Question about Amana Kitchen Ranges
Need part number PS79785 Electronic Clock Control Assembly. The circuit board burned out. Model #ACS335OAS.
EllaWatson25
  • 725 Answers
SOURCE: electronic control touch pad not working
This is your electronic control board that needs to be repalced on this unit. GE Profile is a great brand and it is easy to repair, also.
We provide part removal/installation instructions for our customers when you purchase your parts from us.We also ship parts overnight to assure that you get your oven repaired right away.
Please contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
from 7 AM until 9 PM CST. We look forward to getting you cooking again soon.
Thanks, Ella
Posted on Nov 17, 2009
  • 146 Answers
SOURCE: Smelled like burnt board
Just so you know. Bosch has a 5 year warranty on any printed circuit board (excluding labor) so you pay only for labor charges. They have a 2 year warranty (again excluding labor) on the entire dishwasher. I am leaving a copy of my owners manuals warranty information I hope this helps.
Extended Limited Warranty: Bosch also provides these additional
limited warranties:
• 2 Year Limited Warranty: Bosch will repair or replace
any component that proves to be defective in materials or
workmanship (excludes labor charges).
• 5 Year Limited Warranty on Electronics: Bosch will repair or
replace any Bosch microprocessor or printed circuit board if it
proves to be defective in materials or workmanship (excludes
labor charges).
• 5 Year Limited Warranty on Dish Racks: Bosch will replace the
upper or lower dish rack (excluding rack components), if the rack
proves defective in materials or workmanship (excludes labor
charges).
• Lifetime Warranty against Stainless Steel Rust Through:
Bosch will replace your dishwasher with the same model or
a current model that is substantially equivalent or better in
functionality, if the inner liner should rust through (excludes
labor charges). Bosch will replace the stainless steel door if the
door should rust through (excludes labor charges).
The foregoing timeline begins to run upon the date of purchase, and
shall not be stalled, tolled, extended, or suspended, for any reason
whatsoever.
Repair/Replace as Your Exclusive Remedy: During this warranty
Posted on Jan 15, 2008
aborcass
  • 2651 Answers
SOURCE: Maytag Nepture MAH5500BWW burned control board
ummmm, honestly ive never replaced just the board(im an authorized maytag servicer) so our replacements have always been new, and in this case the repair kit containing both board and motor. that being said, i cant see a reason as to why you couldnt relace just the board itself, ,Ireally never found the reason why the board would burn out, but, as far as repair kit im certain that they were trying to get all circuit boards and motors back to only one model, instead of having 5 or six different boards andmotors, this will bring them all to the most recent board and motor, never was an issue with themotor, jusat that you couldnt wire in the new board without the neew wiring. As long as its the same board i cant see why that wont work. as far as the "wax motor" that was a seperate issue burning out the Top control board, total seperate then your problem,., dont really see an issue with installing your "used board"
Posted on Apr 08, 2008
SOURCE: singer electronic control sewing machine model number 4562
http://www.singerco.com/accessories/
You can download the instruction manual for free instantly.  Or pay $15 for a hard copy.  Some attachments are available for purchase on the website, others you can purchase at JoAnn Fabrics.  Good Luck.
Posted on Nov 29, 2008
szanti
  • 36 Answers
SOURCE: How to identify the model number of a Ademco Alarm
on the top of the circuit board there should be a green lable with the writing P10 P15, P20.
P15 is a Vista 15, P20 is a Vista 20. You can find more info on honeywellsecurity.com.
Posted on Nov 20, 2009
Testimonial: "Thank you Szanti & Fixya...I received information from Honeywell support that the board/model is Ademco Vista 12. Regards Edward "
The broil and the bakery light is on but the clock is not on please help
Hello. If the oven control is an electronic version, then the main control board is defective and must be replaced. This is assuming that the main control board has the clock display all-in-one. Some ovens have a separate user interface panel with a display and the oven control board either mounted to it or close by. I really need the brand/model number to help you more accurately.
Aug 15, 2015 | Kitchen Ranges
What does the error code F1 E1 mean and how can i fix it
Hi.
F1 - E1 means: EEPROM Checksum error. The EEPROM is a memory chip located in the ERC (control module). The problem is communication error with the EEPROM
1. Disconnect power for at least 30 seconds.
2. Re-apply power and observe for at least one minute.
3. If code re-appears, replace control board (also called ERC or clock).
Note: Applies to all F1-Ex codes except F1-E3.
Regards.
Ginko
Aug 29, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
We cannot set clock on mirowave model wmh1163xvb
Your actual model number from the tag on the oven will be WMH1163XVB0, WMH1163XVB1, or WMH1163XVB2.
You have a failed membrane keypad.
On these models, the membrane keypad is not available as a separate part, so you would have to order the control panel frame assembly which comes with a new keypad.
In this case, you simply move your circuit board into the new frame. That is a simple do-it-yourself job.
