Question about Garden
I have a arien snow blower (924 series) that does not blow snow out the impeller. the auger just pushes it. bothe the impeller and the auger turn. the shear pins for the auger are in. the rear key way for the drive pulley is in. the drive belt is new and adjusted
    Brigadier General:
  • 4,088 Answers
Run the impeller without any snow coming into it--hold your hand over the exhaust of the impeller to check for considerable wind force. If almost non existent, make sure the impeller is being driven at full speed. Is there a shear pin related to the impeller? The only other problem would be if the impeller was running the wrong direction, but I don't see how that would be possible. Hold the impeller with your hand while trying to turn the pulley--there should be no slipping between the two. Hope this helps!
Posted on Jan 04, 2011
My ariens 8524 doesn't blow snow very good,whats wrong? sheir pins are good and i put a new auger belt on it
Does your engine rev up the way it should. You can't blow snow very well if you engine is at half speed.
Dec 22, 2016 | Garden
How do you put it in neutral
Does it have steering control triggers to turn it left or right...if so hold both at the same time with engine off and see if you can push it..Let me know if that works. Or let me know what kind of controls you have
May 13, 2014 | Rotary Snow Blower Parts Replaces Ariens...
Auger does not turn
If the high speed impeller is turning, but the auger is not, there are 2 failure modes:
1. The sheer pin attaching the auger to the shaft has sheared. There is one shear pin on each side. This is an easy fix. Buy a new shear pin. Do NOT use a regular bolt.
2. The gear box between the 2 augers is broken.. This is an expensive fix and requires modderate skill for a DIY fix.
If the high speed impeller is not turning, it is likely the belt is broken between the engine and the blower. This is a relatively easy fix.
Feb 05, 2014 | Ariens Garden
Auger does not engage on Ariens Model 924121 sno- Thro
first check shear pins in the auger ( try to turn big auger by hand, engine off)
then if they are good then try to turn impeller by hand, engine off
youll need to turn it a few times before the larger ones turn, but thats what you want
if they dont turn then you have sheared the gear box gears
be sure belts are good tooo
Dec 15, 2013 | Ariens Snow Blower. Sno-Thro Deluxe Drift...
Ariens st350 snow blower wont blow snow, augers wont spin
there is a bolt that goes thru auger and spinning shaft (look for a hole where it once was) holds the augers to the spinning shafts, it is called a shear pin, it is a safety feature, and made of softer metal, so if you pick up something too hard with the auger, it wont lock up the engine, or break engine crank shaft.find an ariens repair shop to purchase the shear pin so you get the right softness of metal.
Mar 05, 2013 | Garden
The blower won't throw snow - especially heavy snow. Auger and impeller turn but bog down. Trying to replace belts, but there are no numbers or sizes on them. Are these generally available (say at a...
If the belts are intact, then NAPA or a hardware store should be able to replace them. If they are shredded, then you should order them from Ariens. Good luck!
Feb 01, 2011 | Garden
Ariens snowblower impeller not throwing snow
Sounds like you have a broken or partially broken shear pin in the auger.Check along the auger[machine off]and see if there is what looks like a bolt anywhere along the auger shaft.If there is [and there will be] remove and inspect it and you will see why the auger is not working.Next time,never clean out a chute or auger while the engine is running,people loose limbs this way.
Feb 13, 2010 | Ariens 34 In. Zoom Series Riding Mower
Only one blade turns automatically on Ariens snow blower.
There is a bolt that goes through the center of the shaft that shears off if you hit something. You will need to line up the holes of the internal shaft with the auger tube and install a new bolt.
Feb 09, 2010 | Ariens 34 In. Zoom Series Riding Mower
Craftsman 247 88190 0 snow blower auger frozen
my auger and impeller froze too. fixed by clearing all snow, ice,stone build up behind impeller it works fine now.. hope that helps
Jan 19, 2009 | Ariens 34 In. Zoom Series Riding Mower
Garden Logo
138 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
