Question about Dell PowerEdge 1800 Server
The light at the front of the server which is normally blue is flashing orange, what does this mean
    Problem Solver:
  • 8 Answers
Try replacing the battery on the motherboard. It will flash if the battery is left out.
Posted on Feb 05, 2013
  • Irwin B. Mainway
    Irwin B. Mainway Sep 29, 2014
    Event Viewer in the MMC I bet shows red flagged events, need to right-click for info. What I actually DO: UNPLUG the Dell and plug it in and reboot, unless defective drive or whatever, blue light is back.
  • 355 Answers
HERE are the manuals for you exact model server. it's the best place to start.
Posted on Jan 07, 2011
    Sergeant:
    Novelist:
  • 143 Answers
You should get into the System Event Log and review the records. The orange LED speaks to a much larger number of errors than just the CMOS battery.
Posted on Jun 14, 2015
2 Suggested Answers
hothawk
  • 174 Answers
SOURCE: Flashing orange light
Power edge system are having two power input check the cables from the power outlet may be one is in contact otherwise one of your power supply gone means not working. Check the wires first then the power supply units
Posted on Jul 02, 2008
Luz naranja parpadeante?
That depends on what is flashing orange. Please be more specific, and please post in English. In general, flashing orange lights on Dell servers mean something is wrong. Installing and running Dell OpenManage System Manager will usually tell you exactly what is wrong.
Jul 28, 2014 | Dell PowerEdge T110 II
Orange light blinking mean
Warning that the computer battery is low or dead.
Aug 21, 2013 | IBM Computers & Internet
What happens if the power button to the Wii turns orange for a while and sometimes, when it does that, the disc inputter flashes blue? It only goes back to normal when I unplug it for a while then plug it...
The blue light means you got a message from another user or nintendo has an update for you. The orange power light means your wii is on standby and the red light means your wii is completely powered off.
Mar 13, 2011 | Nintendo Video Game Consoles & Games
I have a blue vertical flashing light showing just above the Dell emblem. In the past there has been a solid light. I have checked on OpenManager which indicates all is well but I do not like unexplained...
Great thanks,
That's just a system indicator flash. Solid blue means on and normal, blinking means someone either turned on the system indicator in the management software or bumped the indicator switch on the back of the server. This was designed to make easier transitions from back to front when working with multiple servers in a rack. To turn the indicator off, just go to the back of the server and find the Ethernet and usb ports that are together. If the usb is the bottom and Ethernet port is the top then just to the right you should see a small blue blinking light and a button, pushing the button wil turn the blinking off.
Again, no worries this is just a "locator beacon" not an error message, if the light ever blinks yellow then you have an issue.
Hope this helps FixYa,
Chris
Jan 10, 2011 | Dell PowerEdge 1800 Server
Dell Inspiron 1525 laptop, no power light, battery light flash orange, wifi light flash blue and orange I bought the Dell Inspiron 1525 laptop in 2008. I use the laptop as a desktop, so I never plugged...
Since it sounds like an issue with the Power first try to release flea power.Disconnect the charger,remove battery,press and hold down the power button for 30 seconds.Reconnect the battery and charger.Turn on system and check if it turns on. For further help please check Dell Inspiron 1525 Manual. Also confirm if the light on the charger stays on,when connected to the system.
Mar 06, 2017 | Dell Inspiron 1525 Notebook
Dell poweredge 830 server orange flashing light instead of solid blue. No fault on screen. any ideas?
its the cover switch. there is a small push switch on the front panel that detects if the front cover has been removed, either the switch is defective, or the cover is not seating properly to close the switch.
Jun 09, 2010 | Dell PowerEdge 830 Server
Dell poweredge 1650 is beeping with blue flashing light
Flashing blue light is harmless - it simply means the Identify button has been pushed. There is a small button with a white, cursive 'i' on the front and back of the server - pressing this will make the light flash blue (or make it stop).
Go to Dell's support site and view the manual for the 1650 for an explanation of the beep code - identify the pattern of the beep.
If you are still able to get to Windows, use OpenManage Server Administrator to check the Hardware logs and RAID array.
May 20, 2010 | Dell PowerEdge 1650 Server
Help with server boot problems flashing orange lights etc
Seems the RAID is broken. You may see which drive (hot swappable?) it showing an error code with its lights in front. If not, I would suggest re-seated all drives.
If you see one that is not right, remove it all the way, while it is on, then push it back in, it should try to rebuild the raid on the drive, if it still fails, you will need to replace the drive.
Not sure what RAID you are using or how many drives, so feel free to explain more.
G'luck
Oct 24, 2008 | Dell PowerEdge 4600 Server
Nov 26, 2007 | Dell PowerEdge 1800 Server
Dell PowerEdge 1800 Server Logo
1,578 people viewed this question
Alun Cox
