Question about Samsung WF337AAL Front Load Washer
Error code nf comes up even though it has water and filter is clean
2 Suggested Answers
SOURCE: nf error code sporadically
Tell me, do you notice the water filling and going against the "glass" door and going straight to the overfill trap bellow the door?
Let me know.
Posted on Mar 08, 2010
What does nf mean
NF = No Fill
Washing machine displays a 4E or NF Error Code
Last Update date : 2015.06.17
The 4E or NF error code indicates a water inlet problem or the machine cannot feed itself with water. Make sure the source water tap is turned on and check the water pressure.
To troubleshoot this error further, follow these steps:
Note: The steps below generally apply to all types of Washing Machine (Top Load, Front Load, Washer and Dryer Combo)
Step 1: Turn the machine OFF.
Step 2: Turn the water tap OFF.
Step 3: Remove the water hose from the tap and dispense the water into a sink.
Step 4: Remove the entire hose.
a. Check for Kinks.
b. Check for Clogs.
Step 5: Check if water supply is good.
Step 6: Check, remove, and then clean the first mesh filter (Brush under running water).
Step 7: Check and clean the second mesh filter.
Step 8: Test the unit by turning it on and by performing a normal wash cycle.
Step 9: If the issue persists, unit may require service. Inquire about the Warranty and Service Booking procedures for the unit.
May 06, 2016 | Washing Machines
What does nf code for a Samsung front load washer mean?
Water Inlet problem.
a. Check for Kinks.
b. Check for Clogs.
Washing machine displays 4E or NF Error Code
Dec 02, 2015 | Samsung Washing Machines
NF error code during rinse cycle only.
If the unit was working fine before bearing repair, then I lean toward wiring issue. Do a visual inspection of the water valve and all the wires to it. One might have been put in wrong place. If wiring is correct, then maybe a bad water valve. The water valve has multiple solenoids and the one for rinse might be bad. I still think its a wiring issue. Good Luck!
Nov 23, 2015 | Samsung WF337AAL Front Load Washer
Error code of NF (no fill) on samsung top load washer (WA422PRHDWR/AA) even after checking lines for restrictions and ensuring clean line filters (red and blue). Now, when it does work, it will only do a...
Put the temp select switch on HOT, start machine. If water comes out check the flow amount. If no water flow, replace inlet water valve. If there is water flow switch to COLD, start machine. If water comes out check the flow amount should be approximately equal or slightly more than flow on HOT. If no water flow, replace inlet water valve. Move selector to WARM, start machine. Now there should be twice the flow of water than there was with HOT and COLD temps. I suspect it is the HOT side of inlet water valve that has failed because machines usually rinse with COLD water.
Jan 20, 2013 | Samsung WA422PRHDWR 4.2 Cu. Ft. VRT Top...
FRONT LOAD WASHER samsung model WF338AAW/xaa
please see the cause and proceed to test the water inlet valve can be defective and replace it.use the common sense,see the diagram
God bless you
Water Supply Error occurs when water level frequency does not show changes more than 100Hz or water is not supplied up to the preset water level after 10 Minutes or more at the time of initial water supply. The error status can be cleared by turning the POWER switch OFF and back ON.
Sep 19, 2012 | Washing Machines
Nf error code
The NF error codes stands for no fill. This is usually caused by hard water deposits in the fill valve screen. Youl will need to disconnect the water lines to the back of the washer and clean then out thoroughly. This should solve you problem, please rate my response if it helps you:)
Dec 02, 2010 | Kenmore Elite 45986 Front Load Washer
I got an NF code today when I went to do laundry. We recently had a three day power outage and have sediment from the well still coming through our pipes. Could this be clogging the fill line? How do I...
NF means "not filling". This means that either there is no water getting to the machine or it's at too low a pressure.
Given the information regarding sediment it strongly suggest that the water inlet filter is blocked. Although I'm unfamiliar with your exact model, you will usually find that when you unscrew the flexible inlet hose from the spigot on the back of your machine there will be a gauze filter inside the spigot. Remove and clean it and consider fitting an in-line external hose filter to the inlet hose. Before refitting the inlet hose, ensure that there is a good strong water flow through it.
If I've made the correct diagnosis you should find that the code has gone when you reconnect your washer and turn to both the water and power supplies and turn it on once more.
If not, then please report back for alternative suggestions.
Please take a moment to rate my answer.
Mar 01, 2010 | Maytag MAH6700AWW Neptune Front-Load...
How do i clean the debris filter
NF = No Fill Error
Check your hose inlet strainers.
Be sure they are free of contaminants.
Turn off the water supply - remove the hose.
On the side of the machine is a small metal strainer which catches debris in the water line.
Remove it using a small screwdriver and clean it.
Otherwise - your water valve is likely failed. (or the CCU not giving it the signal to open) so further testing will be required.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 08, 2009 | Kenmore Elite 45986 Front Load Washer
Nf error code sporadically
Let me know.
Dec 30, 2008 | Samsung WF203ANW Front Load Washer
MAYTAG NEPTUNE ERROR CODE NF
NF is a NO fill..
1 check that the water is turned on.
2 check the water pressure
3 check the nose filter screens
4 check the water valve is opening
5 check the conection on the water valve to the control.
6 replace control board
Oct 19, 2008 | Maytag Washing Machines
Samsung WF337AAL Front Load Washer Logo
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
