Question about Power Acoustik Car Audio & Video
Equalizer hi my levels on the eqaulizer not responding
Hi Sir
I Think You Should First Reinstall Your Car System And then you can try it again
if you are not successful in doing this then you should replace your car battery or check your battery terminals
thanks i hope it will help you
Posted on Jul 12, 2008
  • Nikhil Malhotra
    Nikhil Malhotra Jul 12, 2008
    I Hope it will help you
What plugs into the PRE OUT (L) (R) and the power amp in (L) (R)
Pre Out ( L ) ( R ) can be connected to other Amp Input,
or another Equalizer or Compressor/limiter
Power Amp In , should you need to connect direct to main amp input
Aug 03, 2012 | Sony Av-910 Receicver Fm/am Suround Sound...
Hi i just got a ava1202 boss eq it didnt have instructions this eq has rca inputs and high level speaker inputs can i use this eq with out an amp can smeone plz help me thnk u
Yes you can use the equalizer without an amplifier. That is what the high level speaker inputs are for. You simply take the positive and negative from a speaker and hook it up to the positive and negative high level speaker inputs on the equalizer.
Jun 04, 2011 | Boss AVA-1404 7-Band Car Equalizer
How much fork oil in the tuono 2007 1000r usd showa forks please
Oil level: 122 ± 2 mm (4.80 ± 0.08 in) (edge-leg).
FOR PROPER OIL LEVEL MEASUREMENT The slider must be perfectly vertical. The oil level must be equal on both legs.
Hope this will help.
Regards,
Alex
PS-Don't forget to vote me, thanks!
Sep 27, 2010 | 2008 Aprilia Tuono 1000 R
Needs manual of sony str 6800 sd, whats the function off de externial adapter, can you connect a eqaulizer on it? Is it the same as a pre main connection?
Hi...
I won one of these. Very nice receiver too.
You can use the Pre-Main connections OR tape 1 in/out (as long as you select Tape 1 monitor)
I dont know what the Ext adapter is.
Try www.stereomanuals.net
Feb 21, 2010 | Sony Audio Players & Recorders
Hi i,ve got a cb900fz running very rich on cyls 2,3,4 the carbs appear to be standard i,ve recently fitted new air cut off valves float heights appear right but are plastic one piece units so non...
sound like the carbs need to be synced if throttle plates are fully closed at start it would cause a rich condition and no need for a choke becase there is very little air passing through mostly fuel if they are not eqaul there would be hesitation when opening throttles til about 1/4 throttle
Jan 30, 2010 | 2004 Suzuki GSX-R 1000
Equalizer setting help
try to use the preset equalizer settings after which you can come back to the parametric equalizer and adjust to your own taste. no problem if you don't connect the subwoofer just make sure you set the hi-pass filter to off so that you will hear the full range to your speakers. but, I advice you to put a subwoofer. There is more dynamics to the lower freqs too. don't adjust the source level if there is no problem. take note the EQ of your head unit is a parametric equalizer. hope this helps while you read about parametric EQs.
Apr 20, 2009 | Pioneer EQ-6500 9-Band Car Equalizer
One out of the two microphones is intermittent.
Hi Ken....
I just fixed one of those but not for the same issue.
The manual is on the peavey site (archived)
That will tell you if there's a VOX ckt inside.
If opening the case doesnt scare you, open it ( UNPLUGGED) and reseat the ICs(integrated curcuits) that are socketed
Feb 01, 2009 | Peavey Audio Players & Recorders
Need wire diagram for clarion 500EQA equalizer
Your installation manual is not anywhere to be found since the product you are inquiring about was made 1985-87... however, by deduction, you can figure it out yourself...
You need a Power 12V Constant.
A 12V Switched
A Ground
And Signal Cables.
Reply with the wire colors available to you, and I will tell you what is what.
Yellow is usually constant 12V.
Red is Ususally switched 12V.
Black Is Ground.
RCAs are self explanitory.
If your EQ has HI Level outputs, the color scheme is a little more complicated.
Jan 03, 2009 | Clarion EQS560 5-Band Car Equalizer
Unable to turn PROTECTION ON, off!
Annie, your tuner, is it a receiver that incorporates the main audio amplifier as well? and your equalizer is an additional gadget only? are you sure you got it wired correctly?
If you're connection is the usual since you have moved places, something must be wrong in your amplifier output stage or your speakers too, or since this happened only when you changed place maybe you wrongly interchanged the plus/minus cables. Your amp wil activate protection at 50% vol. That displayed protection on means overcurrent in the amplifier output stage, either you have a bad speaker or overdriven input stage, the output then consequently overdrives as well. check first your speaker polarity. Also try to reduce the equalizer output level to 75% maybe. then try it again if it still does the same, we'll try something else. not a big thing to rewqire your eqaulizer to your receiver. even without the manual
Mar 18, 2008 | Audio Players & Recorders
Car Audio & Video Logo
101 people viewed this question
Top Power Acoustik Car Audio & Video Experts
Tygh Duval
Tygh Duval
Are you a Power Acoustik Car Audio and Video Expert? Answer questions, earn points and help others
