Question about Garmin nuvi 255W GPS Receiver
My garmin 760 stopped speaking street names - Garmin nuvi 255W GPS Receiver
  • 1 more comment
  • Anonymous Mar 04, 2009
    My Garmin 760 suddenly stopped speaking street names also. Now it just tells me to "turn right" for example....I paid extra for this feature on the 760 and there does not appear to be a setting to turn it back on.
  • Anonymous Mar 26, 2009
    My unit suddenly stopped announcing street names also. It worked perfectly for about 3 months then just quit speaking street names. All other features work fine. I can't find any options to turn on or off the feature.
  • Anonymous Apr 12, 2009
    my new NUVI 760 does not speak street names...how can I fix it?
I had the same problem and wrote Garmin for help. Here is the solution:
Thank you for contacting Garmin International. I'll be glad to help you with this. Please check the voice settings of your Nüvi. Starting on the main menu, select: Tools (wrench)> Settings> Language> Voice. The voice setting should be set on an option with (TTS). This stands for "text-to-speech" and is function of the unit that allows it to speak actual street names.
In other words you must choose a language with (TTS) after it such as American English-Jill (TTS)
I hope this helps everyone.
Posted on Mar 27, 2009
You probably have gotten corrupt data in your unit. You need to reset the master data base. Caution, this will erase all of your personal data so back it up on your computer if you don't want to loose your favorites, etc.
Turn the unit off.
With your right thumb hold pressure down on the bottom right corner of your screen.
While holding down your right thumb, turn the unit on with your left hand.
You will get a message asking if you really want to reset the database. Remove your right thumb from the screen and answer yes.
You will have to answer a few set up questions after that.
You should be able to test your unit and have the voice guidance begin speaking street names again.
Worked on mine.
Posted on Mar 10, 2009
Thanks you rd301. I followed your suggestion and it worked perfectly. John from Ocala
Posted on Aug 09, 2009
My garmin nuvi 255w does not speak street names. How do I set it up to speak the street names?
I'm afraid the 255w does not speak street names. A satnav needs to have "Text To Speech" capability before it can speak the names and the 255 doesn't have it.
Aug 04, 2011 | Garmin nuvi 255W GPS Receiver
My Garmin Nuvi 760 GPS announces the turns but not the street names.
1. This is because some voice files are only basic but others speak the street names. To change the voice file press TOOLS, then press SETTINGS then press LANGUAGE. Press the VOICE and change it to a different one.
2. You can download extra voices, if you need to, by connecting your satnav to your computer, Download webupdater from http://www8.garmin.com/support/collection.jsp?product=999-99999-27 and install it. When it's installed it'll look for software updates. After this it'll give you the option to download extra voices. Select the ones you want and press next. Follow the prompts and they will be downloaded to your satnav. When you have disconnected your satnav from the computer you can select a new voice as described in para 1 above.
Aug 19, 2010 | Garmin Nuvi 760 Car GPS Receiver
Garmin nuvi 750 won't say street names after upgrade to 2009 maps
User's manual available at www.garmin.com. Select "support", then "Manuals". Enter "mobile electronics"+"automotive"+"model #". Manual says that selecting a language with a person's name will speak street names.
Jul 04, 2009 | Garmin (010-00583-00) for nuvi 750/760/770
My Garmin 760 does not speak street name on the turns. How to set dthis?
On your GPS device, Touch settings>Select language>Select Voice and select the TTS(Test To Speech) man or women to speak.
Make sure the volume is up, and the mute is off.
The pre-recorded voices(those with out a persons name) have a limited vocabulary and do not speak names of locations or streets.
hope it helps you out
JADF
Apr 13, 2009 | Garmin Nuvi 760 Car GPS Receiver
Garmin 750 stop saying street names
If you go to your languages, in the menu
Check Languages are
(( noted with a person's name ))
these are TTS text to speach voices,
Check they are set correct,
you should be good.
Hope this helps
Regards
Richard.
Apr 11, 2009 | Garmin (010-00583-00) for nuvi 750/760/770
I have a Nuvi 255. It does not speak street names
Did you select Text To Speech (TTS) one?  If the voice doesn't have (TTS) it won't speak street names.
Mar 29, 2009 | Garmin nuvi 255W GPS Receiver
Late response on turn-by-turn voice directions- garmin nuvi 760
Hi, my 760 had the same problem, and a stutter when speaking street names. I fixed both by upgrading the software to v4.60 using the Garmin Webupdater.
Dec 24, 2008 | Garmin Nuvi 760 Handheld GPS Receiver
Speak street name
Select a voice with TTS (Text to speech).
Jun 02, 2008 | Garmin Nuvi 350 Car GPS Receiver
Street names
http://iq.garmin.com/eCustomer/KODSelfService/request.do?session={ed995d70-c2e6-11dc-6a6e-000000000000}&event=1&view()=c%7Bf996f590-047f-11dc-e004-000000000000%7D&objectId=&eksObjectId=&objectType=Case&isJumpEnabled=false&isContentJumpEnabled=false&vendorKey=&versionId=1301&objectScore=82&from=search
Question
: My nuvi is supposed to speak street names when giving voice prompts but it doesn't. How can I fix this?
Answer: All of the Garmin automotive GPS units that speak street names are also loaded with basic voice prompts (i.e. 'Turn Right in 500 feet') as well as 'text-to-speech' voices that speak street names. If one of the basic types of voice prompts has been selected, the voice prompts will not speak street names.
In order to change this setting on the nüvi line of products, please follow these steps:
  1. In the Main Menu, tap on the Settings icon.
  2. Tap on "Locale"
  3. The second line on this screen has a picture of a mouth. To the right, the current voice for the GPS device is listed. Tap it to change the voice.
  4. Select a voice that is labeled with (TTS) at the end. These voices will speak street names.
  5. Select "OK". The voice has now been changed.
The device should now speak street names.
Dec 22, 2007 | Garmin Nuvi 660 GPS Receiver
Garmin nuvi 255W GPS Receiver Logo
734 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
