, just below the upper edge of the oven door
  • Swing the locking lever, if one is present, all the way to the left. This should unlock the oven. If there is no manual lever to unlock the oven, it may be unlocked using push-button controls.
  • 3
    Check to see if the oven is in a self-cleaning cycle, or has just completed a self-cleaning cycle. If so, the door will unlock automatically once the oven has finished the cleaning cycle and cooled completely, which may take several hours. You cannot unlock the oven before it has cooled.
  • 4
    Unlock the "Clean/Off" button. Depending on the brand and model of your oven, the button may display both of these designations or just one. If your oven door is locked, but the oven is not warm and is not in a cleaning cycle, unlock it by pressing and holding the "Clean/Off" button.
  • Nov 18, 2012 | Ovens
    Tip
    Kitchen Aid Oven / Stove Fault Codes
    If your Kitchen Aid Oven is showing fault codes starting with F, the problems and solutions can be found at the following website.
    CLICK HERE
    on Feb 26, 2011 | Ovens
    My daughter-in-law just moved in to a newer home with a stainless steel Kitchen Aid ceramic top stove. It has a warming oven, a convect feature etc. However, with options etc. it is very confusing to...
    Kitchen Aid manuals are available from their support site: http://shared.whirlpoolcorp.com/product_literature/search.jsp?siteCd=KAD . The model number is needed to locate the manual. For ranges, the plaque with the model number is inside the oven door.
    The KitchenAid ovens that I know will turn off when you press Off (unless the control lock is on - then you need to disable the control lock). The Warming Drawer will have a separate Off button. Dual oven units require you to select which oven and then press off.
    See http://www.kitchenaid.com/assets/pdfs/product/ZUSECARE/KESS907XSP_Use%20and%20Care_EN.pdf for a similar range. (ceramic glass cooktop, convection feature and warming drawer)
    I hope this helps.
    Jul 02, 2011 | KitchenAid Ovens
    How to remove door on stoves EL716 toop oven
    I can only say for the 720. You have to remove the whole oven from the kitchen furniture and then unscrew/remove the top and side panels. You will then see the springs on either side of the door.
    Important. Remove the inner glass panel from the door first, before you release the springs.
    To remove the springs, ensure the door is closed and then unhook them. You then should be able to remove the door frame.
    May 07, 2010 | Stoves 720EF Electric Double Oven
    Dhow do i remove stoves efa600H oven door hinges?
    1. Open the oven door and remove the 2 screws at the side of the inner glass window 11cm above the hinges and lift off the door. Place it somewhere safe!
    2. Remove the 4 screws that you can see nearest to the left and right edges of the oven with the door removed. These secure the oven to the kitchen unit.
    3. Slide the oven forwards about 20cm out of the unit, being careful not to pull on the cable.
    4. Each hinge is held in place by 2 screws at the side of the unit now exposed, about 18cm apart. Remove them and slide out the hinges. Reassembly is the reverse of the above.
    5. Note that the hinges have no means of adjustment. If not working properly, renew them.
    Nov 20, 2009 | Stoves Premier 600EMa Electric Single Oven
    How do I remove the built in oven to replace the
    there are no internal fuses, chk your houses main power panel and stove plug to make sure you have 240 volts for proper unit operation
    Nov 03, 2009 | KitchenAid KEBC107 Electric Single Oven
    Stoves 900GDO Bottom oven door seal
    You will probably have to replace the oven door hinges.
    This should solve the problem
    Dec 02, 2008 | Stoves 720EF Electric Double Oven
    KITCHEN AID KEBC107KSS03 DOOR. REMOVE INNER PANEL. CLEAN GLASS
    LOOK WHERE THE HINGE METS THE OVEN DOOR FACING..you will see on the hinge a tab with the door open pull these forward this will lock the hinges do this on both sides then closed the door slightly and lift up the door will come off then you can unscrew the bottom scres to access glass
    Feb 22, 2008 | KitchenAid Architect Series KEBC107KSS...
    Ovens Logo
    115 people viewed this question
    Top Ovens Experts
    Dan Webster
    Dan Webster
    ashburton
    Are you an Oven Expert? Answer questions, earn points and help others
