Question about Locks & Locksmithing
I set my lock code on my master lock speed dial lock and it wont open to the combo and i wantto know if i can reset it or something
  • 784 Answers
If the lock is locked up and the combo that you set it to is not working then I would say that there might be a problem with the lock itself. I would suggest returning to the store that you bought it from and exchange it for a new one. if you want to try and get the lock open - you can try and progress the numbers, since you already have a combo set, this is a little easier then if you didn't have a combo at all. try setting the lock to the combo that you selected, starting with the first number - rotate the first wheel to the next number and try the lock and then to the next number and try the lock, when you get back to your original number, go to the next wheel and rotate that one around to every number ( testing the shackle everytime you get to a new number )---- repeat this process for the next two number wheels,, hopefully this will work,, but again it could be a broken wheel and I would just exchange it for a new one and start fresh.
here is an example of progression --- 1973 ( combo set )
1974,1975,1976,1977,1978,1979,1970,1971,1972 --
1983,1993,1903,1913,1923,1933,1943,1953,1963,---
1073,1173,1273,1373,1473,1573,1673,1773,1873---
2973,3973,4973,5973,6973,7973,8973,9973,0973 ---
I just used 1973 for an example -- if you want a more exact progression chart tailored to your combo, just let me know and I can write it up for you.
c...
Posted on Jan 03, 2011
How do I set up a Master Lock Key Safe with a new code
Open the box, with the existing combo, push the reset lever to the left and down, dial in your new combo, push the reset lever up and right to set.
Oct 04, 2014 | Master LOCK 5401D Combination Key Safe...
Reset combination abus 160/50
The answer can be found at http://www.lockwiki.com/index.php/ABUS_160: "The shackle can only be opened when the correct code is dialed and this is required in order to reset the code. With the correct code dialed in the user pulls out the shackle, turns the key on the right-hand side of the lock 90 degrees clockwise and sets the new code on the dials. The new code is in effect once the key is turned back to the vertical position."
Dec 09, 2012 | Locks & Locksmithing
I set a code in the master lock speed dial 1500id, and it will not open. I cannot reset the code and do not know how to get this open. I have read the other suggestions and nothing has worked yet. Anyone...
Try 2 options:
1. just squeeze the shackle twice and pull it out. This is in case you forgot to enter new combination.
2, Make the 2 combination together, the old and the new as one sequence. This in case you forgot to squeeze the shackle before enter new combination
Ity
Sep 06, 2011 | Office Equipment & Supplies
I messed up entering a new combo on my master lock speed dial thing, this is the second time I did this, how can I open my lock?
If you did not clear the lock before entering new code, you probably have a long combination: the old and new together. Squeeze the shackle twice, enter both codes as one new code and open.
Sep 18, 2010 | Office Equipment & Supplies
I need to reset the combo from the factory set 0000 code. Can you tell me how to do that?
first open the lock then at the back push up that wight thing to the r spot then put the combo you want than kiss a sexy feet and ***
Aug 26, 2010 | Master Lock 5400d: Portable Select Access...
On the master glo website it tells me - as a standard factory settings rule - that to open the lock i have to turn 3 times to the right to start - is that three full turns ?? could you explain how to open...
Let me see if I can help. I started out to write you an explanation when I found this video for you to watch...It explains better than I ever could.
CLICK BELOW and when you get to the site, scroll down the page on the right, till you get to " Combo Lock Training Tool " listed under " MASTER LOCK SERVICES " Click on Combo Lock Training Tool and a video will download that you can watch.
Hope This Helps,
RSMITH972278
P.S. PLEASE RATE MY ASSISTANCE
http://www.masterlock.com/residential/schoolcampus/glo.shtml
Nov 25, 2009 | Locks & Locksmithing
I forgot the master combo and now i cant get it...can i reset it?
I don't know if Master Lock will supply a combination or not but they can open it for you. There might be ownership issues that need verified. They don't know who's keys are in it and they don't know if the lock has been stolen.
Aug 23, 2009 | Master Lock 5400d: Portable Select Access...
Get the numbers master dial combination lock
Buy the identical lock if possiable and return as defective and they will reset. Otherwise odds or 1 in 999,000 differant combos. This is airport baggage security lock.
Please rate. Thanks
Feb 21, 2009 | Hardware & Accessories
I own a masterlock 5400d and left it open. I am ready to reuse it and thought I knew combo but I cannot get the reset button to depress so I can reset the code.b
you are out of luck. this actually happend to me. im really sorry
i heard you could get your code from master lock but i think that is only for standard dial locks :(
Jan 25, 2009 | Master Lock 5400d: Portable Select Access...
Locks & Locksmithing Logo
434 people viewed this question
Top Locks & Locksmithing Experts
ray gallant
Tom Chichester
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
