Question about Gestetner Office Equipment & Supplies
We have a gestner dsm74se it makes copies ok but when you make multiples it gets lighter and lighter on certain copies and doesn't look good
  • 541 Answers
You probably need your pcu replaced or rebuilt the drive gears that supply the toner stip . you get light copies and a noise. we can service it in the detroit michigan area 246-677-8112
Posted on Jan 07, 2011
Why is my Bihub C220 printing multiple lighter black images beside some words
well if copying is OK. then mite be the files. try word pdf web pages do they look ok?
Jun 15, 2017 | Konica Minolta bizhub Office Equipment &...
Gestner dsm620d copies with thick black lines on it
Print a counter page. Does it have the same symptoms? If not, the problem is in the optics. If yes, probably the fuser hot roller is worn out (you can look at it and see them) or the drum is worn out.
Sep 04, 2013 | Gestetner Office Equipment & Supplies
2005 mercedes-benz e320 . lighter outlet cigarrete is mot working and it isnot the fuse,, what should i do?
With the ignition off try prying the tabs closed on the inside of the cig lighter. Sometimes they get spread apart to far when using auxillary chargers. Make sure the ignition is off or you will short to ground and pop the fuse for sure. If that doesn't work and the fuse is good then you'll need to replace the cig lighter as a complete assembly.
Sep 27, 2012 | Mercedes-Benz E320 Cars & Trucks
My cigarette lighter doesn't work but my fuse is good and the switch is hooked up, what could be the problem?
Could be the lighter part itself that is no good, you can buy replacements at the auto parts store very cheaply. You might want to check the wires to the lighter and make sure they are tight and that there is no corrosion on the inside of the socket. You can also buy replacement sockets at the parts store. Most times there is enough corrosion that the grounds don't make contact good.
Sep 26, 2011 | 2001 Ford Taurus
How do I darken the print when I make a copy?
for black and white copy:
  • press the arrow key until the pointer comes to copy b & w,press OK to select the copy settings.
  • press the arrow key to scroll through the copy settings then press OK to select the options.
  • go to lighter/darker menu then press OK to confirm settings.
Jul 24, 2011 | HP Officejet J4680 InkJet Printer
My 1998 Ford anger xlt has a fuse problem...Air conditioner doesn't work and cigerette lighter doesn't work. Are they on the same circuit? I don't have an owners manual. Thanks
Not sure what you mean when you say an air conditioner problem like if the compressor clutch isn't engaging or the blower motor isn't working, that kind of thing. Anyhow, I am about 99 percent sure they are not in any case. What I did do for you is give you pictures of the fuse layouts as well as the descriptions for each fuse (see below). You mentioned that you didn't have an owners manual. If you would like a copy, email me at csautomotivecars@att.net with your make, model and year and I will be happy to email you a copy. Don't worry, there is no cost for it. I hope this helps and good luck.
Jun 21, 2011 | Ford Ranger Cars & Trucks
Mp160 printer prints on multiple pages, doesn't appear to be a set up problem. Re-installed drivers no change, reset printer no change. Any ideas?
Are you saying you are getting the same page printed many times? What happens when you make a single copy? do you get one copy or multiple copies? If you get one then then it does not sound like a machine fault. I wonder how you "Reinstalled" the driver. You should do this via programs, canon, uninstall. A lot of people go to printers and right click on delete thinking that uninstalls it. Try it my way and download the latest driver from Canons website. unplug the usb cable and install the software and only plug the cable in when prompted to. Hope fully all should be well.
Now this may sound silly but if you are using windows vista then funny things can happen. Canon and vista dont go well but then what does with vista. lol
May 28, 2011 | Canon Office Equipment & Supplies
6-part NCr paper form being used. Pages 1 and 2
This is a problem with your paper. Using multi-part forms on an impact printer will get lighter print on each layer working from the top form to the bottom. The "carbon" paper has to impact the paper hard enough to make the marks. If your top and bottom copies look good but some in the middle are light it is a problem with the "carbon" paper and not the printer.
Now IF the top page is light and each copy under that is getting lighter then you need to close your platen gap (the lever on the right side of the machine mark A B C) go one click at a time (darkening) until the print quality looks good (or you go too far and it pinches the paper and jams *not good*)
Feb 16, 2010 | IBM Infoprint 6500 Matrix Printer
How do i change to get copied document to appear
There are 3 settings for print quality on the front panel, good, better, and best. Also when it is set on copy you press the menu button and scroll thru the choices and you will find a contrast setting that you can scroll to a lighter setting.
Jan 29, 2010 | Brother MFC 240C All-In-One InkJet Printer
56 people viewed this question
Top Gestetner Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
Norman  J Weimar Jr
Norman J Weimar Jr
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