Here are the part numbers, depending on color:
Panel Assy, Control - Includes Lens and Membrane Switch
part number color
W10315771 Black
W10315772 White
W10315773 Stainless
W10315775 Universal Silver
You can find helpful exploded view diagrams and order parts by entering the part number or your full model number from the tag on the oven here.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Then you unplug the keypad (as per the photo below) and move the circuit board into your frame.
Some connectors on the relays may have a lock:
May 23, 2011 | Whirlpool Microwave Ovens
E2 f1 errors
E2 F1 is a fault code for electronic sub system failure you are going to have to change the main clock control assembly; enter your part or model number for best results: repairclinic.com/Oven-Control-Board
1. Disconnect power longer than 30 seconds.
2. Re-apply power and observe for longer than 1 minute.
3. If failure remains, disconnect power, replace control.
Make sure your control board is the correct one.
Hope this helps.
May 12, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
No response from the oven control panel.....no lights, clock, nothing Stove top controls work fine.
The Electronic Range Control (ERC), also known as an Electronic Oven Control (EOC), controls all the features of the oven. This is your clock/timer assembly. The surface burners work independently of the oven and usually have electrode type igniters that get their power from a spark module. Since you mentioned your clock display is blank, more than likely you have a defective ERC board. The following link explains how to replace one:
http://www.fixya.com/support/r3727366-replacing_control_kitchen_range
A replacement control board can be purchased from any of the following webistes:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between sites, so shop and compare. The first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need.
NOTE: In most cases the overlay (preprinted plastic display covering with all the numbering and lettering on it) does NOT come with the control board. If your overlay is still in good condition, it can be easily removed from the old control board and reapplied to the new one. Just make sure you properly orient the overlay so the buttons all match up. If you need to replace your overlay, you may need to order it separately. Read the part descriptions carefully to see what your replacement parts include.
The part number for a replacement ERC is 316455400, the overlay (if required) is 316220701 for BLACK. The parts are listed as items 20 and 20A, respectively, under the "Backguard" parts listing.
If you have any questions, please post back with your complete MODEL NUMBER and let me know. I hope this helps you.
Aug 23, 2010 | Frigidaire FEF336BC Electric Kitchen Range
I have power to the burners on top but the oven dont work an the time clock is blank
The Electronic Range Control (ERC), also known as an Electronic Oven Control (EOC), controls all the features of the oven. This is your clock/timer assembly. The surface burners work indepently of the oven and usually have electrode type igniters that get their power from a spark module. Since you mentioned your clock display is blank, more than likely you have a defective ERC board. The following link explains how to replace one:
repairclinic.com
NOTE: In most cases the overlay (preprinted plastic display covering with all the numbering and letering on it) does NOT come with the control board. If your overlay is still in good condition, it can be easily removed from the old control board and reapplied to the new one. Just make sure you properly orient the overlay so the buttons all match up. If you need to replace your overlay, you may need to order it separately. Read the part descriptions carfeully to see what your replacement parts include.
Aug 17, 2010 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Ge built in 1993 oven shows an F-1 sign and beeps
Hello there:
any time you recieve the f-1 and sometimes a f-o error with the beeping this is from the electronic range controle board or erc for short and this means that that part has fgailed and needs to be replaced if you go to repair clinic.com you can look up you oven model number and get parts from there or if you have a appliance repair center in your home town give them a call and tell them the ovens model number and tell them you need a erc or electronic range controle board ok?
Hope this helps
Best regards Michael
Aug 16, 2010 | GE Ovens
I am getting F 1 on my control panel. Have unpluged it 2 times DCF3305BT 0201421915
The F1 on this Amana model indicates a bad control/clock. If disconnecting the power did not work then the electronic circuit board control would need replaced.
Jun 14, 2010 | Amana Kitchen Ranges
Unit oven control burned out due to electrical overvoltage input. Requesting especific part number to replace the electronic card. The kitchen appliance is Model 911.9348810
The control board/clock assy is the one you set and the one you see on the front of the control panel. The part number is WB27M4. There is also another board behing the control which cannot be seen unless taken apart. Looking at the oven from the front the board would be on the right side. This is called the power board. The part number is WB27K5072 but if you order from sears they are putting an R on the end WB27K5072R. Same board either way.
Please rate this post. Thank you
Jan 22, 2010 | Kitchen Ranges
Oven burnout
The oven is controlled by an Electronic Range Control (ERC). This is the clock assembly on the range. The surface elements are powered by infinite switches and do not go through the ERC. That explains why the clock assembly is dead, your oven does not work, but your surface elements do. You need to replace the ERC. If you can provide me with a model number (located near the oven door or bottom drawer opening on most ranges, on the back of the console on some) I can determine what type of ERC you need and how much it might cost you. Post back with comments and let me know if I can be of further assistance. I hope this helps you.
Feb 11, 2008 | Kitchen Ranges
Kitchen Ranges Logo
515 people viewed this question
Top Amana Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal DeAngelo
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
