Question about StarTech.com StarView SV211K 2-port KVM Switch
Can you tell me how can ONE obtain keys ?
Can you tell me how can u obtain keys for t*wst? i shall be very greatfull
  • 103 Answers
Tw codes for 9th july approx 6:30
00: c3 40 78 a2 b2 1c 84 f9
01: fc 5b d3 21 c4 e0 7a fe
please leave a ranking thanks good luck
Posted on Jul 09, 2008
Need wst 3501 manual
Try Googling (brand)(wst 3501)(manual) without parens.
Oct 09, 2017 | Office Equipment & Supplies
Recently odered a boss dd3 digital delay pedal I was just wondereing whether the order was successful and when I shall expect it to be delivered I would be greatfull if you could inform me of these...
I would suggest trying to get in touch with the people you ordered the product from as they will be able to help you.
Where did you order it from?
Maybe you have a confirmation email waiting for you?
Mar 15, 2011 | Computers & Internet
HOW WE CAN RESOLVE Error message E1 CHG.WST.CTN
This tells you that the waste container is full and needs to be replaced. This LINK tells you the step by step process in resolving this issue.
I hope this works for you. Kindly reply for further assistance. Good Luck!
Thanks for using Fixya!
Mongkey
TIPS: Is your computer slow? This might help
http://www.fixya.com/support/r8158906-diy_manual_pc_tune_up
(for Windows only)
Feb 19, 2011 | Canon Color ImageRunner LBP5970 Laser...
What does the error code E000005-0000 mean?
This is a cleaning web end of life code. Replace the web and reset the counter in service mode. Press the additional function key, then the 2 & 8 at the same time, then the additional function key again. Press copier, counter, MISC, FIX-WEB, then OK. You might as well reset the WST-TNR setting as well. Check to make the waste toner bottle is empty - right side ,lower right of copier behind panel.
Nov 10, 2010 | Canon imageRUNNER 5570 Copier
Where is waste toner receptacle?
Hi Gail. On the right side,rear lower corner, you will find a cover that's about,oh 5 inches wide and about 15 inches tall.It is secured by 2 screws at the top and has 2 small "legs" at the bottom that fit into the frame of the copier to keep the bootom in place.Remove the top 2 screws and allow the cover to "tilt"away from from the copier top first.Look down and you will see the "legs" and the notches they go in for re-installation.Once the cover is removed the waste toner bottle is exposed.Slide it out and pour it into a trashbag,being careful not to spill it or cause an inordinate amount of airborne waste toner.Reinstall.NOW,for this model Canon you actually have to tell the device you have emptied the bottle.You will need to go into service mode.You do this by pressing the ADDITIONAL FUNCTIONS button,then release it,then press the numbers 2&8 at the same time, release, then ADDITIONAL FUNCTIONS again.That a 3 step process that will bring up the service mode screen. Press COPIER.You will see several tabs across the screen at the very top..The tab at the far right says COUNTERS.Press it.New screen shows up.Press MISC in the lower left corner.You will see FIX-WEB and WST-TNR.Select WST-TNR.To the right of this field you will see a value that's probably around 300,000.Now go to your 9 key pad and at the bottom you will see a "C" which means clear.Press the "C" and the value next to the WST-TNR box should clear.CONGRATULATIONS!!!! Have a good day. :-)
May 07, 2010 | Canon imageRUNNER 5570 Copier
I need vacuum cleaner bags for a WST 1300
call a vacumn or small appliance repair shop most vacumn repair shops will know what bags you need esp if they service your model or may be able to tell you who to call
Dec 18, 2009 | Vacuums
N72 in off line
You will need to format your phone and restore it to factory settings. Backup your data before you start the format. To format:
Press *#7780# on your phone, it shall ask you weather you want to restore the phone to factory defaults? Select Yes, enter the security code (default is 12345) the phone shall restart. Now once it comes back, press *#7370# and follow the same process again. After it comes back, everything should be working fine.
In case you do not remember the security code, then turn off the phone, press the star key (*), number 3 key and Green keys (the one used to make the calls) together and keeping them pressed turn on the phone, do not release the keys until you see the formatting screen, let it complete and the phone shall restart and then it should be working fine.
Dec 11, 2009 | Nokia N72 Cellular Phone
Can u tell me how can one obtain keys?
contact me and I will always provide u wid keys
Jul 09, 2008 | StarTech.com StarView SV211K 2-port KVM...
Can u please tell me how can one obtain keys?
contact me!!!!
until then here is New code
Tele*est 11th July
C3 40 78 A2 B2 1C 84 F9
2A 09 4D DF CD 33 00 B9
StarTech.com StarView SV211K 2-port KVM Switch Logo
Top StarTech.com Computers & Internet Experts
Alun Cox
mbowen171
mbowen171
Are you a StarTech.com Computer and Internet Expert? Answer questions, earn points and help others
