Question about Scheu (85-FAC) Heater
I have a SCHEU Products SPC - 85 Propane Heater that would not stay lit. I now cannot get it to light at all. The plug is firing. I assume it is the thermocoupler.
5 Suggested Answers
Buffalo12980
  • 625 Answers
SOURCE: reddy heat/scheu kerosene space heater no ignition
Typical kero heater uses either a spark ignition or a hot surface. The hot surface igniter is very fragile. A small bump may break the elements. Flame is detected by a photocell, signal is sent to the lockout relay board. Change the igniter costs about 50 bucks.
Posted on Nov 29, 2007
Buffalo12980
  • 625 Answers
SOURCE: all pro spc-85
going through the backplate to the nozzle location is the thermocouple. it is a copper like tube that sits back from the actual flame. if you are looking for a replacement go to www dot desatech dot com.
Posted on Dec 11, 2007
SOURCE: I currently have a Scheu
I have had the same problem on a smaller unit (30,000 BTU). I remove the cover, take the thermocouple out of the burner area, and clean it until bright with either scotch brite or very fine emery cloth. The deposit on the outside prevents it from tranfering the heat to the hot end of the thermocouple and in turn to the sensor. I usuall do this once a year. The cleaning hasn't worked for me recently but the unit is 12 years old now and I will look for something else to fix.
Posted on Feb 06, 2009
mxc2
  • 146 Answers
SOURCE: My 85-FAC heater wont stay lit when I release the
Just remove the end of the thermocouple from where is goes into the gas valve and leave the end that goes into the flame in place.
Clean the end of the thermocouple connect by scraping off just a little metal from the end just about there the nut tightens the thermocouple into the gas valve. After you have exposed some new metal do the same inside the valve where the thermocouple seats into the gas valve.
Use a small pic or similar item to scrape inside the gas valve to expose some new metal there also.
Now reassemble the thermocouple into the gas valve and see if the unit works when you release the button.
Here is a link with some more instructions.
http://www.msservice.net/ts/reseat_thermo-clean_pilot-ODS.htm
Posted on Oct 22, 2010
Have 2 heaters 1st heater will not light, has gas
sometimes you need to hold down the button for 5 to 10 seconds while the heater heats up,, as soon as it gets to temperature then it should stay on with no problem.
as far as the one that is not lighting -- all I can thing of is that the igniter is not close enough to the fuel exit area ( ? ),, with the power off - ( un-plugged ) look inside as you press the igniter and see if you can see the spark arch. -- also, if this is a new heater there is a chance that there might be something wrong with the regulator and it is either getting to much or not enough gas.
c...
Dec 31, 2010 | Scheu (85-FAC) Heater
I have a dyna pro propane heater model rmc-fa100dep,will not stay lit. I took it apart. I think I need a new thermocupler. Any idea where I can get one?
YOU SOUND LIKE YOUR ON THE RIGHT TRACK,, I USE GENERIC ONES THAT FIT IN WATER HEATERS OR FURNACES THE SALE THEM AT THE HARD WARE STORE FOR AROUND $10.00 USE YOUR IMAGINATION TO MAKE IT FIT, PRETTY EASY, GOOD LUCK LEAVE FEED BACK THANKS
Jan 17, 2010 | Desa International ALL-PRO® SPC-85 Utility...
Heater lights but goes out when button is released
if it is propane fired, I would replace the thermocouple first.
Jan 13, 2010 | Scheu (85-FAC) Heater
SPC-40 wont stay lit
Problem is either the thermocouple or the thermoelectric valve. I have one of these as well with the same problem. On mine it is not the thermocouple. I have replaced the thermocoupler and still have the problem. A thermoelectric valve is $42.25 at http://www.masterheaters.com/propane/
Im looking for a cheaper part. Any suggestions?
Gru es 1234 @yah oo.c om
Jan 12, 2010 | All-Pro Propane Garage Shop Heaters - All...
Where can i find a parts breakdown for this heater spc-85
I plug a Thermostat in The power line to break the power when at temp. Once I start the heater using the reset button,when temp is reached and the themo calls for heat just the blower comes on only. I have a All Pro propane 50,000 to 85,000 btu heater thanks Ron
Nov 21, 2009 | All-Pro Propane Garage Shop Heaters - All...
Will not stay lit. Full tank of gas. M/N Universal 85-FAC
change the millivolt generator or check the two spade connectors on the millivolt's tube. wires go to a klixon temperator overload.
Oct 15, 2009 | Scheu (85-FAC) Heater
SPC-12 SPACE HEATER WON'T STAY LIT?
When holding button in,you are overiding themocouple funtion. You probably need to replace the thermocouple
Feb 27, 2009 | All-Pro Propane Garage Shop Heaters - All...
I currently have a Scheu Universal 250, 250-A all pro spc-250, SPC 250-A 250,000 BTU constructtion heater that I can't get working. I've connected to a propane tank w/ regulator and can't get it to fire. I...
Dec 23, 2008 | Heating & Cooling
All-Pro SPC-85 Utility Heater
Check the thermocouple, it is a very small diameter copper wire that goes from the gas valve to the burner. Make sure it is being hit by the flame. If it is, remove it and go to a good hardware store with it and get a new one.
Jan 15, 2008 | All-Pro SPC-85 Utility Heater
Scheu (85-FAC) Heater Logo
352 people viewed this question
Top Scheu Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
Are you a Scheu Heating and Cooling Expert? Answer questions, earn points and help others
