Question about AEG Lavamat 74640 Front Load Washer
Aeg 74640 error code e30
Aeg 74640 update error code e30 what is it
  • Anonymous Mar 24, 2009
    what is a aeg e30 fault
  • Anonymous Mar 27, 2014
    COD ERROR E30
What does the E40 error code mean?
Posted on Sep 18, 2008
AEG OKO Lavamat 74640 update wont spin. Pump and rinse works ok but doesn't spin.
  1. E52 is a motor fault, i.e. motor not turning or tachometer is faulty. It is most likely that the carbon brushes are worn out and need replacing. These are readily available online
Nov 12, 2016 | AEG Washing Machines
How can I correct error code 25 on an AEG OK-LAVAMAT 74640 update washing machine mean?
Family error code "E20" means difficulties in draining, but I never heard for error code E25 on this model. Could be : E21, E23 and E24 error code.
Dado
Aug 24, 2014 | AEG Washing Machines
AEG Lavamat 64809 error code E30
Lavamat?! Where in the *&%^ is this machine from? Yugoslavia! I'm guessing it will not allow water IN Because only the Spin (Centrifuge) cycle works?! So if that is so you need your water inlet valves replaced, there are Two. Even in machines named after a Bar of Soap!
Jan 04, 2014 | AEG Lavamat 16810 Front Load Washer/Dryer
I have a 74640 Update washing machine and the spin has started to sound very noisy and 'scrapey' when the spin cycle starts. Am i looking at new bearings and if so can you give me an idea of how...
done this already takes bout 6 hrs if ur competent im vechicle tech so have tools etc u will need brgs seal and probably the spider prob cost about 100 all in ididnt replace spider and now one brg has failed again deciding wether to do again properly or replace ta Nigel
May 06, 2011 | AEG Lavamat 74640 Front Load Washer
How do i re set an EFO code on an AEG LAVAMAT
you just need to mop up the water inside the cabinet to allow the float switch in the base to reset.check there is nothing stopping the float returning to the floor. a small leak from the door seal can cause enough of a leak to trip it . clean the door glass and seal to stop this. or change the door seal.
Jul 17, 2010 | AEG Lavamat 74640 Front Load Washer
Oko lavamat 74640 update showing error E20 what does this mean?
its a draining error, check sump, pump and drain hose for blockage failing that it needs a new pump.
Mar 31, 2010 | AEG Lavamat 72640 Front Load Washer
AEG Washing Machine: Door won't close
Hi again,
Any updates/development with your project?
Jun 21, 2008 | AEG Lavamat 74640 Front Load Washer
Lvamat 74600 coalbrushes
Yes most likely the brushes. Easy to fix takes just time.
Remove motor remove back plate of motor and it will show how to remove them
HERE is the place you can get them
Jun 19, 2008 | AEG Lavamat 74640 Front Load Washer
AEG Lavamat 74640 Front Load Washer Logo
2,267 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
