Question about Hitachi CP-S335 Multimedia Projector
I follow all the steps to reset the filter time and lamp time with a new bulb but it will not reset any ideas
  • 488 Answers
This Projector is controlled by an internal microprocessor. Under certain exceptional circumstances, the projector may not operate correctly and the microprocessor will need to be reset. In such a case, please push the Restart switch by using a cocktail stick or similar and before turning on again, make the projector cool down at least 10 minutes without operating. Only push the Restart switch in these exceptional instances.
Posted on Jan 03, 2011
Why is the bulb light shows to change and it has new bulb?
I dont know if you skipped this step but you should reset the lamp usage time by selecting "Yes" for
Lamp Reset in the OSD Lamp tab. Page 48 on the instruction manual.
Sep 02, 2014 | Dell 1210S Projector
Failure to change Filter Time
unplug projector for about an hour, and then remove bulb, and filter, inspect areas for damage, also inspect it to make sure your inserting it correctly. put filter and bulb back in, put covers back on, then plug it back in. reset the timer. if you still have problems let me know.
May 06, 2008 | Hitachi Performa CP-RS55 Multimedia...
Turn off on screen message
follow this steps and fix it. God bless you
  • Secure the lamp cover and the air filter cover of the projector body if the projector does not power on. Ensure that the power cable is firmly connected to the projector and an active power plug. If the projector was turned off and then on quickly--let it sit for 90 seconds before trying to turn it on.
  • 2
    Replace the projection lamp if the projector will not power on or if the lamp indicator is flashing. Turn off the projector and let it sit for at least 30 minutes. Locate the lamp cover and remove or loosen the lamp cover with a screwdriver. Carefully remove the projection lamp from the projector housing using the handle, if available.
  • 3
    Place the new projection lamp into the projector housing and secure it to the projector. Replace the lamp cover and reset the lamp timer. Power on the projector to ensure the new lamp is working correctly.
  • 4
    Remove the projector from the enclosed area to allow air circulation if it constantly overheats. Place the projector into an open area and make sure there is no blockage for the ventilation holes. Unplug the projector for at least 45 minutes to allow it to soft reset.
  • 5
    Clean the air filter to allow the projector better air circulation. Turn off the projector and unplug it from the outlet. Remove the air filter cover and use a vacuum to remove dust from the area. If the filter is unable to be cleaned correctly or is damaged, then replace it. Pull the air filter from the projector and place the new one in the now empty slot. Close and secure the air filter cover.
Oct 28, 2013 | Dell 4310WX Projector
I heard a pop on the Toshiba rear projection TV (model #62hmx84) and immediately lost the picture
Sir the problem of your unit is the lamp try to replace it it is much better to use a gloves and wash your hand after replacing the lamp because this lamp contains mercury. follow this steps.
1. Unplug the unit to main ac outlet. Remove the bulb housing cover from the back of the TV. Using a screwdriver, carefully remove the cover to reveal the old bulb. Using a cloth, remove the bulb from the TV by first unplugging it from the wiring harness. Carefully rock the harness back and forth until it comes free from the bulb. Push in the bulb slightly and turn it a quarter-turn to remove it from the bulb housing.
2. Install the new bulb. Do not touch the new bulb with your fingers, as any grease or fingerprint from your hands will damage the tiny mirrors in the bulb. Instead, carefully handle the bulb using the cloth. Insert it into the bulb housing and secure the door. Test the unit. Plug in and turn on your Toshiba TV and make sure that the new bulb is installed properly and that the image looks crisp.
3.
Reset the lamp time counter. Each Toshiba TV comes with a lamp hour meter stored in its software. If you do not reset the lamp timer, the unit may stop operating when it gets to a certain time (refer to your manual because each Toshiba TV is slightly different). To reset your Toshiba lamp timer, turn off the TV, wait 10 seconds, hold down the "on," "menu" and "input" buttons on the remote at the same time, and turn the power back on. A yellow light should appear in the bottom corner of the TV indicating that the lamp timer has been reset.
Hope this help good day and best regards.
Sep 23, 2011 | Toshiba 62HMX84 62" Rear Projection HDTV
I have a InFocus IN35 w360, I have no idea how old it is, do you? The bulb had dimmed the other day and now it will not power up, is replacing the bulb the only thing I need to be aware of with this type...
More than 5 years old. After replacing bulb you have to reset the lamp hours as follows. To reset the lamp timer, navigate to the Settings>Service menu and select "Reset Lamp Hours"
Aug 15, 2011 | InFocus IN35 Projector
I have two issues with the pb8220 1. How do you reset the bulb hrs when a new bulb is installed? 2. Projects for about 10 seconds then goes black. The red bulb light comes on when the screen goes...
Reset the lamp hours as follows.
Press the Exit button on the projector for 3 seconds to display the total used lamp time. Press the MENU button on the projector during the lamp hour message. An adjustment message will appear. Press left or right arrow to reset lamp hours or press EXIT to leave.
sonsunny
Jul 09, 2011 | BenQ PE5120 Multimedia Projector
I have a Sanyo PLC-EX20 projector which shuts down after five minutes, what could cause this?
There are 2 possible causes.
The first may be due to overheating. Most projectors have a "air filter" that can be removed and cleaned. If it gets clogged with dust over time, the projector can't breathe and shuts down.
The second cause may be your lamps life hour clock. Most projectors keep track of the amount of time that their bulbs have been active. Once a preset # of hours has passed the projector will limit functionality until a new bulb has been installed AND the lamp life clock reset. Most projectors do not automatically reset the lamp life clock after a new bulb is inserted.
There should be instructions on how to reset the lamp clock in your users manual, and info on cleaning the air filter. Unfortunately I went to the Sanyo website and was unsuccessful in locating a PDF of the user manual for you.
Mar 04, 2011 | Sanyo PLC-XE20 (Chassis XE2000)...
Warning lamp blinks red. Tried new bulb just for kicks, but not the problem. Any ideas?
Time to clean the air filters. See manual how to clean air filters and reset the filter cleaning counter in the device.
Feb 16, 2011 | Sanyo PLC-XU101 Projector
I have a Panisonic pt-52lcx66 that won't come on.
OK AT THIS POINT IT COULD BE A BALLAST ISSUE IT SOUNDS LIKE IT'S NOT SENDING THE CORRECT AMOUNT OF VOLTAGE TO THE LAMP TO TURN IT ON, AT THE START IT NEEDS A KICK OF 15,000VOLTS TO TURN ON AND IF THE BALLAST IS WORKING CORRECTLY THIS WILL HAPPEN
HOPE THIS HELPS
http://www.fixyourdlp.com/2007/11/24/reset-your-panasonic-lamp-counter-after-installing-a-new-lamp/?click=48428
http://www.discount-merchant.com/how-dlp-works-like-magic-a/141.html?click=48428
Nov 19, 2009 | Panasonic PT-52LCX66 Projection Television
Hitachi CP-S335 Multimedia Projector Logo
123 people viewed this question
Top Hitachi Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Hitachi Office Equipment and Supply Expert? Answer questions, earn points and help others
