Question about Hitachi 43UWX10B 43" Rear Projection Television
We are having problems with the blue convergence being off.
  • Hitachi Master
  • 3,459 Answers
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set twe are having problems with the blue convergence - 578ba6c.jpghe fluid changed.
TVwe are having problems with the blue convergence - 69189a5.pngter fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on Jan 22, 2011
Blue shadows and a yellow and blue arc acroos the bottom of the screen
Tv have a problems known as a convergence problems it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board it is dead.The tv convergence board must require replacing 2 STK convergence ICS and some or all of it resistors too.To fix the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Mar 02, 2011 | Pioneer SD-582HD5 58" Rear Projection...
Philips 43pp92 blue will not converge
STK392-120 is convergence correction amplifier.. the problem is the convergence circuit... try to check the small Valuie electrolytic capacitors or High value resistors! maybe the said parts is in change Value... used a ohmmeter tester to find the chenge value parts!.
Nov 05, 2007 | Philips 43PP9202 43" Rear Projection...
The blue lines on the left lower side of the tv will not converge. The tv has never given me a problem. I woke up one morning and powered it on and noticed the blue is misaligned. I tried converging and...
This problems can happen to the DLP tv any times of it tv life.Tv is 100% have a convergence problems.The 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Dec 03, 2010 | Pioneer SD-643HD5 64" Rear Projection...
Panasonic PT-47WX49E blue convergence problem.
if convergence does not adjust in menu mode could be a defective convergenceic or fuse
Nov 11, 2009 | Panasonic PT-47WX49 47" Rear Projection...
Blue convergence bows when watching tv, hdtv looks great
Below are two of the most common problems encountered with projection TV sets.
Problem #1 - CONVERGENCE PROBLEM
Projection TV2_bing.gif sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung2_bing.gif, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit from the link below.
  • Screen looks 3D
  • TV shuts off after powering on - TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash2_bing.gif focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
Sep 14, 2009 | RCA HD52W58 52" TV
Convergence problem, blue ghosts
Projection TV sets have several common problems listed below.
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Problem #2 CRT Fluid has clouded over.
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
  • Halos around objects
  • Red/Orange looking
Example Photo:
You can see more examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 01, 2008 | Samsung PCN5425R 54" Rear Projection...
Blue Convergence
Hello All Above,
Your one and only problem is a bad convergence Amp board. Changing it will fix your set. You can contact http://www.interactiverepair.com for step by step assistant with installation of this board.
List price $100
Part Number: BP95-00142P
Best regards
circuitcity
Mar 11, 2008 | Samsung HCN653W 65" Rear Projection...
Blue shadow
If the blue shadow is convergence you should have an option for convergence adjustment via the remote control to converge the blue onto the green. If it doesnt move then its probaly a IC problem. What make and model set do you have?
Jan 02, 2008 | Televison & Video
Blue convergence
Plus and minus power supply voltages to run the convergence circuitry.....you might need a diagram to trace blue horiz &
blue vertical....Also, ?....What part # is STK and what did you
install.............??.....................T.
Nov 15, 2007 | Panasonic PT-53WX42 53" Rear Projection...
Jvc av56pw74 blue shadow
You are going to need a full convergance alignment to rectify this issue.
Aug 09, 2007 | JVC AV-27720 27" TV
Hitachi 43UWX10B 43" Rear Projection Television Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
