Question about Sony 1GB Memory Stick PRO Duo Memory Card
How do I format my 1GB memorystick PRO Duo memory Card. I put my card in the camera and it says to format the card
  • 1,679 Answers
Remove the memory card and you will find a switch on the left side of the card. It must be locked, so slide or push the lock on other side to open it and then Format It.
Regards
Ron
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
Posted on Jan 03, 2011
Ahoo.commy sony memory stick pro will not show photos it sais device error on my camera
If possible, copy the photos into pc and then format the memorystick by the camera
Jun 21, 2011 | Sony 1GB Memory Stick PRO Duo Memory Card
Hello Sir.Madam, I have DSC-H10 digital camera. It is having memory of type "Memory Stick Pro Duo". This card was working fine till the day. To transfer images to my PC, I have accessed this card to SD...
Your problem is that you have formatted your MemoryStick from your computer. Your Sony camera uses its own proprietary formatting method and does not understand FAT32. You may also have corrupted your memory card if you didn't click on "safely remove hardware" or by right clicking on the icon of the MemoryStick in the My Computer window and selecting "Eject" from the drop down menu. (This assumes that you have a Windows pc, Macs will have their own way of doing this).
Try reformatting the memory card in the camera itself, this usually solves the issue but if it doesn't then you'll have to replace the MemoryStick.
Good luck, I hope that my reply has been of use and that you are able to save your MemoryStick. I'd be grateful if you would take a moment to rate my answer.
Sep 30, 2010 | Cameras
1GB Memory Stick PRO Duo Memory Card: i have a memory stick pro duo card .... but now we...
Hi sir
  • Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  • 2 Open up 'My Computer'. You should see it under the list of available drives.
  • 3 Check its contents first to make sure that you have the right drive.
  • 4 In 'My Computer', right-click on the drive and choose 'Format'.
  • 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  • 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
  • May 17, 2010 | SanDisk 1GB Memory Stick PRO Duo Memory...
    1GB Memory Stick PRO Duo Memory Card: My sister's boyfriend put my stick into his comput...
    Preformat : By Fix-shad0w
    #1
    #2
    #3
    #4
    #5
    #6
    With A USB , CELLPHONE , Camera The SameThing
    May 14, 2010 | Sony 1GB Memory Stick PRO Duo Memory Card
    Memory stick pro duo
    LLFTOOL is a utility for low-level disk drive formatting,
    also supports formatting of FLASH cards using a card-reader.
    1. Download this tool:
    http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
    2. Format stick pro duo
    (WARNING: After running this low level format tool,
    the whole USB flash disk surface will be fully erased.
    Therefore, data restoration will be impossible after using this utility!)
    Jan 28, 2010 | Sony 1GB Memory Stick PRO Duo Memory Card
    How to repair a memory stick duo turn that to raw
    Put memory stick in camera and format it, this is the only way to fix some problem in memory stick.
    If that does not help, memory stick got hardware problem that is irreparable. Buy new memory stick then.
    Thanks.
    Nov 05, 2009 | Sony 1GB Memory Stick PRO Duo Memory Card
    I cannot formate my sony 1gb memory stick pro duo when i inserted in my computer it shows it cannot use it before formate disk when i tried to formate it shows window was unable to complete the format
    Windows formatting tools are not good enough to format Sony memorysticks.
    You need to use special formatting tool
    Download that from here:
    http://esupport.sony.com/US/perl/swu-download.pl?mdl=MSACUS40&upd_id=2860&os_id=7
    If this will not be able to format your memorystick - call sony support and report that repair of memorystick is necessary. It is a hardware fault with memorystick and it needs to be repaired or replaced.
    May 28, 2009 | Sony 1GB Memory Stick PRO Duo Memory Card
    Formate memory stick
    try formating the card using a digital device such as a camera or a playstation portable (PSP)
    May 17, 2009 | Sony 1GB Memory Stick PRO Duo Memory Card
    Wont access memory card
    i) try to put memory card in any mobile if it working in it is fine, if not your memory is having some password put on it or attached, try to remove the password and then work with it ........
    you can remove password by keeping the memory card only in that mobile where you kept the password(only in that mobile through which u kept the password...)
    Dec 28, 2008 | Sony 1GB Memory Stick PRO Duo Memory Card
    Sony 1GB Memory Stick PRO Duo Memory Card Logo
    111 people viewed this question
    Top Sony Electronics - Others Experts
    Sandy Moore
    Sandy Moore
     Grubhead
    Grubhead
    Are you a Sony Electronics - Other Expert? Answer questions, earn points and help others
