Question about Cadet Manufacturing 67508 Coil / Ribbon Compact Heater
Red Light turns on when i Click on the heater but nothing blows out... No hot or cold air. it just clicks like its turning on but nothing happens??? What could it b?
How do I get my heater to blow hot air?
I assume this is gas . induced draft blower or ignitor.
Apr 30, 2014 | Goodman GMS90703BXA Heater
The heater in my 1999 Land Rover Discovery Series 1 won't blow cold.
As per your problem mentioned.There are few solved help links to troubleshoot these problems.Go through the list and Click the link below:----
Air conditioner blows air but not cold air http://repairhelpcenter.blogspot.in/2012/07/air-conditioner-blows-air-but-not-cold.html
Car overheats and Air blows hot at idle? http://howtobyme.blogspot.com/2011/11/car-overheats-and-air-blows-hot-at-idle.html
Heater blows cold? http://schematicsdiagram.blogspot.in/2012/02/heater-blows-cold.html
Heat blows cold on drivers side and hot on passenger side? http://schematicsdiagram.blogspot.com/2011/12/heat-blows-cold-on-drivers-side-and-hot.html---------- Hot air on the driver's side vents only? http://repairhelpcenter.blogspot.com/2012/01/hot-air-on-drivers-side-vents-only.html
2005 Chrysler PT Cruiser: A/C Blows Warm? http://whoisbyme.blogspot.in/2012/06/2005-chrysler-pt-cruiser-ac-blows-warm.html
1992 Toyota Camry: A/C Control light Flashing and A/C not Blowing Cold? http://technoanswers.blogspot.in/2012/04/1992-toyota-camry-ac-control-light.html
No heat, blower blows only cold? http://technoanswers.blogspot.in/2012/02/no-heatblower-blows-only-cold.html
These will help.
Thanks.
Nov 22, 2012 | Cars & Trucks
Heater doesnt work
To troubleshoot this types of problem,click the link below :---
Car heater blowing warm, but not hot air?http://schematicsdiagram.blogspot.com/2011/12/car-heater-blowing-warm-but-not-hot-air.html
Engine Overheats and heater blowing cold?
http://howtobyme.blogspot.com/2011/11/engine-overheats-and-heater-blowing.html
No heat on car? http://technoanswers.blogspot.in/2012/02/no-heat-on-oldsmobile-silhouette.html
Heater blows intermittently and temp gauge goes erratic?
http://technoanswers.blogspot.com/2012/01/heater-blows-intermittently-and-temp.html
Heater blows cold?
Heater/AC blower motor not working?
http://technoanswers.blogspot.in/2012/02/heaterac-blower-motor-not-working-on.html
A/C, heater, defroster fan, not working? http://technoanswers.blogspot.in/2012/02/ac-heater-defroster-fan-not-working.html Heater problem?
http://technoanswers.blogspot.in/2012/02/heater-problem-on-isuzu-trooper.html
This will help.Thanks.
Mar 27, 2012 | 1994 Volvo 960
Heater core is working properly but car will not blow hot air only cold air i am thinking the flapper that controls hot \ cold is stuck in the cold air position
To troubleshoot this types of problem,click the link below :----http://howtobyme.blogspot.in/2012/02/heater-blows-only-from-defrost.html
--------Go through the procedure to confirm the issue.
Jan 25, 2012 | 2001 Buick LeSabre
Heater does not blow hot only cold air. Every so often the heater blows hot . When driving on freeway the heater works sometimes but turns cold when at red light.
Check the radiator level, if it low the hot coolant will not reach the heater. Second may be the water pump, as it wares the clearance increases and the efficiency goes way down and it cannot pump the coolant unless the engine revs are up.....
Feb 13, 2010 | 2005 Dodge Caravan
2001 Dodge Caravan heater blows cold air when stopped
Have you checked the coolant level? What you describe is exactly what happens if the coolant level is low. When stopped at idle, hot coolant is not circulating through the heater core, so no heat. As the engine increases in rpm's when you pull away from the light, the water pump is spinning quicker, and some coolant is making it to the heater core. So check the level, and if it is low, keep an eye on it to see if it drops again. That of course indicates a leak somewhere. Get it fixed, as overheating the engine leads to costly repairs and worse case a new engine. Let me know how you make out with this.
Dec 05, 2009 | 2001 Dodge Grand Caravan
The heater only blows hot air sometimes
it sounds like a bad blend door motor.these are controlled electrically and not with a cable like older vehicles did.
Oct 27, 2009 | 1999 Ford Windstar
Cadet Manufacturing 67508 Coil / Ribbon Compact Heater Logo
76 people viewed this question
Top Cadet Manufacturing Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
Are you a Cadet Manufacturing Heating and Cooling Expert? Answer questions, earn points and help others
