Question about Savin Office Equipment & Supplies
Is there any way to reset the thermal fuse - it was just working fine, and then it said paper jam, now I get the SC-542 error code - how do I reset it first or get in the setup mode to reset the jam counter at least
  • 62 Answers
Firs you go to SP mode while pressing
Starting SP Mode
1. Type the keys as follows:cleare mode button which appers in yellow color and continue the numbers 107
2. Press the cleare button which appers in red color and hold it down until the SP-mode menu is displayed (about 3 seconds) then switch OFF the machine and switch ON this process re-set the code -thanks
1 2 3
4 5 6
7 8 9
0 #
Posted on Jan 06, 2011
Ricoh sp 210su service call sc559 problem
Code
SC559
Description
Fusing Unit Third Jam Error (Fatal Error)
Causes
The exit sensor failed to detect the leading edge of the paper within the prescribed time and triggered a jam alert.
Remedy
• After this error has occurred three times, the machine will shut down automatically and cannot be re-started until the machine has been serviced by a service technician. • Check the paper transport path for any physical obstructions (paper scraps, etc.) • Make sure the fusing unit has been installed correctly • After servicing the machine to solve the problem, the service technician must execute a "Fuser SC Reset". Otherwise, the machine will continue to issue this SC code and cannot be operated.
Apr 10, 2018 | Office Equipment & Supplies
Fix problems for error code sc 542 for ricoh 3510dn printer
1. Switch machine off.
2. Hold up and down arrows in while switching the machine on.
3. Select Service menu and OK.
4. Scroll to 5.Mode and OK.
5. Scroll to 810 SC/Jam reset and press OK.
6. Execute
7. Switch machine off and on again.
If code does not reset you would need to replace the Fusing Unit and follow the above steps again.
Jun 01, 2016 | Ricoh Aficio SP 3510DN
How can I correct error SC559?
  • ? Afterthiserrorhasoccurredthreetimes,themachinewill shut down automatically and cannot be re-started until the machine has been serviced by a service technician.
  • ? Checkthepapertransportpathforanyphysicalobstructions (paper scraps, etc.)
  • ? Makesurethefusingunithasbeeninstalledcorrectly
  • ? Afterservicingthemachinetosolvetheproblem,theservice technician must execute a "Fuser SC Reset". Otherwise, the
    machine will continue to issue this SC code and cannot be operated. ( "Executing Fuser SC Reset")
Feb 19, 2016 | Ricoh Aficio SP 100SF e Laser...
What is error code SC542 for ricoh aficio 9005?
Ricoh Aficio MP2510, 3010 Error code sc542 on Lanier ...
? 6:08
https://www.youtube.com/watch?v=58MQVyjfDyg
Sep 3, 2013 - Uploaded by Used .Copier
Are you getting Error Code sc542 on your Ricoh, Lanier,Savin or Gestetner copiers? ... Ricoh Aficio 1022 ...
How to reset Ricoh Error Code sc542 sc546 sc548 problem ...
? 2:41
https://www.youtube.com/watch?v=3CnGl1Ytp34
Sep 21, 2015 - Uploaded by Copier Liquidation Center
How to reset Ricoh Error Code sc542 sc546 sc548 problem ...Ricoh Aficio copiers : AFICIO 1013 F
Dec 02, 2015 | Ricoh Aficio Office Equipment & Supplies
Sharp photocopy machine showing error code Sc 542
SC 542 Basically the machine is telling you that the fuser did not reach its target temperature in a specified amount of time. In normal circumstances this code will appear if the thermistor is not maintained or replace periodically or in abnormal circumstance the heat lamp blew. This is a Service Tech reset code. Once the error is detected, the printer is toast until you manually clear the error from the keypad. Even though the printer is physically fine, it won't come ready until the prior error condition is cleared. basically you will have to care a service tech to clear it
Aug 03, 2015 | Sharp Office Equipment & Supplies
Ricoh c8 problem solution
hi sir help me rico sp 100su c8 error whats the problem
May 19, 2014 | Ricoh Aficio SP 100SU e Laser...
Error sc 542
this is a fusing error
change the set of thermisters in the fusing unit
Jan 20, 2014 | Ricoh Aficio CL3500N Laser Printer
Sc 542 error code
press clear (yellow) and press 1,0,7 and press and HOLD the stop button 5 secs. (red) press 1 when u see the copy sp mode and press 7 (datalog) and press ok, look for the sc/ jam counter reset. press the execute 2x. turn of the machine in the main switch (orange switch on the lower front side) the shortcut mode is by pressing 7807 na press execute
May 22, 2009 | Ricoh Aficio CL7200 Laser Printer
Ricoh Aficio MP 2510 SC 541, SC 542 Errors
To clear level A SC codes such as this SC541, you need to
Enter SP mode, and then turn the main power switch off and on, only.
Please check if the thermistors are the proper ones and are installed correctly in their position properly.
This is also useful for SC542.
Please check the thermostats and fusing lamps for open circuit.
Good luck and please rate me, thanks.
Jan 17, 2009 | Ricoh Office Equipment & Supplies
217 people viewed this question
Top Savin Office Equipment & Supplies Experts
quennie732
Adorjani Laszlo
Don  Farrell
Don Farrell
Are you a Savin Office Equipment and Supply Expert? Answer questions, earn points and help others
