Question about Microwave Ovens
Remove a 1986 Quasar over the stove Microwave
  • Microwave Ovens Master
  • 9,098 Answers
You can enter your model number here to see if the manual is available for free download.
If not, you'll need to order the manual here.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jul 12, 2008
What is the cu. ft. of a Quasar mqs0963e microwave oven?
About 0.8 cu.ft. - internal dimensions: 8inch x 13inch x 13 inch
Feb 02, 2015 | Microwave Ovens
Installing a microwave / convection oven above a stovetop
Needs to be properly vented to outside the house. Only install a microwave that's designed for over-stove use in this space.
Aug 25, 2014 | Microwave Ovens
How do i remove a over the stove microwave?
On a 1-10 scale- this is a 2.
place a cardboard box on the stove to support the microwave once it is free.
Remove power cord from the outlet in the cabinet over the microwave.
In the cabinet over the microwave, locate the 2 mounting screws.
Loosen each one about 6 turns- the microwave should drop down in the front by about 1/2 inch.
Once loose, you can remove both screws completely and allow the front of the oven to rest on the cardboard box.
While supporting the front of the microwave,have a helper remove the cardboard box.
Tricky part...while supporting the front - angled slightly down, lift hard under the rear of the microwave and pull toward you.
Have a helper feed the power cord through the upper cabinet bas as you bring the microwave toward you and slightly down.
Place the microwave on the counter- with a towel in place to prevent scratching the counter.
remove the rear-wall mounted support bracket.
Apr 27, 2014 | Maytag MMV4205 Microwave Oven
Stove fire smoke on microwave above stove.what will clean off this smoke residue? we encountered a stove which left a heavy smoke residue on the microwave above. the microwave has a plastic handle and...
Mr. Muscle Kitchen cleaner will remove the smoke. It won't hurt the plastic. Just make sure to either wear rubber gloves or wash your hands soon after cleaning off the smoke residue. It will make the skin on your hands / fingers slick and then dry after your done. Let the cleaner sit for about a minute before trying to wipe off the smoke residue.
Mar 16, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Remove over the stove microwave Sharp R-1462
Ther are 2 long screws at the top on the left and right side in the cabinet.Remove them carefully it is heavy and will drop hard if you do not hold it while you remove them.If it does not come off then there maybe a release handle on the top left part of the vent you must look carfully hope that helped:)
May 18, 2009 | Microwave Ovens
Can not remove microwave from wall
There should be screws in the cabinet floor ABOVE the microwave. Unscrew them, they will be long. Make sure you have someone to help you hold the microwave while you unscrew. One all the screws are gone, unplug the microwave and tilt the unit front first down about 45degrees then lift the back of the unit up 1-2 inches. Pull it forward and you should be all set.
Apr 20, 2009 | Microwave Ovens
How do you remove a microwave above the stove
Take the glass tray out and unplug it. Remove the 2 or three phillips screws in the top of the cabinet going into the micro. They should be towards the front. Hold up on it while removing screws. When all screws are out, let it tilt forward and lift it up off of the hooks. Some require help, so be carefull and put blankets on your stove to set it on when it first comes out.
Apr 10, 2009 | Kenmore 63762 Microwave Oven
Removing a Sharp Carosel R 1440 over the stove microwave
you should be able to do this yourself. Do you have an outlet to plug this into, or will you need to hard wire it into your apartment/house wiring/. If the former, then you should be okay. You will need a bracket/plate to mount the microwave to.
May 26, 2008 | Sharp R-510HW Microwave Oven
Microwave Ovens Logo
304 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
