Question about Kodak EasyShare C1013 Digital Camera
My camera turns on and off normally, i have the software downloaded and my album is empty. when i connect the cable from the camera into my computer, the camera turns off and wont turn back on unless i disconnect it. how can i keep the camera on and connected so i can transfer my pictures to the album on my computer?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Kodak Master
  • 102,366 Answers
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use any photo cataloging program.
Posted on Jan 03, 2011
How can I install my Samsung camera S860 to computor without disc
Cameras don't require a disk to connect with a computer. The disk contains software, supplied by the manufacturer, to edit and print pictures from your camera. windows already has software to edit, crop, print pictures as well as create albums and slideshows.
Simply connect the camera to the computer with the USB cable and turn it on. After a few seconds, the computer will see the camera and a window will appear asking what you want to do. Then follow the instructions when you decide what to do with your photos.
Apr 05, 2011 | Samsung S860 Digital Camera
How do they connect to the camera
I presume your question is a typo. Cameras do not connect to cameras, they usually connect to computers to download the photos. The camera shouold have a download cable with a normal USB plug on one end that connects to the computer and a very small plug at the other end that connects into a matching socket somewhere on gthe camera. If you have the camera socket but no cable then either go buy a cable from any computer or camera shop, or you can remove the camera storage card and insert into a computer card reader. It will then act as a new drive and the computer will give it a drive letter. The same will apply if you use a connecting cable between camera and computer. Either way when the computer recognises the camera card, it will give it a drive letter and you can then download your pictures to any folder on your computer. However, almost all digital cameras have download software on the driver disc and if that is the case with your camera then go get the connecting cable - take the camera with you to the shop if you're not sure of the cable type
Dave
Mar 12, 2011 | Cameras
When I plug cable from camera to USB computer connection, nothing happens!
Not enough information. The transferring of files requires a sequence of functions to happen before the pictures will transfer to the computer. You will need the camera software installed on the computer. The camera sequence for transfer and each camera is different, some just need you to turn the camera on after connecting the USB cable while others require you press the "Playback" button to transfer files. Depending on the camera software installed on a computer they "normally" download to a file folder then the pictures can be opened in the software programing.
Feb 08, 2011 | Cameras
I think mine is the e260 - 2 gig sansa. The last time I turned it on, it resumed playing the album that had been playing the previous time I used it - as normal. When the album finished and I tried to...
Resetting the device:
1. Press and hold the Power/Menu button for approximately 20 seconds.
2. Release the Power/Menu button.
3. Press the Power/Menu button again to turn on the player.
Jan 09, 2010 | SanDisk Sansa e250 MP3 Player
Downloader says no pictures on the camera!
Computer does not recognize camera and unable to download pix???? It sounds like a bad usb cable connection. Try purchasing a new cable.
Jun 11, 2009 | Disney Pix Click Digital Camera
Western digital external hard drive showing empty folder
Hi Elizabethfam
If not removed safely, external devices can lose information when disconnected.
I recommend using a free recovery tool called Handy Recovery which is normally used to recover files accidentally files on a PC. The application can also be used to try and recover files on your external HD.
Handy recovery: http://www.handyrecovery.com/download.shtml (look for the small button near the bottom that says 'Freeware')
~Rob
May 16, 2009 | Western Digital My Book Essential 1TB...
Downloading from Camera to Computer
FE-180 camera is not connecting to the Desk Top Computer in which the OS is XP
Jul 11, 2008 | Olympus FE-180 Digital Camera
Downloading Images
Downloading images from a digital camera can be very easy if you keep these basic steps in mind. After loading the PhotoMax software on your computer: 1. Make sure that both the camera and computer are turned off. 2. Confirm that the camera has adequate power (using the AC adapter is recommended; otherwise, make sure that there are fresh batteries in the camera). 3. Plug the serial cable that came with your camera into the serial output of the camera. 4. Plug the wide end of the serial cable into the COM port (serial connection) of the computer. 5. Turn the camera on and start the computer. 6. Launch the PhotoMax software (double-click the icon) from the desktop. 7. Click on Get Photo. 8. Click on Album or Camera. 9. Select Twain device from the Acquire From box and click OK. 10. Select your camera from the Select Source box. 11. Click the Acquire icon: (Thumbnails will be displayed). 12. Select images you wish to save from the thumbnails and click on Get Photos. Your images will now be saved to the album you choose.
Sep 21, 2005 | Polaroid PhotoMax Fun Flash 640 Digital...
Kodak EasyShare C1013 Digital Camera Logo
61 people viewed this question
Top Kodak Cameras Experts
Tony
Jerry Greenberg
Jerry Greenberg
Are you a Kodak Camera Expert? Answer questions, earn points and help others
