Question about Garden
The garage door was installed in November, 2006. Recently however, the single door will not close and re-opens automatically every time we try to shut it! I have attempted to adjust the sensitivity adjustment (both decreasing and trying to increase the same without success.the model number and serial numbers are as follow: Model No. 3585-100 Ser. No. 23482101329 I can be reached daily at (678)464-2154 and will welcome your suggestions for repair. My e-mail address is as follows: dave_garrett2000@yahoo.com Thank you in advance, Dave Garrett
    Novelist:
  • 185 Answers
I had a problem with a door once, the door tracks were slightly out of alignment. Does your door have the safety photocell device on it? If so, there are two small boxes on the door track about 2 feet off the floor, they are there to make the door go up incase a pet or child happen to walk under the door when it is closing. This is to prevent the obvious injury of someone. You may already know this, I am just trying to cover all bases. This might go out of alignment as the door comes down and make the door go up as well. You can look at the receiver end of the two units. (one shoots a beam of infra-red light) There might be a light on the unit to show that it is receiving the beam. Place your hand between the two units, the indicator light should go out. This indicates it is operating properly. Now close the door and observe the light, if it goes out and the door reverses, then you need to adjust the sensor so that it stays in alignment with the beam throughout the door cycle. I hope this helps. By the way, thank you for providing the information of the unit in your question.
Joe
Posted on Jan 04, 2011
On 4 occasions we found the door open! Installed in November 2014!
Sometimes the down force is set too light and the door opens as it gets to end of travel. Are you sure it was closed and stopped when you found it opened? Or just heading down as u drove off. Also, the wall remote if wired could have a staple that penetrated the wiring, that shorts out and opens door intermittently.
Apr 21, 2015 | Building Materials
I have a Craftsman 139.53673SRT garage door opener. When I try to close door with remote or single push on doorbell control, the door reverses after 6-8 inches of travel - and big bulb flashes 10 times. ...
When the main light flashes 10 times and the door reverses it is a door sensor problem. Make sure they are pointed at one another and that the small light on each one is lit and not flickering. Tweak them a bit. If you cannot get both lights to come on you have a bad sensor or wiring.
Aug 28, 2010 | Sears Craftsman LiftMaster Chamberlain...
Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+: My craftsman 1/2 hp garage dood does not close whe...
If the main light flashes 10 times when you try to close the door it is a sensor problem. Make sure they are not flickering ever so slightly and that they are not loose on their brackets. Tweak them a little bit.
May 18, 2010 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener closes when closed
Try this: Loosen the chain enough that you can remove it from the sprocket above the motor. Now run the opener until the sprocket turns in the clockwise direction and stops. Reconnect the chain. This will get everything in sync and you will have to tweak the 'up and down limits' a bit to get it just right.
Oct 11, 2009 | Sears Craftsman LiftMaster Chamberlain...
How to switch back to automatic after manually close the garage d
mikey-moore's advice helped me figure out what to do but it's not exactly what I had to do. Manually open the garage door all the way. Then hit the automatic button you normally would use to open and close your garage door. The bracket slides back and locks into place. Hit the automatic button again and the garage door should automatically close.
Jul 19, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door opens/closes by neighbor
Your code may be teh same or close to you neighbors. I'd change to another code. Takes 5 minutes
Jul 19, 2009 | liftmaster Chamberlain Garage Door Opener...
Sears Craftsman Garage door opener does not open or close
The drive gear is most likely stripped. It is a white nylon gear just in front of the motor. The parts number is 41A2817 and is available from Sears or any good door opener service company. It comes with instructions.
Jun 03, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door closes and then automatically opens half way
ADJUST THE DOWN LIMIT IT THINKS THERE IS AN OBSTRUCTION AND IS REVERSING LIKE IT SHOULD.
TURN THE LIMIT ABOUT 1/4 TURN AT A TIME.
HOPE THIS HELPS
Mar 15, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garden Logo
37 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
