Question about LG Refrigerators
The refrigerator freezes everything in the food compartment. This is the second year in a row.
  • 472 Answers
It sounds like you have a bad thermostat control or the damper is not shutting off when it is suppose to... the unit actually works by freezer side cooling first and then air is pushed over into the fresh food side .there should be a control that sets the temperature and a small damper door that opens and closes based off of temperature as well.. one of the two are not telling the refrigerator side to shut down.... hope this helps you out./....repost with anymore questions if i see you on here i will try and help.... lg. servicer/ and appliance repair specialist for 18 years
good luck and please vote
Posted on Jan 03, 2011
Model KBF A25ERSS01 - S/N ECT2510800
I am not familiar with this refrigerator, but what you describe can happen if the refrigerator uses a motorized damper to control the refrigerator temp by varying amount of air from the freezer that circulates in the refrigerator compartment. If the damper door is stuck in the open position or broken, the refrigerator temp will not be controlled and freezing can occur in the refrigerator compartment.
Apr 01, 2014 | KitchenAid Refrigerators
The food on the refrigrator side is freezing. the water line is not working so i assume its frozen as well.
Hello Tina,
The problem with it freezing in the freshfood section is going to be because the air damper that opens and closes to let cold into the ref. section is stuck open and too much cold air is entering into the ref. compartment. This is a fairly common occurence with the GE refrigs. and by replacing the fresh food air damper which is located in the upper left corner of the fresh food compartment it will open and close properly and not allow too much cold air to enter where upon it freezes everything.
GENE
Sep 30, 2011 | GE PSW26MSR Stainless Steel Side by Side...
GE Refrigerator GTS17BBMRW. Everything in refrigerator compartment freezes.
Hi, There can be many reasons why your refrigerator is freezingyour food. To see what could be happening and to figure out how to possibly fixyour problem. Take a look at this tip which contains many of the causes andsolutions to fix the problems.
Refrigeratoris Too Cold and Freezing Food
heatman101
Sep 18, 2011 | Refrigerators
Maytag Model MFF2557KES EVERYTHING FREEZES TOP AND BOTTOM COMPARTMENT
heatman101
Sep 17, 2011 | Maytag MFF2557HES Stainless Steel French...
Everything is freezing in the refridgerator. The water dispenser will not put out water. We have taken the temperture to 0 then back to 5 and it still will freeze in the regular compartment.
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Mar 13, 2011 | GE Refrigerators
My TRUE GDM49 refrigerator is freezing food...what do i check or replace?
HI,IF YOUR REFRIGE IS FREEZING IN THE REFRIGERATOR COMPARTMENT EVERYTHING ,CHECK THE AUTODAMPER OR AIRFLOW CONTROL FOR ICE BUILD UP ,NOT LETTING THE DAMPER TO CLOSE ONCE IS COOL ENOUGH IN THE REFRIG SIDE,MOST OF THE TIME WHEN REFRIGERATOR IS FREEZING TOO MUCH THE AUTODAPER IS BAD.GOOD LUCK..
Feb 21, 2011 | Refrigerators
My fisher and paykel refrigerator keeps freezing my food, then its ok, then it freezes up my food again, I have adjusted it, but still no good.its 8 years old
you will need to check your damper door between the freezer and refrigerator compartments and watch to see if its opening and closing when you adjust your refrigerators cold control,then if it doesn't move after adjustment the control will need to be replaced
Jan 08, 2010 | KitchenAid KSCS25FKSS Side by Side...
Fruits & Veggies are freezing in both lower frig compartments
Good day,
This problem appears in spades this time of year, every year.
The problem becomes more severe when the temperatures in the house cools down and is made even worse if the usage of the machine becomes lighter.
It occurs when the machine is off, not on.
There is an open vent, near the bottom, between the freezer compartment and the fresh food compartment. This opening or vent is necessary when the machine is running, so that the air pumped into the top of the fresh food section, can return to the freezer compartment. This is by design.
Now,
When the machine is off, the zero degree air from the freezer compartment. can drift into the fresh food compartmnet and drop the temps near the bottom to below freezing.
Off time increases substantialy at this time of year.
Some have even recommended turning the controls colder to offset the problem, but I've no proof it works well, or even a little.
SXS and top freezer models experience it more than bottom freezer models.
Dec 14, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Fridge keeps on freezing everything inside of it
This refrigerator only has one thermostat located in the fresh food compartment it is designed to activate the sealed system (cooling) until it reaches approximately 37 deg f in the fresh food compartment. The damper controls how fast the cold air can move from the freezer compartment to the fresh food compartment. Allowing you to control the temp in the freezer by controlling the flow of cold air to the thermostat.
You have one of two problems.
#1 your thermostat is no longer opening when it achieves set temp. fix = replace thermostat pn 61005798 $35
#2 your damper arm or assemblie has broken. Fix = Replace damper or broken arm and actuator.
damper assembly pn12001377 $44
damper actuator pn 61002000 $2
damper arm pn 61001999 $2
thermostat actuator arm damper arm
damper assembly both pics
Apr 06, 2009 | Refrigerators
Top mounted freezer on refrigerator not working
Move the refrigerator to a room that is at least 50 degrees F.
Temps on most refrigerators are regulated by the fresh foods temp. If your garage is let's say 35 degrees, the fresh foods temp will most likely never raise enough to turn the refrigerator on. With the refrigerator never running, the freezer compartment will warm to 35 degrees, resulting in everything melting. Even if garage is a bit warmer, say 45, the refrig will not run long enough for the freezer to maintain a low enough temperture. If the garage temp falls to below freezing, say 20 degrees, the food in the fresh foods compartment will freeze. (outdoor beverage dispensers have internal heaters to prevent product from freezing !) Please don't rate this if not a Fix-Ya for you, as anything else lowers my score.
Jan 22, 2009 | Frigidaire 5 cu. ft. / 142 liter Chest...
Refrigerators Logo
113 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
