Hi there. When I use the source button, the s-video option doesn't appear anymore. But, the cable in my bedroom is working. Meaning, my cable is working. The tv is saying weak or no signal. It was working fine yesterday. Nothing has been moved around.
  • 39 Answers
Hi there
Are you watching it through a cable box in both rooms? If so, it may be that the box in your living room has packed up.
Hope this helps
TV_Doctor
Posted on Jan 03, 2011
  • temper_22 Jan 03, 2011
    hi,
    Yes, I have 1 cable box that has 2 cable cords running through it. The tv in the bedroom has cable, but the living room one doesn't. I can still switch to my Xbox by using the source button, but the s-video option doesn't show up anymore....
    Not sure what is going on with this thing.
  • TV_Doctors Jan 03, 2011
    First check that all the cables are connected properly. Do you normally watch TV via the TV's built in decoder, or through an external box such as in your bedroom? Cable companys have began switching off the analogue signals, meaning you can only watch if you subscrive with the box and decoder equipment.
How do I use the video source button? I can see the different video inputs I can select on the screen after hitting the button but I can't move the cursor to select a different video source an
On Most TVs I have messed with, Hit the input or source button muliple times to cycle throught the different inputs. Also make sure there is an active device on the input for the TV to recognize it. Good luck
Jan 03, 2015 | Televison & Video
Hello - Our Pioneer vsx-305 display screen doesn't light up anymore and we are unable to get it to work even though the on/off button appears to operating correctly (red standby light comes on). T
It is likely failing due to age.Cold solders fail, corrosion can cut a connection, a capacitor can harden and fail... a myriad of things can happen in time. Repairing it will cost more than an inexpensive replacement. The same receiver can be had on ebay from $60 up (with shipping). It is a cost benefit issue at this point.
Jan 10, 2013 | Pioneer VSX-305 Receiver
Video and hdmi cables will not work
Theliquorguy,
Do you change the input source?
Feb 09, 2018 | Sharp LC-C4655U 46 in. LCD TV
Hi, I have a Dynex flat screen and I want to play a video. I connected the RCA cables. What do I need to do?
Hi If you have connected the RCA cables corretly, that is, Yellow, Red, and White colured sockets of video source component, may be a VCR, DVD, Blu-Ray etc; to the respective colured sockets to the TV, just switch ON both the devices, insert a video casette, CD or DVD whatever it may be into the source player. Get into the Menu of TV, surf through; and come towards its Input option and select the input you want to get through it. Hilight that option and press enter button on the remote control. When the correct input have been selected you will see the video signals plays through your TV. OK.
Jul 11, 2011 | Dynex Televison & Video
Get ''not supported ''message on vx-1018-ah
Verify this is a Pioneer VSX-1018AH.
The manual explains it all... The problem is probably an incompatible setting on your source.
Search for "not support" in the manual...
http://www.pioneerelectronics.com/PUSA/Unassigned+Content/VSX-1018AH-K+OPERATING+INSTRUCTIONS
I think this may do it... From Page 86...
No picture or sound. • This receiver is HDCP-compatible. Check that the components you are connecting are also HDCPcompatible.
If they are not, please connect them using the component or composite video jacks.
• Depending on the connected source component, it’s possible that it will not work with this receiver
(even if it is HDCP-compatible). In this case, connect using the component or composite video jacks
between source and receiver.
• If the problem still persists when connecting your HDMI component directly to your monitor,
please consult the component or monitor manual or contact the manufacturer for support.
• If video images do not appear on your TV or flat panel TV, try adjusting the resolution, DeepColor
or other setting for your component.
If ‘NOT SUPPORT’ appears in the receiver’s display, try adjusting the resolution, DeepColor or
• While analog video signals are being output over HDMI, use a separate connection for audio
output.
• When this receiver reproduces MULTI CH IN audio sources with the HDMI setting set to
THROUGH, you cannot hear audio output from all channels. In this case, make a digital or analog
audio connection.
• To output signals in DeepColor, use an HDMI cable (high speed HDMI cable) to connect this
receiver to a component or TV with the DeepColor feature.
Check the HDMI Control (Page 65-66 of the manual). It only works with Pioneer Flat Panel TV's. Also check Page 83 for "No image is output..."
