Tv wont switch on
I turned my tv on then it turned straight of now wont work
  • 8,617 Answers
I will ned the model number of your set to even begin to help you with the problem. Please respond to this same post with your model number.
Posted on Jul 09, 2008
I have a 2002 chrysler concorde. When i park the car if the wheels are turned to the right, the car wont start because the car wont show park or neutral. Even if the shift is in park the car wont register...
IT could still be the neutral switch that is not adjusted properly and registering the straight ahead position but if you have a column shift I would say that the neutral switch is way out of adjustment as the switch works off the selector position and not where the wheels are pointing.
Apr 28, 2014 | Chrysler Concorde Cars & Trucks
Tv wont turn on
It sounds like a main digital board fault. Contact any service technician. To get more details, http://electronicshelponline.blogspot.com/
Nov 28, 2013 | Televison & Video
LG TV KEEPS TURNING OFF
Kindly do not keep attempting to turn it on, as you are likely to spoil some other boards/parts/components of the TV. Look for any loose contacts in power out let, RC jack, cable and socket. In order to ensure, it is not caused by the input device, connect a DVD player
and see. Switch off TV, switch off power, remove plug and wait for 48 hours and retry.
If problem persists, I suggest it is better to refer it to a qualified service technician, since the back cover has to be opened for investigation/rectification.
Aug 21, 2012 | LG 50PC1DR 50 in. Plasma HDTV
Wont turn on from standby
Switch off TV manually, switch off power, remove plug and retry after 48 hours. If problem persists, please refer it to a qualified service technician.
Jul 30, 2012 | Toshiba 40BV801B LCD TV
Can't turn off the closed captioning
I had the same problem. Okay, First get the TV remote. not a cable box remote. Next, switch the input to an Analog input. (TV or input one if you have the RC red, white and yellow hook up. or, just hook up the coax cable straight to the TV..
Now, use the TV remote to operate the closed caption. It will work like it should.\
Briefly, closed caption works on the TV with a straight hook up to the TV. It will not work with a cable box.
Good LUCk
Monty
Aug 21, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
How to remove switch .Key no longer works
turn the key to acc then put a straightened out paper clip in the tiny hole under the key switch and push while wiggling the key switch and the switch will pull straight out,if the key wont just turn the switch then lightly wiggle the key in and out till it actualy turns the switch then follow instructions i provided.
Aug 28, 2009 | 1986 Ford LTD
Tv wont turn on
Switch off the surge protector for 2-3 minutes then switch back on and TV should work.
Feb 19, 2009 | Philips Magnavox 27MS343S 27" TV
Tv wont switch to Sky when remote control is pressed
Hi.
On the sky box do the following.
Check scart to tv is in the correct socket marked TV.
Try pressing services
then system setup
then picture settings.
Then try switching scart control to on or off.
If this sorts it great. If it doesnt check scart lead has all pins wired & not only A few.
http://dysonmanuals.llc.nu
Chris..
Jan 19, 2008 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
