Question about Teac CD-X8 CD Shelf System
I may have miss-placed a part for the FM antenna. what parts should I have?
    Problem Solver:
  • 44 Answers
You will need wire and antina
Posted on Jan 03, 2011
Fm antenna
hahahah that's low reception try to connect into tv antena much better reception.
Aug 10, 2013 | Samsung HTC550 Theater System
AWRC3G
Assuming you're talking about listening to radio not CD, I feel like an idiot asking this but do you have an antenna attached to the FM antenna input on the back? If not, attach one. The FM antenna in the power cord is rudimentary at best. Putting your hand on it makes you an antenna so hissing stops. Move away it starts again.
Apr 17, 2013 | Bose Wave Radio
FM antenna is not providing reception, despite cable connected to powered antenna amplifier. TV also connected to powered antenna amplifier (splitter) works fine. FM mode produces only static. I purchased...
If I understand your setup, you've connected the receiver antenna terminal to the output of the antenna amplifier. If this is true, I'd suggest trying the receiver using a plain old FM dipole antenna (available at Radio Shack and other stores) or even just a piece of wire hooked to the antenna terminal. You should be able to pick up some local FM stations then.
What might be happening is that the FM is being filtered out by the amplifier. Some amps made mainly as a TV signal booster have an FM trap designed to block the FM broadcast band. In the analog broadcast days, the FM band was right near the sound part of a TV signal, and the trap was there to prevent interference. It may be filtering out your FM band.It may also be possible that you're just overloading the FM antenna input with the amplified signal. Sometimes a signal can be too strong. Using a simple wire antenna will let you test the receiver by itself.
Other than connecting an antenna you shouldn't have to do any setup for FM reception. If you still get no stations at all when using a simple antenna, then the receiver may need service. But I doubt Circuit City would have sold a floor model that was defective, even at the very end, unless it was clearly marked as such and sold "as-is". I'm pretty sure you'll find that the receiver works with an antenna made for FM.
Sep 14, 2011 | Denon DRA-37
Antenna Wire Missing.
a length of wire similar to the original should work. The end bit may have been an F-connector. Just plug the wire into the middle of the connector on the back or the receiver. Adjust the position of the wire till you get a good signal.
Apr 20, 2010 | JVC UX-GP5 Micro Stereo Audio System Shelf...
Will I get good reception in a metal factory building I get spotty fm reception with my current radio
With old radios it worked to connect the antenna to some central radiator or (metallic) water pipe. Some old wire was used to connect it;
Feb 22, 2010 | Grundig S350 AM/FM/SW Radio
Car radio works on am but not fm
antenna is desconnected, find lead and reconnect .
Aug 11, 2009 | 1994 Chrysler LeBaron
JVC detachable face with auxillary input
You may have a bad antenna or antenna cable.
FM signals are measured in microvolts and are easily influenced by poor antennas or a mashed antenna cable.
Aug 12, 2008 | JVC AM FM CD DET FACE CAR STEREO
Antenna
OUCH! Cb antennas are cut to a specific frequency. FM antennas are also cut to a specific frequency. If you ground the antenna to a frame, you short out the antenna. BAD THING. If it is a 102" whip, you would have to cut off about 2/3's of the whip to work. If there is a cylinder at the base of the antenna You would only need about 7' of the whip sticking out for it to work right. Inside the cylinder there is a coil that would make up for the missing length of a 102" whip. I would suggest finding an old CB with FM built in like one of the old SEARS CB/FM receivers.
They had the electronics built in to compensate for the varience in the old sets.
Jul 30, 2008 | Cobra 29 LTD CB Radio
I have a sansui receiver 9900z with a broken antena,I think. The broken part was connected to the rear near the antena connectors. I am not sure if this is suppose to ba a antena or not? The set plays well...
The back of the receiver should be marked for FM and AM antenna connections.
Usually the FM antenna needs at least a dipole antenna or a "T" antenna. The part that broke off is probably just the AM antenna.
If you go to your local Radio Shack, you can get a cheap AM/FM antenna for under 20.00. (probably under 10.00)
After hooking up an antenna, you should be good to go.
I hope this helps.
Good luck.
Please remember to leave a rating if I have helped you with your question.
Mac =)
Mar 30, 2008 | Audio Players & Recorders
Teac CD-X8 CD Shelf System Logo
179 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
