Question about Kenmore 23822 Top Load Washer
Put to many towels in and now it will put water in but no spin
  • 43 Answers
If motor revolves (the heard noise) , but drum no, that you necessary to change the belt.
Posted on Jan 03, 2011
Washing machine won't go to spin cycle if there are towels in it
Washing machines have trouble if they are overloaded and the load gets out of balance. This occurs most often with towels. Open the machine and lift the towels out and put them back in evenly to get the load to finish. You will see how heavy they are when full of water. In future, try running with a few less towels and see if it works ok. You have found the other 'fix' by draining and running spin only which probably resettles the load.
May 11, 2017 | Washing Machines
How much water do I use when using a front loader say 5 items of clothes with 3 large towels and two sweater
many front loader washing machines don't have different water level options since they cycle the water differently than the "tub-o-soap" upright washers. The best answer I can give, if there are different fill settings, is to put the laundry in the machine and see how full it looks. Err on the side of overfilling, since the towels will soak up a lot of the water, and unless the sweaters are delicate or inclined to stretch out badly, I'd opt for an extra spin cycle to get rid of the excess water soaked up by the towels and sweaters.
Mar 21, 2011 | Washing Machines
WHIRPOOL washer model LSR8010PQ0, WHEN LOADED WIT...
If large items in the machine create an imbalanced load the machine is designed to switch off...Towels are notorious for doing this because they hold so much water. Jeans don't soak up much water. Wash towels with towels alone and the problem should be reduced....Good luck....Nomess
May 16, 2010 | Washing Machines
GE Front load washer spinning too slow????
A couple of things come to mind,if the micro-processor senses the load is out of balance enough, it will control the RPMs(reveloutions per minute) or slow it down in order to avoid damage to the suspension system, so readjusting the spin speed manuallly probably would help. Although that machine should be able to handle 9 large towels easily! Next thing, have you cleaned out the trap inside the lower access panel, if it is restricted you will have draining problems. Good luck !
Jan 07, 2010 | Kenmore 22422 Top Load Washer
Kenmore 80 Series Mod:110.23832100 top load that with heavy clothes (towells robes) won't drain and leaves excessive water after spin cycle. Everything appears to function otherwise, no odd noises. No...
When you are putting the heavy clothes (towels robes) the sleeves of the towels will come out easily and get stuck in between the drain out valve so it will not sent the water out properly please avoid heavy clothes(towels robes) try to give a normal load
Dec 23, 2009 | Kenmore 15864/15862 Top Load Washer
The washer does not spin during washing cycle or drain & spin cyc
I can a very simple part called the motor coupler...you can find the part at www.repairclinic.com. It costs 13.95. I am fixing my washing machine today, as this happened before and was the answer. Goodluck
Apr 11, 2009 | Kenmore 46462 Front Load Washer
Laod with bath towels won't spin out
hi, you may find that the towels when wet are to heavy for the belt to grip the drum if it spins with normal clothes in you need to reduce the load when you wash your towels, hope this helps.
Feb 11, 2009 | Magic Chef CAV4000AWW Top Load Washer
My new washer did not spin out the water
if its a new washer call and have them trade it out for another one.
Dec 31, 2008 | Samsung WF337AA Front Load Washer
Kenmore 23822 Top Load Washer Logo
13 people viewed this question
Sal DeAngelo
fordexpert
 Brian Main
Brian Main
