Question about Fujitsu fi-6130 Flatbed Scanner
HOW DO YOU TELL THE SCANNER TO SCAN ONLY ONE SIDE OF A DOCUMENT?
I would like to scan a document. I am using the All In One printer. I am using a brother printer with the printer, fax, copier, scanner, and PC fax. How to I begin to scan my document?
Hi Gerrid,
There should be a scan program on the pc or a scan button on the scanner itself. You can go to the brother website and see if you can find a downloadable program for this unit. Alternatively, if the scanner is 'seen' by the pc, you can search your Windows program for "Windows Fax and Scan" from which you can select "Scan", if the printer is seen it will do the job, if not, it will tell you "No Scanner found".
If the scanner is not found, you can go to "Device Manager" and do a scan of the pc to detect "Plug and Play" devices. This should find the scanner.
I hope this answers your query, Please rate and comment, Thank You Joe
Sep 07, 2011 | Computers & Internet
How may I scan a document?
Overview: To scan a document you need a scanner and scanner software, this answer will cover
the steps necessary to scan and save a document.
  1. You must already either own or purchace a scanner (eg: this model)
  2. Connect the scanner via the provided USB cord. Consult the manual for this step as necessary.
  3. Use the provided scanner drivers (Consult your scanner manufacturer's website to obtain) and scanner utility to preview the document.
  4. Adjust the settings as necessary and preview your document, if satisfactory enter a name for your scan and save it.
Mar 07, 2011 | Computers & Internet
My scanner is now adding a page with a black line that runs from top to bottom of the page and the actual document scanned is page 2. But the document is fine with no line through it. Does this mean that...
Check your scanner software settings. It is probably set at duplex ever time you start to scan. That is why you get two pages for every pass, the front and the back. You must place the document in the feeder in a way that the front side of the document is page 2. You may want to flip it next time you scan. So the main question is why there is black line from top to bottom? That is because there is a piece of dirt stuck on the glass of the scanner. You see, this scanner actually does two scanning when a page runs through it: the front and the back in duplex mode. So there are two scanners in side the box. The front page scanner apparently is dirty and needs to be cleaned with clean cloth and lens cleaner.
Aug 31, 2010 | Canon DR 3060 Path-Through Scanner
Could any one tell me how to scan documents in extra length?
If the document is too large for the scanner, then scan different parts of the document in two or more scans. Then open a Word document and paste the scan parts into this Word document - adjust the images to create the whole page.
Dec 31, 2009 | Syscan TravelScan 2300 Scanner
We have a Canon Scanner Canoscan N124OU. We have
hey try to crop it, once the scan image is been previewed the sides of the scanned image can be resize, try to resize it by using your mouse.
Oct 25, 2009 | Canon CanoScan N1240U Flatbed Scanner
IS760 How to scan a 2-sided document
Well, the right answer will depend on what equitment you using to scand. Let me know what you are using.
Jan 19, 2009 | Ricoh IS760 Flatbed Scanner
Driver scanner benq 3300u
If you have a BenQ Scan to Web 3300U, just plug in the scanner to your USB port on the computer and plug the power into the power bar. XP will recognize that you have connected the scanner to your pc. It will install the scanner immediately.. Go to MY PICTURES. The top option on the left hand side of the screen will be "to obtain pictures from a scanner or a camera". Click on this.. It will tell you that you have a flatbed#23 . Click on next. Using the preview button, scan the document. Using your mouse, make the scan box fit your picture or document. Then click on scan. Save your scan job . You can then view your scan job.
Dec 24, 2008 | BenQ Scan to Web 3300U Flatbed Scanner
My scanner is only scanning 3/4 of the page
My guess is to line up your document right, usually you will find some arrows on the scanner bed to tell you where the corner of the document goes. It's probably on the other side. Good luck!
Aug 20, 2008 | Fujitsu ScanSnap Manager
Scanning
you need an application software to scan a document first, install one from your manufacturer's CD and follw the direction carefully, or if your computer recognizes
go to start-program-accesories-then scanner and camera, see if your computer recognizes your scanner.
Aug 16, 2008 | HP Officejet 6310 All-In-One InkJet...
Fujitsu fi-6130 Flatbed Scanner Logo
167 people viewed this question
Top Fujitsu Office Equipment & Supplies Experts
Smidler
Level 1 Expert
Are you a Fujitsu Office Equipment and Supply Expert? Answer questions, earn points and help others