No image is output when an
input is selected.
• Check the video connections of the source component (see page 18).
For high-definition video (using component video connections), or when digital video conversion
is switched off (in Setting the Video options on page 72), you must connect your TV to this receiver
using the same type of video cable as you used to connect your video component.
• Make sure the input assignment is correct for components connected using component or HDMI
cables (see The Input Setup menu on page 67).
• Check the video output settings of the source component.
• Check that the video input you selected on your TV is correct.
Some components (such as video game units) have resolutions that may not be converted. If
adjusting this receiver’s Resolution setting (in Setting the Video options on page 72) and/or the
resolution settings on your component or display doesn’t work, try switching Digital Video
Conversion (in Setting the Video options on page 72) OFF
Apr 05, 2009 | Pioneer Audio Players & Recorders
I signed on last night, asked a couple of questions, but the info sent to my e-mail didn't have anything to do with the questions I asked. Noticing in the forum, several people has the same problem:...
Howdy Mike-d. here, mikedee4@gmail.com
Hi CindyCee,
I have tried to post solutions, but they seem to be too long, so I will have to post more than once to get the info to you.
First part- the "Line-In" Video Source thing many people are having fun with. Try these options from the Samsung FAQs website.:
How Do You Switch Video Sources? spacer.gif Depending on the model TV you have, there are up to four ways to change the video source:
  • Through the on-screen menu controlled by your remote
  • Through the on-screen menu accessed through the Menu button on your TV's front panel
  • Through the TV/Video, TV/Component, or Source button on your remote
  • Through the TV/Video or Source button on the front panel of your TV
Your TV could provide any combination of these methods. Instructions for all the methods are below
Changing the Source Using the On-Screen Menu Controlled By Your Remote To use the on-screen menu of your TV controlled by your remote to change video sources, follow these steps:
  1. Turn on your TV.
  2. Press the Menu button on your remote. The Main Menu appears.
  3. Select Input, and then press the Enter button. The Input menu appears.
  4. Select Source List, and then press the Enter button.
  5. Press the Up or Down arrow button on your remote to select the signal source, and then press the Enter button on your remote.
  6. Press the Exit button on your remote to exit.
Changing the Source Using the On-Screen Menu Accessed Through the Menu Button On The Front Of Your TV To use the on-screen menu of your TV accessed through the Menu button on the front of your TV to change video sources, follow these steps:
  1. Turn on your TV.
  2. Press the Menu button on the front of your TV. The Main Menu appears.
  3. Use the Up or Down Ch button on the TV to select Input, and then press the - or + Vol button. The Input menu appears.
  4. Use the Up or Down Ch button on the TV to select Source List, and then press the - or + Vol button.
  5. Press the Up or Down Ch button on your TV to select the signal source, and then press the - or + Vol button.
  6. Press the Menu button to exit.
Changing the Source Using the TV/Video or Source Button On Your Remote To use your remote to change the video source, follow these steps:
  1. Turn on your TV.
  2. Press the TV/Video or Source button. The current source appears on the TV screen.
  3. Press the TV/Video or Source button repeatedly to cycle through the available sources. Stop when you reach the source you want.
Changing the Source Using the TV/Video or Source Button On The Front Of Your TV To use the TV/Video or Source button on the front panel of your TV to change the video source, follow these steps:
  1. Turn on your TV.
  2. Press the TV/Video or Source button on the front of your TV. The current source appears on the TV screen.
Part 2 -next
Jan 20, 2009 | Televison & Video
Not recognizing any source
Hi, i hope this works for you, all you need to do is press the source button this makes the projector search for active inputs.
Nov 06, 2008 | Acer PH110 Multimedia Projector
I can't set the clock on a DEH0-2050MPG car radio. When I press function as the manual says to, only 2 options appear, and neither have anything to do with the clock. What do I do?
If the function button does not work to set the clock, you have to turn the radio off, and hold down the source button until the clock appears. When the Clock appears, you can set it by using the four smaller buttons around the source button.
Jul 22, 2008 | Pioneer Audio Players & Recorders
Televison & Video Logo
43 people viewed this question
Top Televison & Video Experts
