Question about Mitsubishi WD-52525 52" Rear Projection HDTV
I have a Mits rear proj screen ws-55613 replced the 4 caps on the DM and still have th fast blinking green LED any Ideas?
Posted on Jan 04, 2011
SOURCE: Mitsubishi TV WS 65869 blinking Green Light
This is a common problem with Mitsubishi rear-projection TV's.
See my post at http://www.highdefforum.com/showthread.php?t=58189
or email me at pds318@verizon.net. I can send you the instructions I used to successfully repair my Mitsubishi WS-55613 which was doing the same thing....
Posted on Dec 08, 2007
SOURCE: Mitsubishi dlp tv green timer light blinking
timer light keeps blinking tv does not turn on
Posted on Nov 29, 2008
SOURCE: Mitsubishi DLP, green blinking timer light, tv won't come on,
This Chassis has been known for a slew of Capacitors failing throughout many of the Circuit Boards. The best way in my opinion to fix the set is to send the Chassis Assy to Mitsubishi for them to rebuild it. Some folks have has some success in replacing the bad Capacitors in the Power Supply, the DM Board, and the Format Board to get the set to turn on. These Capacitors are identifiable because the tops of them are bulging up.
It is a difficult set to work on and disassemble, this is Mitsubishi's Customer Service Number in case you need assistance. 1800-332-2119
I hope this helps,
Sky Assoc
Posted on Feb 08, 2010
Nov 22, 2011 | Mitsubishi WD-57731 57" Projection HDTV
Jan 08, 2008 | Mitsubishi WS-55813 55" Rear Projection...
None TV is powered off. Normal operation.
Green TV is powered on. Normal operation.
Green 1. TV just plugged into AC outlet.
Wait until blinking stops before turning on (approximately 1
minute). Normal operation.
2. AC just restored after power failure.
3. TV Rebooting after System Reset was
used.
4. TV Rebooting after power fluctuation
or receiving abnormal digital signals
from digital channel, or digital device.
5. You have begun the procedure to
update software from an authorized
flash memory device.
For detailed information, see the instructions that accompany
the authorized software update. IMPORTANT: Do not
use unauthorized software at any time.
Green TV just powered off and lamp is
cooling.
Starts to blink 30 seconds after turning off TV. TV can be turned
on before blinking starts or after blinking stops, but not while the
indicator is blinking. Normal operation. hope it helps regards shaun
Green TV powered off and auto-on timer is set. Normal operation. TV can be turned on at any time.
Dec 06, 2010 | Mitsubishi Televison & Video
May 27, 2010 | Mitsubishi WD-62525 62" Rear Projection...
Mar 22, 2010 | Mitsubishi WD-62525 62" Rear Projection...
Aug 01, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Jun 29, 2009 | Mitsubishi WD-52628 52" Projection HDTV
May 09, 2009 | Televison & Video
Jun 24, 2008 | Mitsubishi WS-55513 55" Rear Projection...
May 07, 2008 | Mitsubishi WD-52525 52" Rear Projection...
203 people viewed this question
