Question about LG Televison & Video
I do not know how to set the sleep timer without having to go through too many steps. Do not want it repeated every night
  • 39 Answers
Hi there
Do you have the model number of your LG TV? Sometimes they have programing functions in the timer menu. There you can programme it to do exactly as you want.
Hope this helps
TV_Doctor
Posted on Jan 03, 2011
How do i change sleep mode
Sleep Timer Mode
The Sleep Timer mode is an energy-saving feature that enables you to set a time for the monitor to
power on and off at the same time every day. This also extends the life of the backlight bulbs in the
monitor. The Sleep Timer has five settings:
? Set Current Time
? Set Sleep Time
? Set On Time
? Timer: On/Off
? Sleep Now
To set the timer:
1. Press the Menu button on the monitor front panel to display the OSD Menu.
2. Scroll down and highlight Management.
3. Press the OK button to select Management.
4. Scroll down and highlight and select Sleep Timer > Set Current Time.
NOTE: You must set the current local time before you reset the time for Sleep Time or On Time. Note that the time is displayed in a 24-hour clock format. For example, 1:15 p.m. is displayed as 13 hours 15 minutes. A power failure or loss of power to the monitor will cause the timer to reset to 00:00. If this occurs, you will need to reset the sleep timer mode.
5. Press the OK button once to enter the adjustment mode for hours.
6. Press the - (Minus) or + (Plus) button to adjust the hour.
7. Press the OK button again to enter the time for minutes.
8. Press the - (Minus) or + (Plus) button to adjust the minutes.
9. Press the OK button to lock in the time chosen.
10. After setting the current time, the highlight automatically skips to Set Sleep Time. Repeat steps 6 through 9 to set Sleep Time.
11. If you do not want to set Sleep Time, press the OK button twice, then select Save and Return to exit the menu.
12. After setting Sleep Time, the highlight automatically skips to Set On Time. Repeat steps 6 through 9 to set On Time.
13. Set the Timer mode to On to activate the Sleep Timer settings.
14. When you are finished, select Save and Return to exit the menu.
The fifth selection, Sleep Now, turns the monitor backlights off immediately and stays in sleep mode
until the next On Time activates or a monitor button is pressed.
May 27, 2014 | HP Pavilion 22bw Black 21.5" LED Monitor...
How do I set the sleep timer? We got the tv from a friend and it had no manuel.
Programming the Sleep Timer:
  1. Press and release the TV key.
  2. Press and hold the SLEEP key for three seconds. The illuminated component name turns on.
  3. Release the SLEEP key.
  4. Using the number keys, enter the desired time in minutes (from 1-99 minutes). To set the timer to an umber under 10 minutes, first press 0 and then the desired number (e.g.,05 for five minutes). The illuminated component name blinks with each key press.
  5. Once the second number is entered,the illuminated component name turns off.
    Tip Any key press other than the number keys is ignored. If you don't enter the sleep time within 10 seconds after pressing the SLEEP key, you must start over at step 1. The illuminated component name blinks four times and then turns off, indicating your attempt to program the Sleep Timer has been unsuccessful.
  6. The Sleep Timer is now set.
  7. Leave remote aimed at the TV. Once the Sleep Timer is set, you can continue to use the remote without affecting the Sleep Timer. However, because the timing mechanism for the Sleep Timer is built into the remote itself, the remote must be in TV Mode and pointed at the TV to activate the Sleep Timer.
    Note: If the ON·OFF key is pressed, the Sleep Timer is canceled.
Aug 19, 2011 | RCA Rcr461 Remote Control
My tv keeps turning on by its self. At night I use the sleep timer a lot, but I do not know if that's why it turns on randomly?
Yes,tv it will turn on and off randomly,if sleeper timer mode is on,u probally setup for both OFF and ON setting same times like 30,60,120 mins setting is on.
Aug 07, 2011 | Quasar VV-1311W 13 in. Combo
How do i set the timer? i use it for my alarm.
