Question about Harman Kardon SoundSticks II Computer Speakers
My speakers were working fine. Then I decided to move them to another room. I hooked them up and now only a low buzz comes from the speakers. A blue light is on in the base of the speaker unit. Can you help me to get them to work again, please?
    President:
  • 2,047 Answers
Speakers are quite difficult to get damaged. When you hook up speakers and instead of the expected output something else is gotten then it simply means that the speakers are not properly hooked up.
Common mistakes in hooking up speakers are mixing up the wires instead of connecting the brown ones to brown you mix them up with the silver or white.
First check to ensure that your speakers are properly connected to each other then also check that you have put them in the right port for your computer.
Hope this solution has been helpful?
Posted on Jan 03, 2011
The sound on my garmin zumo 550 is not working right it has been working fine. But this morning when I hooked it to my Harley ultra classic it was reel low upon further check it was only coming through...
sounds like the Audio patch cord, i had around 5 of them that do that ...sometimes i hear the music thru one speaker, cracking noise sometimes it works when the wire is twisted, but i would try a new patch cord first.....my patch cord worked fine on some stereo units others break up
Nov 07, 2010 | Garmin zumo 550 GPS Receiver
Constant Buzz coming from SX-255r
Power source harmonics. Or its power supply regulation. Check also if input line is touching something.
Apr 03, 2009 | Pioneer SX-255R Receiver
Moving TV's from one room to another
tSounds like you have a PIP window open. Is everything else black excpet for that small "internet box?"
Mar 20, 2009 | Vizio L32 32 in. LCD HDTV
Static humming from speakers
I've had the same problem and I think I've solved the problem. I noticed that they were fine when I first turned them on. After a awhile the blue light would flicker and static would start. I figured there might be some connection so I unplugged my speakers, took off the thin rubber from bottom and removed the 3 small screws. I carefully pulled the circuit board down, spotted the led light and snipped it off. I put everything back together, double stick taped the rubber piece back on, plugged it back in and have been listening static free for hours. Yippee, no more room full of screaming babies (that's what static sounds like to me)! By the way, I'm no expert. I just have a very strong aversion to static.
Good luck,
Beth
Mar 14, 2009 | Insignia 2.1 Speaker System (3-Piece)
The speakers don't work anymore.
1)Please Check the Power Cord.
2)Please Check the Wire that goes to Computer is working fine.
Jan 21, 2009 | Logitech X-530 Computer Speakers
No sound
Sounds like you have missed the wire which connects them to your pc (or to each other)
Mar 21, 2008 | Logitech X-230 Computer Speakers
Unwanted sound from subwoofer.
switch your subwoofer off from the socket for at least 30 minutes and check if the noise is still there,if its still there open it and play a movie then press it lower if the sound stops then you will have to put some toilet papers at the back of it ,thats what I did to mine.
Feb 19, 2008 | Logitech S200 Computer Speakers
Distortion/noise and buzz in front left speaker
Try to see if the reciever will make the buzzing/noise without anything connected to it except power, and speakers. Tune into a local radio station and see if the noise continues. If the noise has stopped, then you know there is an issue with the player or cable.
Dec 28, 2007 | Onkyo TX-SR503 Receiver
How to add more speakers?
In the end I biwired the speakers and that's worked fine.
Aug 12, 2007 | Denon D-M71DVS System
Buzzing speakers
It is merely degradation of the connection. Try unconnecting the speakers, cleaning the tips a bit, replacing them in, removing, recleaning, and then replacing a final time. This should get some scoring off of the connection... Aside from this, a new set of speaker wire is the best solution but just let me know what you decide on! Hope this helps!
Jul 26, 2007 | Sony MHC-ZX70DVD System
Harman Kardon SoundSticks II Computer Speakers Logo
100 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
