Question about Kenmore Refrigerators
Compressor makes brief but loud rattling noise when it shuts off. Other than that the refrigerator is operating properly.
My ge fridge fresh food side is good but my freezer side want freeze but is making some ice. whats wrong
Posted on May 15, 2011
  • 43 Answers
This is a normal functioning(working) the compressor.
Posted on Jan 03, 2011
    Problem Solver:
  • 8 Answers
There are rubber shock mounts between the bottom of the compressor and the fridge frame, if any of these are worn it can cause that sound. Sometimes the condensate tray is what is actually making the noise; when the compressor powers down it vibrates and causes the metal tray to shake, maybe bumping the side and creating the noice. Pull the fridge off the wall and take the cover off the back of the fridge. Be careful, there's some voltage going through there. Locate the condenstae tray, shake it gently and see if it's loose. Give the compressor a gentle push and see if that makes the sound. Usually it's one of those two things and not an actual problem with the unit. When you touch the compressor, be careful, they can get pretty hot.
My wine refrigerator is now operating making very loud noise, what is causing this?
Make sure there is nothing loose that is just rattling. If not, there are only a couple of things that will make a lot of noise. There is probably a cooling fan on the unit. It may be dirty or is wearing out. The other would be the compressor. I don't know how large your wine fridge is, but you probably just need to replace it if the compressor is bad.
Jun 13, 2017 | Refrigerators
Why does my whirlpool refrigerator makes a very loud clunk noise when it turns off
Try looking for any pipes that are rattling against the cabinet , if not, I'm afraid compressor problem.
May 02, 2014 | Whirlpool 25.6 cu. ft. Side-by-Side...
Switch on compressor clicks on loudly and compressor makes a rattling noise when it runs.
if your sure it is the compressor relay that is making the noise then i would suggest replacing it fast... it may be getting weak and will leave the milk spoiling soon... another possibility is that the compressor it self is starting to get harder to crank and or the compressor itself is getting ready to go out...you may be hearing a rattle because sometimes it is not starting and the rattle is the compressor vibrating because of a weak start relay... hopeful thats the case if it constantly is rattling then i would say the compressor valves are starting to fail adn won't be long before you are shopping for a new unit or a appliance repair man ...good luck to you...lets hope you caught it early enough ....
Feb 11, 2011 | Maytag MZD2766G Side by Side Refrigerator
The compressor works fine, but when it shuts off after cooling the refrigerator it rattles very loud. Any way to fix it or do I need a new compressor?
That's usually mounts inside the compressor. It could still last awhile so if you can put up with the noise just wait for it to quit before replacing the compressor or getting a new fridge.
Mar 21, 2010 | Kenmore 57029 Side by Side Refrigerator
My refrigerator has a loud rattle in back when the compressor (i think) shuts off. when i pulled fridge away from wall i can simulate the noise by shaking what looks like an expansion tank. Sounds like a...
more than likely you probably have a bad compressor foot mount . It is a rubber cushion between the compressor and the refrigerator base frame. they wear out, allowing the compressor foot to contact the mounting base which would be metal to metal contract.
Mar 13, 2010 | Refrigerators
Constant loud noise when frig turns on/comes from bottom
when the compressor is running unplug the ref. and if you hear the noise coming from the compressor then
a ballance spring may be broken inside the compressor.
The compressor will run normally with a broken spring it will just be annoying when it shuts down.
Jan 16, 2010 | Roper RT21AKXKQ Top Freezer Refrigerator
Why is there a loud knocking noise when my refrigerator shuts off? The volume of the noise differs each time that the unit shuts off
HI. Just so you know, Hissing and popping is normal on frost free refrigerators, it is the defrost heater, in this case. I would check these following areas to address any other abnormal noises.
If the level of the unit is not adjusted to proper specs, this will create an unstable operating condition, causing many noises to emit from the units structure. inspect the unit for proper level. adjust if needed. Next will be the drain pan. Once removed for cleaning, the pan must be replaced in position correctly. If not, the pan will rattle against the compressor, causing a ping or rattle.Simply reposition the tray if this is the case. The third possible issue will be the condenser fan. The condenser fan is located behind the refrigerator. It may be necessary to remove an access panel to reach it. This fan has a shroud, and if the fan blade becomes warped, it will rub against the shroud, causing noise. This fan blade is whole,and it can be removed and replaced if this is the case. Ok, the fourth problem spot will be the evaporator fan.
The evaporator fan is located at the back of the freezer. It may be necessary to remove obstructions such as the contents of the freezer, freezer shelves, ice maker and the rear inside panel of the freezer. The rear panel may be held in place by retainer clips or screws. Remove the screws or depress the retainer clips with a small screwdriver. Check the fan for warped blades. if the blades are warped or mis-aligned, replace it. This fan also is protected by a shroud as well, and it will make noise if the fan blade is damaged.
Last, i would move on to the compressor mounts. This is the most common spot for noise overtime. The compressor sits on rubber mountings. Those rubber mountings are designed to absorb vibration from the compressor. As the mountings age, they can become hard or disintegrate. When this happens, the compressor vibration is transmitted to the refrigerator structure and it can cause noise.
The compressor is located in the rear. It may be necessary to remove an access panel to get to the compressor.
Locate the compressor and remove the screw or retaining clip of just one of the compressor mounts.Using a pry bar, lift up the compressor enough to slip out the rubber mount. Inspect the mount for deterioration. The rubber should be firm but not rigid. If the mount is crumbling or hard, it should be replaced.
This concludes the inspection procedure. Follow carefully, and replace any failed or damaged device.
Nov 27, 2009 | GE GTS22KBP Top Freezer Refrigerator
Makes a shuddering noise when compressor turns off
It sounds like the suspension spring has broken inside the compressor so when it shuts off it rattles against the case. If the refrigerator is still operating normally I would recommend not repairing it. It could run for years like this without any further problems and a compressor change would be very costly.
Feb 24, 2009 | Kenmore 64254 / 64252 / 64259 Top Freezer...
Frig makes a very loud booming noise/ratteling what is the cause?
The noise is coming from the compressor and is a result of a broken support spring inside the compressor. When the unit shuts down, the inner casing rattles against the outer casing because the spring is not there to keep them apart. The only fix is to replace the compressor but otherwise it is just bothersome.
http://tclaundryrepair.com/home
Feb 19, 2009 | Kenmore Refrigerators
Refrigerator brief loud knock when compressor shuts off
The compressor you see is actually the outer shell, inside of which is a refrigerant pump (ie:compressor) which is on internal support springs. When the unit turns off, the momentum of the internal parts can sometimes knock against the outside of the compressor case. The only "fix" would be a new compressor. In the real world, the fix is to live with it. It's generally not an indication of immenent compressor failure and most likely will run many more years with no problem. Note: if you put your hand on most compressors (even new unused ones) and give them a shake, you will hear that noise.
Aug 29, 2008 | Refrigerators
Refrigerators Logo
197 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