Which timer do you want to use? To use the On/Off Timer, press Menu and use the navigation arrows to select Time. Press Enter and navigate (up/down arrows) to select either On Time or Off Time. Press Enter and then use the up/dwon arrows to select Repeat. Select the frequency for the timer function (off, once, everyday etc.) with the left/right arrows. Use both the up/down and left/right arrows to set the time (hour or minute). Press Return to return to the previous menu and Menu to leave the OSD menus. For the On Time, you can also select the input source that will be shown when the TV comes on. (Select Input similarly to the above directions and set the desired channel if the source is TV.) The time must be for this to work (select Time and then Clock then Auto (gets the time from a digital channel) or Manual) and the TV must be in Standby mode for the On Timer to work. The TV will go into standby in two hours after coming on unless a button is pressed on the remote or the TV. The Off timer will override the TV On if they are set for the same time.
The Sleep timer is set in the same Time area or in the Q.menu (from the remote). Select Sleep time and then the length of time you want the tv to stay on before going to sleep. This is reset when the TV goes off.
The Shut-off time is set in the Time menu as well; select Auto Sleep. When this is on (on/off options), the TV will shut off after 10 minutes without a signal.
I hope this helps.
(you will have to reset the timer after a power failure)
Oct 06, 2010 | LG 32LG30 32 in. LCD HDTV
Can't set sleep timer on my mitsubishi cs-40505 tv. I do not have the original remote. How can I set the sleep timer?
U can't do it without the original remote.Go in the tv menu by the manual button control might could set the sleep timer.This is a extra option on most tvs.
Jun 07, 2010 | Mitsubishi CS-40505 TV
Lock-up during the over nigh
you may perform flash memory clear. it is located at F9-06.
perform this after you copied/backup all necessary settings.
Feb 26, 2010 | Panasonic DP-C263 Copier
Standby light is flashing 10 tims Model KV-HR36
Try unpluging your T.V. for 5hours+, then turn it back on. Worked for It's called a "hard reset" by sony.
Otherwise
Do the following steps
  1. Check the Sony remote for a button labeled "Sleep." This allows you to cycle through the sleep settings and determine how long you want the TV to remain on.
  2. Step 2 Press the "Sleep" button. You'll see a number come up onscreen: usually 15 or 90. When you press it again the number changes, moving up and down in increments of 15. This is the number of minutes the TV will remain on before it goes to sleep. As you cycle through it, you should see a setting with the words "Sleep Off" appear onscreen. If you leave it there, the sleep setting should cancel, allowing you to turn the set off when you like. If you miss it, just keep pushing the "Sleep" button. It will continue to cycle through the options until "Sleep Off" appears once again.
  3. Step 3 Access the timer function to shut off the timer by pressing the "Menu" button, then cycling through the onscreen options until you reach the "Applications" setting. Press it, and then cycle through to the "Clock/Timers" option.
  4. Step 4 Highlight the "Timer 1" setting and press the "+" button. If it's showing a given time, you'll need to deactivate it. Use the up and down arrows and move through the possible options until you come to the "Off" setting. Leave it there; that should shut the timer off.
  5. Step 5 Repeat the process with the "Timer 2" setting, a little further down the "Clock/Timers" menu. Set it to the "Off" position just as you did with the "Timer 1" setting.
  6. Step 6 Press the "Menu" button when you are done to exit the menu and return to the screen. You should be able to view the Sony TV as normal with no danger of it turning off.
good luck
Aug 08, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sleep Timer on remote does not work
First try to access the sleep timer menu from the controls on the TV to verify the TV is working.
If that works then the remote has the problem.
Now try this;
Step 1- Pull the batteries out of the remote and leave them out until Step 4.
Step 2- Press and release each and every button one at a time on the remote control until every button has been pressed and released at least once!
Step 3- If your remote has slide switches, you must move the switch to each position then repeat the button pushing in Step 2.
(When you're done, be sure to put the slide switch in the correct position to operate the unit the remote came with!)
Step 4- Put the batteries back into the remote, being very careful to install them correctly.
New batteries should be used if you're not sure about the old ones.
If this does not work, then you may need a new remote unit.
Mar 10, 2009 | Olevia LT37HVS 37 in. LCD HDTV
RCA 32V432T
FIRST THING TO TRY IS RESET-unplug AC cord for a few minutes,hours or overnight==let me know if you need more help.T.
Aug 04, 2007 | RCA 32V420T 32" TV
Televison & Video Logo
35 people viewed this question
Computer Repairing
Computer Repairing
