Question about Dishwashers
The dishwasher isnt getting water in to it. what could be the problem?
  • 472 Answers
Could be a few things.. first and most obvious has anyone shut water off under sink make sure that is still on... i am sure you have already done that so the next step would be remove the bottom kick plate and you will find on this model i believe the weater valve is on the left front side... remove the plastic plug from the water valve and put a meter lead in each of the two sockets then turn your unit on normal wash and see if you are getting 120 volts ac current if you are and when you plug back up then you have a bad water valve solenoid and are going to need a new one.. if you are not then most likely the problem is coming from the tier device or the control on the unit... hopw this helps repost with aymore problems.... please vote......
Posted on Jan 03, 2011
My zanussi dishwasher isnt bringing in water and there are no blockages that i can find and my water pipe isnt blocked what else could this be
Here is a tip that will help you to find out why water will not come into thedishwasher...
Dishwasher Trouble No Water entering Dishwasher
heatman101
Aug 25, 2011 | Zanussi Dishwashers
My dishwasher isnt using the soap I put in the main wash compartment. Ive ran it 5 times using different kinds of soap and it isnt doing anything. The compartment that holds the soap isnt popping open...
Hi, The soap dispenser may not be the problem. It could be that it's not getting enough water. Is the pump running and water cleaning the dishes. Then there is no problem.
Jun 27, 2011 | Dishwashers
It isnt draining water. checked waist pipe and it isnt blocked Looks like the problem is in the machine. regards Brian
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Sep 08, 2010 | Dishwashers
The dishwasher isnt rinsing properly anymore. We are getting a white film left on the dishes.
check water quality. If dish washer salt needed add it to the dispenser provided.Salt softens the hard water.
Check rinser liquid availability in the dispenser. Refer user manual for location
Apr 12, 2010 | Maytag 24 in. MDB5000 Built-in Dishwasher
Dishwasher isnt pumping the water out
Check the drain pipeline of your dishwasher if it is working or clogged. There's a good possibility that it is clogged. So, check these areas well. Send in your
e-mail so we can assist you further.
Oct 14, 2009 | Tricity Bendix 18 in. DH090 Free-standing...
My dishwaher isnt getting any water to it
check you water source, check for crimped hoses, check water source valve, these are all outside of your dishwasher, internally it may be the solenoid which allows water into the unit.
did it quit all of a sudden/ then i suspect a internal part failure..
RB
Feb 12, 2009 | Frigidaire Dishwashers
Water level needs to be adjusted, too low
Check for blockage in the water inlet pipe. As per the manual there is no way to adjust the water level.It is automatically chosen by the machine.
Jan 10, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Old ge dishwasher
Hi loda83,
I'm Harvey the Master Plumber.
Your problem is: there isnt any water going to your dishwasher and its just making a humming noise when you turn it on
The most likely culprit is the solenoid valve. It is a simple on/off valve under the d/w on the left. Depending on make and model I might remove the d/w from the cabinet to facilitate installation. Don't forget to turn off the water first.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 28, 2008 | Dishwashers
Dish washer not filling with water
there can be several reasons: as a start, split the door and check for broken wires in the wiring loom where it passes round the bottom of the door. also check the circulating pump is not burnt out.
May 06, 2007 | Bosch SHU5307UC Built-in Dishwasher
Dishwashers Logo
32 people viewed this question
Top Dishwashers Experts
Owen Barnes
