Panasonic PT51hx40b I have the above model and all of a sudden it smelled llike something was burning and it shut off....I tried to turn it on and it clicks on then about 5 seconds late it clicks off.....any suggestions?
  • tamall Mar 17, 2009
    The television was on and working fine. Developed a smell(bleach scent). The picture went out and now has a clicking sound when it is turned on. Has no picture.
  • 8,617 Answers
Does the power indicator blink? If so let me know the number of blinks when you press power.
Posted on Jul 09, 2008
Kodak 5210 all in one was working fine but all of the sudden it shuts off and now doesnt power on at all and smells as if something burnt out on inside
If you detect a burning smell, it's time to unplug the printer and replace it. Always unplug immediately whenever you have an electronic device with a burning smell as a matter of safety. As Kodak no longer makes inkjet printers, you will need to select another brand.
Hope that helps,
Bax
Sep 25, 2013 | Kodak ESP 5 Printer
My rainbow 1650- was working fine then all of a sudden it powered down and had a burning smelt a little electrical, but also like something else. Then I hit power switch andi unplugged The unit. I took...
It might have been the wad passing through but with a burning electrical smell it should be checked out by qualified technician. Burning electrical smell means it may catch on fire
Sep 23, 2013 | Vacuums
Dryer shutting off too early. Faint smell of something burning?
Check the vent for clogging condition that will turn off unit and cause it to overheat. If vent goes up to roof check up there also - that is where mine was clogged with a sort of paper mache clog!!!!!
Sep 02, 2017 | Whirlpool LER4634J Electric Dryer
Vacuum shuts off and has a burnt smell
Try removing the drivebelt, and try running it to test like this. The brush bar will not turn, but it should function normally without smell at this point. If it doesn't, you may need a new motor as I think the brushes may have worn down - producing an electrical type burning smell.
If it runs fine without the belt attatched, then there is probably a build-up of hair or threads at each end of the roller stopping it turning freely. With the hoover off, check it turns freely and easily. A small metal nail file or similar is usually a good tool to clear it.
If the roller is stiff, the belt will not turn easily, and overheat on the motor spindle - causing the burning smell.
Jan 08, 2009 | Hoover Vacuums
Panasonic WIDESCREEN 52" hdtv: power tries to come on and then there is a burning smell. The power button LED on the TV flashes several times. This starting happening after the TV was on and suddenly...
check of fluid leak from the tubes, check to see where the burning smell is comming from. could be anode, hv wire, splitter, surge caps in h-circuit, but it sounds like a high voltage transformer.
what is your model number of your tv?
Apr 10, 2008 | Televison & Video
Schematics of the pt51hx40b
check the board, maybe is burned , I have the schematics, if you want it, write me to ipbass@gmail.com, only I need the model of the board
Mar 11, 2008 | Panasonic PT-51HX40 51" Rear Projection...
TV suddenly blanked (power is not off)
It is probably a burning deflection yoke.I just fixed an identical model with the same condition,Jim
May 20, 2007 | Panasonic PT-51HX41 51" Rear Projection...
Televison & Video Logo
93 people viewed this question
Top Televison & Video Experts
