Question about Samsung Digimax S500 Digital Camera
Battery compartment I cannot get the rechargeable battery out of the camera without a major struggle and I have to use tweezers or long fingernails.
    Genius:
  • 2,985 Answers
There should be a relase spring catch so that a gentle 'push'
will releas the battery and it pops up.
Posted on Jul 14, 2008
Cant get the battery door to open
Push the release lever(gray) toward rear of camera. At the same time place your fingernail under the cover in the middle of the camera and slide the compartment to the outside. The battery compartment cover can now be hinged upward per the diagram in the instruction manual.
Jan 12, 2013 | SVP Aqua Wp 6800 Underwater 18 Mp Digital...
My canon power shot sx10is wont turn on
yes that good very well be the problem. if it is the problem then most likely it has been damaged some how.
Jun 05, 2012 | Canon PowerShot SX10 IS Digital Camera
I just received this dv002 camera and can't get the battery compartment open. I'm afraid if I force it open, it will break.
You do not need to open up the battery compartment, as it is a built-in rechargeable battery. Use the cable included to recharge the camera.
Jun 18, 2011 | Cameras
My digicam won't start
There could be a couple of reasons why your camera would not start.
Before considering it to be defective, verify that the camera has batteries inside and that these batteries are charged. To do this:
  1. Locate and open the battery compartment.
  2. Identify the type of batteries needed and purchase new ones OR
  3. Recharge the batteries with the recharger provided.
  4. Place the new/charged batteries inside, closing the battery compartment.
  5. Try to turn on the camera.
If the camera still doesn't work after verifying that the batteries are in order, remove the memory card and any other accessories that the camera may have and try turning it on again.
If still the camera won't turn on, one last step can be performed if and only if your camera uses standard batteries (AA or AAA). If this step is performed incorrectly, you could short circuit the batteries, which would discharge them. This procedure will not damage the camera if performed correctly. Please pay attention and do exactly as explained:
  2. Remove the batteries.
  3. Place the batteries back inside in the opposite direction than the one indicated. If the position indicated is for the positive end first, place the battery with the negative end first. Do this process for all the batteries.
  4. Close the battery compartment.
  5. Attempt to turn on the camera. It will not turn on, but this step is necessary nonetheless.
  6. Open the battery compartment.
  7. Remove the batteries.
  8. Place the batteries in the correct position according to the indication.
  9. Close the battery compartment.
  10. Attempt to turn on the camera.
If the camera still does not work, it is likely that it is defective. At this point you should take the camera to an authorized service center.
Mar 30, 2011 | Cameras
Just replaced batteries camera is brand new and wont turn on
Remove the backup battery. You will see a rectangular insert inside cover of battery compartment, closest to the hinges, pull out using fingernail. Close battery compartment with batteries inserted, turn on. Turn off open battery compartment replace backup battery. Reset date and time.
Jul 18, 2010 | Canon PowerShot A490 Digital Camera
Can i plug my nikon coolpix s570 into my computer to charge battery
No. You must either remove the battery and charge it in the MH-63 charger or use a nikon coolpix s570. The best bet is to get a second spare battery so that you can recharge a spent battery.
Check
http://www.batteryengine.com/accessories/nikon_coolpix-s570_digital-camera_battery.htm
Please rate this solution. Thanks.
Feb 16, 2010 | Nikon COOLPIX S570 Digital Camera
Sony t90 got wet with a water splash during swimming now i cant take pics and there's "E:62:02" Constantly flashing.can u pls help me?
Open the battery compartment and remove the batterys and the memory card. Completly dry the camera as best you can without further damaging it. Let it set open up like this for about 5 to 7 days. Recharge the battery and reinsert the battery and memory card. If you have to reinsert the battery to recharge the battery, do so. If it still doesn't work, contact the factory for a repair estimate.
Nov 13, 2009 | Sony Cyber-shot DSC-T90 Digital Camera
Change the batteries message even with new NIMH RShack batteries
The solution is to change the small 'date/time' battery. You can have the regular batteries as charged as you like, it won't make any difference. The tiny date/time battery is in the same compartment as the regular batteries, on the opposite side of the hinge. Extract it with a fingernail, it is situated on the left hand wall of the battery compartment (when the camera is inverted and the compartment open).
Jun 12, 2009 | Canon PowerShot S2 IS Digital Camera
Put rechargeable battery in the wrong way and it is stuck!
carefully remove the battery or take it to repair center... tweezers may work but you have to be careful to not damage the battery
May 21, 2008 | Olympus Stylus 720 SW Digital Camera
Samsung Digimax S500 Digital Camera Logo
16 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
