GE Profile washer
I have a GE profile washer which recently developed a freight train like grinding noise durring the spin cycle. The noise got progressively worse until it suddenly stopped as did the washers ability to wring clothes dry durring the spin cycle. I checked the rubber tub holders on each of the four corners and they look O.K. Is this a bearing, transmission, or clutch issue? and how much would each issue be?
Model # WPSR3100W0WW
Serial # GV170241G
Thanks
  • daveororpha Jul 10, 2008
    Thank you kindly oldfixer. I was told by an online tech that it is the bearings but definitely will get an onsite estimate before proceeding any further. Thanks again.
    New Friend:
Take the cover in center of agitator off .remove bolt ,and agitator . Our new washer likes to eat change and get stuck between the agitator in the drum when they start spinning it starts grinding like a bunch of ball bearings In can
Posted on Aug 17, 2014
    Genius:
  • 1,028 Answers
Suspect gearcase ask for estimate first..could be more than new washer
Posted on Jul 10, 2008
Hi y'all! I recently aquired set of Neptune W&D. Washer is a TL and has 2 problems: 1. When washer goes into the spin mode, it sounds like a freight train going by. VERY LOUD...like maybe the...
Them are junk...Lol sorry but yes in the back where the pulley is there is a bearing and you have to replace the whole thing a 500$ part
Mar 13, 2011 | Washing Machines
Make a humming noise and spins very slowly
MINE DOES THE SAME. HOUSING IS CRACKED THAT ATTATCHES TO DRUM. WHITE METAL CANNOT BE REPAIRED.
Jul 25, 2010 | GE WPXH214A Front Load Washer
Wont spin and makes alot of noise
You could check if its drum by removing the belt turn drum by hand if its okay no noise check motor pulley ....is motor ok ?
Nov 17, 2009 | GE Profile Prodigy WPSE4200A
Ge profile prodigy make clunking before spin cycle
Is there a humming sound? Check you have the hot and cold water supply turned on. Check the water inlet hoses are not kinked.
May 03, 2009 | GE Profile Prodigy WPSE4200A
GE profile washing machine won't agitate it spins out, drains,
Pull the agitator out and check the drive collar splines.If you have the model I think you have just pull straight up on the agitator. Once removed you will see the drive collar with a 7/16 head bolt,remove it and pull off the collar.First before pulling it off spin it if splines are stripped it will spin freely.
Mar 25, 2009 | GE Profile WPRE6100G Top Load Washer
Washer transmission dead?
From your description, it sounds like the drum bearings have failed. If you grab the drum (power off, of course) it will probably wobble around a lot more than it should, and there might be metallic debris in the removable filter. White clothes may have been getting greasy spots on them recently.
Does any of this fit the bill with you? I hope it helps a bit to find out what's wrong.
If these suggestions do help you solve the problem, please give my reply a rating to help others judge my knowledge / guessing skills. If they do not, please add a comment with more details so I can try to help you further. Cheers, D
Jul 10, 2008 | GE Profile Prodigy WPSE4200A
GE Washer WPSR3100W0WW roars like a freight train in spin cycle
You would need a transmission (WH38x10002) which comes with a new tub seal, and runs between $150 and $200. Check the back of the owners manual to see if your washer has a five year warranty on the transmission. (newest ones may be only 1 year) They do make a couple special tools which make the repair easier, and an experienced tech can do one in about a half hour, but your first one will take much longer. Motor is most likely just fine.
Jul 03, 2008 | GE Profile WPSR3120WWW
Washing Machines Logo
544 people viewed this question
Top Washing Machines Experts
